Question about DeLonghi CTO4003 4Slice Toaster
Works one side, other side trips out the electric in the kitchen
  • 22 Answers
Stop using the other side.
Posted on Nov 07, 2014
Why don't the left side burners work?
call a repairman or someone that knows how to check continuity and ohms and volts with a voltmeter
Jun 22, 2015 | Whirlpool GR460 Electric Kitchen Range
Oven wont heat up
If only the oven portion fails to heat up then you have a bad control board. If the entire range does not work then you could have a circuit breaker tripped or bad wiring in you house. If the circuit breaker is not tripped then you will have to pull out the range and measure voltage on the power outlet. If there is voltage there on both legs (120v on two sides) then your problem is the range.
Aug 03, 2012 | Creda C361E Electric Kitchen Range
Can you connect the electric side of the cooker to a household plug
You will need to work out the current rating of the electric side of the range. If this is less than the current rating of the household outlet you can. If you set it up this way and it works the only problem that will occur is when you turn one or two other kitchen appliances on. The circuit will probably trip. The circuit for the oven element is normally a dedicated circuit, on it's own.
Feb 11, 2011 | Belling Solitaire G756 Gas Kitchen Range
Electric stove elements stopped working
Circuit breaker is tripped duel breaker 1 of them is tripped, maybe an electrical problem causing this.
Feb 20, 2009 | GE Kitchen Ranges
Electric tripping
There is no way to boost the amount of electricity to your kitchen, short of having an electrician run additional outlets on a new circuit. It sounds like you have too many appliances plugged into one circuit. Most kitchens built since the adoption of building codes have two small appliance circuits, usually on opposite sides of the room. Try moving the electric kettle across the room. If that doesn't work, try unplugging or at least not using the toaster, toaster oven, electric griddle, coffee maker, microwave, or other high demand appliances at the same time.
Feb 17, 2009 | Bosch Kitchen Appliances - Others
Trips out electric
check the wireing on the oven supply line check the breaker it may bu too small or week check ehere the cord is attached to the range most of the time this is where the promblem is
Feb 18, 2008 | Belling 644 Electric Kitchen Range
Fuse tripping
This usually means an earth fault, probably a faulty element
Aug 25, 2007 | New World 60ECHDGm Electric Kitchen Range
DeLonghi CTO4003 4Slice Toaster Logo
188 people viewed this question
Top DeLonghi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Shehu Pro
Shehu Pro
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
