Question about Toshiba TEC B-572 Printer
How to calibrate toshiba b572 - Toshiba TEC B-572 Printer
I am using a tec b572 in Win7, it prints fine except after the first label the print creeps up the label, so they aren't centered
As a metter of fact, yes there is a cell detecting the gap.
You must turn the Green knob so that the detecting cell is on the notch. You must program the height of the label and in the driver you must give the size of the notch in the Support Tab.
D'ont forget to alse specify if it's direct or thermal transfer.
Jul 30, 2014 | Toshiba TEC B-572 Printer
To stop auto calibration in toshiba color mfd
Better not to turn off the calibration, otherwise it will cause other errors.
If your colour printing is less than 5% ration, perform following. Turn the code 08-2692 "Prevention of color toner low density / ON/OFF setting" to ON, and then set number of sheets to be judged at the code 08-2693 "Prevention of color toner low density / Judged
number of sheets setting".
08-2693 u can put higher value such as 20 or above to delay the colour calibration.
Mar 25, 2014 | Toshiba E-studio 2330c 2830c Color...
I cannot calibrate brightness
Plugged in or on battery power? If you need to Increase brightness, open Power Options in control panel. It would be helpful if you posted the Toshiba Model and the OS you are using. Without knowing the OS I will provide a Win 7 solution: http://windows.microsoft.com/en-us/windows7/how-do-i-make-the-display-on-my-laptop-brighter Depending on your Graphics Adapter, you can override the OS Graphics settings.
Mar 18, 2013 | Toshiba Satellite Computers & Internet
Toshiba 3511 color print problems
Hope it's not the calibration. This could happen due to transfer belt timing problem. There are sensors and reflectors inside the transfer belt assembly. They may be dirty. Clean them or replace the transfer belt if required.
Oct 03, 2012 | Toshiba E-Studio 3511 Color Copier
Toshiba e stodio 230 tach penal is nat warking
Try to calibrate the panel by perform by entering 08 mode.
(Hold 0+8 key & ON machine)
Enter "692", calibrate the panel.
Jun 13, 2012 | Toshiba e-Studio 232 Black and White...
Es 450 toshiba copier administrator password
Perhaps your touch screen need calibration? Try calibrate your touch screen. (08-692)
May 27, 2012 | Toshiba E-STUDIO 450 Copier
I have a Toshiba 281c and a few days ago the display started acting up. Now when you power up the machine the display lights up but has no text or menus on it. You can't change the functions it is stuck on...
try to enter service mode by pressing 08+power on
enter code 1501 you will see 2 sighns "+" on display
by using plastic stick you can calibrate your display
just touch this "+" jently
then wait few seconds till calibrating process
Good luck!!!
Mar 13, 2011 | Toshiba E-studio 281c Copier
Barcode printer type: TOSHIBA SX4 sensor setting for thermal transfer / transmissive error msg paper jam. how to see the sensor?
Diagnostic boot
Feed PAuse button pressed and switch on Keep button prressed until message (1)Diag ...
with feed goto 5 sensor adjustements.
Pause to enter the menu
select the sensor you want to calibrate!.
Feed or restart button for 5 seconds until a star appears.
Switch off and on the calibration is stored in Eprom
Feb 10, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
I need to calibrate the touch screen
Press & hold the "0" and "8" key, on machine to enter 08 mode.
Type "692", calibration screen will pop out, calibrate the 2 points and restart machine.
Nov 08, 2010 | Toshiba e-Studio 202L Copier
B572 Tec
Normally the printer does not need an upgrade only the software driving it.
If your software uses a windows driver then download the latest driver at this link. DRIVER
Jun 23, 2008 | Toshiba TEC B-572 Printer
Toshiba TEC B-572 Printer Logo
56 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
CheckitRight
CheckitRight
matt
matt
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
