Question about Baader Planetarium Baader Hyperion Eyepiece - 24mm HYP-24 2454624
Baader Hyperion became dis- assembled as unscrewing from camera. How does it go back together?
The eyepiece is disassembled. I'm trying to work out how it goes back together
After assembly camera lcd displey is still off
Perhaps in disassembly pressure on the LCD cracked the crystal display with will cause a rich black screen. If the camera has both internal and LCD displays, perhaps the switch is set to the eyepiece? My lumix will shut off the LCD and turn on the eyepiece to save battery. Check wires to that switch.
Nov 13, 2014 | Panasonic Lumix DMC-LX3 Digital Camera
The focus knobs wouldn't retract the eyepiece and so in my infinite wisdom I tried to unscrew the whole eyepiece assembly by loosening the 3 screws that appeared to attach it to the main body. Well...
Focusers can be replaced and or upgraded-- you disassembled the focuser-- you will need to reassemble it properly -- you might have also messed up the screw threads in the holes and may need to try using a slightly larger size screws. Your local hardware store will have them.
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
Jul 29, 2011 | Tasco 49114500 Spacestation(r) 114mm...
How do I put together the eye piece
The eyepiece is NOT MEANT to be dis-assembled. If you took it apart no one can tell you exactly how to re-insert the glass elements inside.
Dec 31, 2010 | C-Star Optics STRATUS (UB-3700) Telescope
The lense for my Nexstar 6se was taken apart and I don't know how to put it back together properly. HELP!!
The eyepiece should NEVER BE DISASSEMBLED! Since it has multiple lenses inside no one can tell you how they go back together. This also voids the manufacturer warranty.
Go and buy another eyepiece and NEVER ever disassemble them. Only the OUTSIDE surface ever needs cleaning,
Here is one retailer who sells eyepieces.
http://www.agenaastro.com/
Sep 05, 2010 | Celestron Nexstar 8i Special Edition (480...
What is the lens arrangment in the eyepiece of an 18-1560?
Did you DIS-assemble the eyepiece? If you did no one can tell you how to put it back together.There are so many different eyepieces. Normally the eyepieces just slip into the focuser.
Jun 05, 2010 | Bushnell NorthStar 78-8831 (525 x 76mm)...
My eyepiece lenses need to be reinserted in eyepiece. how do i do this?
Why did you disassemble them? Never disassemble an eyepiece. The exterior surfaces are the only thing that would ever need cleaning.
Two of the surfaces may be flat. Put the two flat surfaces together and try it. If not just reverse the lens.
Oct 21, 2009 | Optics
The tape broke, where can i bring to get fixed so that i don't lose the film i recorded?
I think you can take it to anyone that deals with video tape even some camera shops will splice video tapes back together. You could even do it your self by carefully disassembling the case of the video tape and taping the two broken ends back together with scotch tape if the two ends are ragged you should cut a small amount off to square the ends up and make sure you apply the scotch tape to the side of the video tape that doesn't contact the head of the video player. And remove all the slack before re-assembling. If you are afraid you might mess the tape up try dis-assembling one that doesn't have any video on it for practice to see if you can do this and you can use the one you dis-assemble as a guide.
Oct 02, 2009 | Fuji DVC-80 Mini DV Tape
Trash inside my monocular
Blow it out with canned air-- if the lens is dirty follow these instructions--
http://www.televue.com/engine/page.asp?ID=143
May 08, 2009 | Tasco Specialty 25x30 1AGST Brass Spyglass...
I have a fuji finepix s7500 and zoom error. I dont have warranty so I tried to fix myself. I actually found the problem with the zoom. now I am trying to put it back together and I cant figure out where...
The trick is remembering how you dis-assembled so you can re-assemble.
Purchase or borrow another camera and photograph each step.
Buy a plastic tray with little compartments in and start at 1 end and then work back when assembling.
service manuals from "Flying Dutchmen Plaza" on ebay will show you how to fix
Dec 29, 2008 | Fuji FinePix S700 Digital Camera
Baader Planetarium Baader Hyperion Eyepiece - 24mm HYP-24 2454624 Logo
Top Baader Planetarium Optics Experts
james laughton
james laughton
ray gallant
Are you a Baader Planetarium Optic Expert? Answer questions, earn points and help others
