Question about Hotpoint NVL333EY Electric Dryer
Kenmore Elite HE3 Gas Dryer - Heat flame will not ignite
I have a Kenmore Elite HE3 Gas Dryer model # 110.92822102 the heating flame will not ignite. The coil turns bright red. I was lighting and then immediately going out. Now it won't light at all (no flame) but the element turns red. Any idea on what could be wrong.
Incidently I tried disconnected the vent pipe to see if that was impacting it and had the same result. I cleaned all lint out of everything, pipes, took the vent components apart and cleaned everything out.
Very frustrating.
  • 6,784 Answers
The Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
Posted on Jun 20, 2009
He3 gas dryer not heating
thee a lot compenents in the heat circuit it could be any one of them , starting with the thermal fuse,thermostat, safety valve ,glow bar, and flame sensor
Apr 30, 2014 | Kenmore Elite HE3 Steam 8674 Dryer
http://homeguides.sfgate.com/troubleshoot-kenmore-elite-gas-dryer-wont-heat-77443.html
Apr 30, 2014 | Kenmore HE3 Gas Dryer
Kenmore Elite HE3 not heating up when vent connected
check outside of house for any obstructions to the outlet. make sure the vent is clean
Jan 02, 2013 | Dryers
My Gas Dryer has stopped heating. I've checked the breakers and reset them...if the thermal fuse is bad, will the drum still turn and dryer run but not produce heat? I thought I had read that the dryer...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 07, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
My Kenmore Elite HE3 gas dryer does not heat up? What do I do?
Hi
Thanks for using FixYa. The first thing that should be checked is the Thermal fuse which is mounted to the exhaust duct inside the back cover. If this fuse goes bad the dryer will not heat and you’ll have to replace it as it cannot be repaired. If this is fine then you’ll need to check the thermostat, igniter and coils. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
My kenmore elite he3 dryer has quit heating could it be the heating element and if so where can i find it on the dryer? The model # is 110.82822103 and the serial# is MR1751757
heatman101
Jun 05, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore elite dryer no heat
You may want to check if the heating element needs replacing. Most Dryers have 2 heating elements that are found by taking the back off, some of the newer dryers have 3.
Jun 08, 2009 | Kenmore Dryers
HEAT FLAME COMES ON FOR ABOUT 10 MINUTES AND THEN GOES OUT
Look inside the door and get me the model number. May be the gas control solenoids need replaced. Let me know, Sea Breeze
Mar 22, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer not heating he3 kenmore elite
repl/ thermal fuse if no heat if heating for a little while clean exhaust, and repl/ coils
Dec 20, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Hotpoint NVL333EY Electric Dryer Logo
415 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
