Question about Electrolux Washing Machines
E2 error is showing on my Electrolux top loading machine
  • 44 Answers
SOURCE: Error E2
A model number always helps when you're looking for help. ;)
I looked through about twenty manuals looking for an answer for you; I suggest that you'll have better luck if you have the model #.
Here's the link to the many, many, many Daewoo washer manuals.
WashingMachine&cpage=1">http://www.dwe.co.kr/english/support/download.asp?class1=5&class2=19&class3=0&selorderby=1&searchpath=WashingMachine=>WashingMachine&cpage=1
Good Luck!
Posted on Aug 08, 2009
SOURCE: E2 error on homemaker washing machine.
I have an E2 error on the display of a homemaker washing machine model no HMWM8000. It will not pump out. The PCB does not have any visibly damaged components, which part is faulty, and how do i test a water level sensor.
Posted on Nov 08, 2009
6ylucy
  • 742 Answers
get the manual at manualfox.com
Posted on Jun 18, 2010
ZJLimited
  • 17970 Answers
SOURCE: Electrolux front loading machine shows
E40: Door open, Interlock, wiring or main PCB failed.
Posted on Jun 10, 2011
  • 6277 Answers
SOURCE: I have a hier (semi-automatic)
Hi Asif from retired Englishman in SW France,
Haier 'E2' states 'drainage error- water not emptied within 4 minutes'.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 31, 2011
What is the meaning of EL error code in electrolux top load washing machine?
Please refer this link and you will get all the information :- https://removeandreplace.com/2015/05/05/washing-machine-error-codes-front-and-top-load/
Apr 04, 2018 | Electrolux Washing Machines
What does E2 error mean
Generic pump error
Error Code-control panel display "Err2" (Error 2, Error2) ' question ...
www.haier.com/za/help.../washing_machine/.../question/.../t20140313_209219.shtml
  1. Cached
  2. Similar
Mar 13, 2014 - Error message:Drain error, water can be not drained fully within the required drain time (controlled by PCB software). Reason 1. Pump filter is blocked. Solution 1. Please open and clean the pump filter. (Filter access door is on the bottom right, at floor level of the washing machine). Step 1.Push a flat blade ...
How To Fix Maytag Washer Beeping And Error Codes E2 and F3 Front ...
9k=? 5:23 https://www.youtube.com/watch?v=by94vOVmmhQ
  1. Similar
Mar 18, 2017 - Uploaded by Nancy Gurish How To Fix Maytag Washer Beeping And Error Codes E2 and F3 Front Load Washer Stopped, Repair Of ...
Washing Machine Error Codes - Front Load and Top Load Washers ...
https://removeandreplace.com/.../washing-machine-error-codes-front-and-top-load/
  1. Cached
  2. Similar
May 5, 2015 - F9 followed by E1 - (drain pump system error) F5 followed by E2 - (door will not lock) F7 followed by E1 - (motor drive error) "rL" - (remove load) Washer making error beeps - Door has not been opened and closed for at least 3 cycles. Washer beeps when HOLD TO START is touched - Door not closed
Mar 22, 2018 | Washing Machines
My Toshiba washing machine model AW-A800MBK This have 4 LED lights, Now machine running some time drain and showing LED 2,3 glowing and then machine stop, What is the problem with this machine?
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times. E2 error code aw 8990st toshiba wash Washing Machines
Mar 13, 2018 | Washing Machines
Sharp es 950 top load washing machine as on same time beeping and showing e2
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Error code details to washing machines are given.
Dec 07, 2015 | Washing Machines
E2 error code aw-8990st toshiba wash
E21: Lid open
E31: Load imbalance
Hope this helps
Jan 25, 2014 | Washing Machines
I have an error code "EF" for my Electrolux
Generally, EF error is showed with an additional number on your display... EF 1, EF 2, EF 3, EF 5, EF8, or EBF.
Each error code will depict a different cause and solution. Out of these solutions, the most common is the control board and possibly the UIB (User Interface Board), or too higher mains voltage coming into the house, causing damage in this UIB device.
Test and check voltage, if this isnt solve it, relace UIB device.
Hope this helps.
Mar 05, 2012 | Electrolux EW1200i Front Load Washer /...
E2 comes up once cycle is selected what and how do I fix this?
This machine is very problematic. I had the E2 Error as well. The problem, like dddd501 said, is with the spring in the left hinge of the top lid. It probably gets loose after some use. I solved this, after many trial and errors by wedging a piece of thick cardboard in the gap between the top lid and the surrounding machine in such a way as to PUSH the top lid BACKWARDS into the direction of the control panel. This, I presume, will force the spring into whatever sensor that detects the top lid is closed and removes the E2 message.
Hope helps.
May 14, 2011 | Haier XQJ50-31 Top Load Washer
Error codes for Electrolux front load washer EWF 1087
E40 error is door interlock faulty, could be the lock or it could be the pcb u have to test them.
May 21, 2010 | Electrolux EW1000i Front Load Washer
How do I stop the error E2 code on my washer? I
The E2 shows that there is a motor problem. This can be caused by having an extra heavy load in the machine so take some out and try it. It can also be cause by any iof the buttons being stuck so make sure they are all 'free'. If this fails then you will need to have a new motor and call a repair man unless you can do the job yourself.
Sep 11, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Power cuts off
The machine beeps E2 all the time. Actually E2 error code means washer door is not closed properly. However washer door does close properly, but the machine still beeps with showing E2 error code. Please help solve this problem.
Many thanks,
Robert
Jul 04, 2008 | Haier XQB60-91AF Top Load Washer
Washing Machines Logo
110 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
