Question about Samsung Vacuums
Over heating while cleaning - Samsung Vacuums
  • 3 Answers
There can be 3 reasons
1. The main dust collection receptacle is full. Empty it
2. The filter in between the receptacle to the machine is clogged. Take it out and wash it. Ensure it is dry before fitting it again as this is the inlet and must not be wet.
3. Look for a clip on attachment from where the air exits. Open this and clean the sponge and filter. I usually take it out and wash it squeeze out the extra water before using again. Since it is the outlet, it doesn't matter if it is damp when refitting.
I would advise that you take a picture before pulling it out so that you place the rubber gasket, sponge and filter in the same sequence as before after cleaning them. Happy Cleaning!!!!
Posted on Aug 15, 2014
My shark steamer is foaming and no steam is coming out
You cant put soap in the steamers, only water. Clean out water container and start new. Also, clean hole where steam comes out with something thin. Make sure it is heating up enough to produce steam, otherwise heat assembly is broken.
Mar 08, 2017 | Shark Vacuums
How does water heater function on bissell pro heat 1548 carpet cleaner work
It adds heat to the fresh water as it is pumped out on the floor. It will NOT heat cold water enough to clean the carpet. You have to put hot water in the clean water container.
Jul 28, 2016 | Bissell Vacuums
I have a Bissell preheat 2x which I have had for about 4 years. The cleaning solution and the water doesn't come out when I start to clean my carpet. I've unplugged the holes and cleaned the cleaner a
Clean the filters? Check your- User's Guide for locations. Or Contact Consumer Care at 1-800-237-7691
Filters are usually located under the Clean Water Tank Cap (looks like a screen) and The Flow Indicator Cap. Hope that helps.
Sep 09, 2014 | Bissell Vacuum Pro-Heat, Pro-Heat 2 6960W...
Soap mixing with water on bissell pro heat 2
Filter clog problem. Check your User's Guide for filter cleaning.
Jul 04, 2014 | Bissell Pro Heat Deep Cleaner Model 25A3,...
My Hoover Steam Vac model f5915-900 no longer heats the floor to reduce drying time. I have cleaned the bottom of the machine where it says "heated cleaning." Anything else I can try? Thanks.
The SteamVac blows warm air from the motor into the carpet to help loosen oily types of soil. If the motor is running, the air will be exhausted. This system is not meant to reduce drying time, but only to enhance cleaning.
Jun 07, 2011 | Hoover Vacuums
The water heats slighty but no steam comes out
Your heating element is damaged, or more likely has scale (lime, calcium, etc) built up on it. See your user manual for instructions on how to clean. If cleaning doesn't help, then it may be time for element replacement, or unit replacement.
Aug 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Want to use Bissell Pro Heat 2X Clean Shot. Have
You can download a user manual from the Bissell website
Sep 15, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
The vacuum is heating up
Could the tube filter need cleaned or changed? Mine over heats when I neglect to clean the tube filter.
Apr 04, 2009 | Eureka 4885 Bagless Upright Cyclonic...
Vacuums Logo
71 people viewed this question
Top Samsung Vacuums Experts
woodzowl307
ray gallant
Are you a Samsung Vacuum Expert? Answer questions, earn points and help others
