Question about Home
Monda rococo toilet back to wall
How to install
2 Suggested Answers
  • 349 Answers
SOURCE: When installing a new toilet. How far from the wal...
To rough in a standard toilet allow about 13 inches to center of drain. That will give you space behind tank so it's not right on the wall.
Posted on May 23, 2010
How do I tighten a mondella rococo toilet seat
Tighten the attaching hardware
Sep 17, 2014 | Home
Where can i buy spare toilet seat screws and fixings for monda rococo toilet suite?
Try to see if you can get them at Lowe's or Home Depot hardware stores. IF you can't geet them there. Try Googling ir or searching for it online. :-)
Jan 18, 2014 | Home
Changing from villeroy and boch soft close toilet seat to a firm close lid.
I have an American Standard Toilet that you can't get to the nuts and bolts when it is installed. You should take a small mirror and see if you can see the nuts and bolts from the back/wall side of the toilet. I hope you can reach them. I had to disconnect the toilet the floor flange to do it because I couldn't fix a tool back there. Which meant I had to replace the wax seal and reinstall the toilet.
what is involved if you need to disconnect the toilethttp://www.youtube.com/watch?v=Y_hVZ3rPzm4
Apr 18, 2013 | Home
MMy past and now New currant mansfield toilet bowels do not refill with water after the third flush allowing gas to escape back into our house. My plumber is baffled and I'm afraid to purchase another...
If you already have your answer to this disregard.
Are you saying that the old toilets and the new ones all did or are doing the same thing?
If yes are they installed on the same DWV (drainage waste and vent) plumbing system as the old ones?
How many toilets are we talking about?
Are any of the problem toilets set back to back in two bathrooms with a common wall?
Mar 11, 2011 | Dmm Mansfield 107 Montclair SmartHeight...
I have two (back to back separated by a wall) Kohler toilets. Model K3589-47. One is always loosing the water in the bowl. It leaks out slowly but always does it. When I flush the toilet on the opposite...
You will need to check the drainage fitting these toilets are draining into. If it is a cross tee fitting without a baffle you are getting throw over across the fitting and it will not stop. The only fix for this is to replace the fitting in your drainage system. In Illinois it is a code violation to put this type of fitting in that application.
When these power flush toilets come out it made this problem worse. In short there is no fix for this problem other than redoing the drainage system.
Feb 10, 2011 | Kohler Home
Installing Washlet toilet seat on Toto toilet
The water supply line on your Aquia toilet was installed before the tank was mounted to the bowl and the tank must be removed to change it.
Jun 02, 2010 | Toto CST414M-51 Aquia Dual Flush Close...
When installing a new toilet. How far from the wall do i need the toilet hole so the tiolet clears the wall?
May 21, 2010 | Home
Looking to buy/install Toto Aquia II in my circa 1964 co-op apt.
When you say 10.5 inches from wall, do you mean that from the center of the drain in the floor to the back wall is 10.5 inches? If so, you need a toilet for a "10 inch rough-in" dimension. The Aquia doesn't come in that dimension. Sorry!
Caroma Sydney Smart model 270 comes in a 10 inch rough-in and is a dual flush model. Note that all dual flush toilets are fairly expensive as compared to normal toilets. HOWEVER, genrally speaking, ALL 10 inch rough-in toilets are fairly expensive just because the low volume that are sold.
Jul 02, 2009 | Toto Aquia II Dual Flush Toilet
What is the diference of 12'' rought or 10''on a installation
if you have a 10" rough in your house you can not install a 12" rough toilet. but if you have a 12" rough in your house you can install a 10" rough you would just have a 2 inch gap between the toilet and the wall.
the rough is measured by measuring the middle of the sewer hole. that your toilett sits on. to the back of the wall this is important because the tank sits behind the toilet. if the tank is too big then the toilet wont fit over the sewer hole.
your house shouldnt have a 10 inch rough unless its about 90 to 100 years old most home's now days go off a 12" to 14" rough.
if you do have an old home you can order any 10" rough toilet at a plumbing supply store. or lowes. they probably wont carry them in stock though because 100 year old houses aren't very common
Nov 15, 2008 | Toto Aquia II Dual Flush Toilet
How to Install Toilet Paper Holder?
I can't unscrew the toilet paper holder from the wall to move it to a different place. There is only one tiny screw underneath, hard to see and it does not move????? appreciate any advice. Thanks.
Aug 27, 2008 | Hansgrohe E & S Accessories 40526000...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
