Question about Zebra P330i Thermal Card Printer
Need to print bank notes, which paper do I use?
What do I have to do if I forgot my password for online banking. I need to print out my statement
When you are trying to login, there is a link to 'Forgot Your Password?' - you only need to doink it and follow the security verification instructions ... PNC Bank
Feb 05, 2015 | AccessData Password Recovery Tool Kit (ftk...
Disable paper source kodak esp c315
you can stick the check in letter size using soft adhesiveness tape as paint tape.
print a sample in a plain paper to know the place where you have to stick it...
Nov 15, 2011 | Cameras
Can not get printer to print information that on top to be copy on bottom of same page.
  1. Select 'Properties' from the Print dialog.
    Note: Properties may be indicated as Advanced, depending on the application software.
  2. Click the Page Setup tab.
  3. In the Printing Type section, select 'Normal-size Printing', 'Fit-to-Page Printing', 'Scaled Printing', or 'Page Layout Printing'.
  4. Select 'Duplex Printing'.
    Note: When a media type other than Plain Paper, Photo Paper Plus Double Sided, or Postcard is selected in the Media Type menu, duplex printing cannot be performed.
  5. Specify Staple Side.
    1. The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position.
    2. Click the Staple Side drop-down arrow and select the setting. If you want to change the setting, select another value from the list.
    3. If necessary, click Specify Margin... and set the Margin width
  6. When the setting is completed, click the OK button at the bottom of the window.
    Note:
    If a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
    The document will be printed on one side of a sheet of paper when printing starts. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
    If Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
    The document will be printed front and back alternately for one sheet at a time, when printing starts. Load the paper according to the displayed messages.
  7. You will be prompted, while printing, to remove the printed page and reload it in the ASF.
  8. Dependent on the number of pages to print, you will need to repeat step 7 until all pages have printed.
Feb 10, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I am getting an error when I am trying to print checks from Quickbooks on my HP C6100 printer. The error is "Paper mismatch: paper size or type is incorrect". I believe these printers have some...
There is good reason to use the proper paper to print checks. If you do not, the machines at the bank may not read them correctly, they will not have watermark to prevent fraud and if they are not the correct weight, they will get clogged in the equipment at the bank processing center.
You can go to
Start
Control Panel
Printers
Right click on the printer in question
Printing Preferences
Paper/Quality
(Plain Paper) This is a pull down menu with all styles of paper. You can change to the paper that you are using and change other settings as well.
If you have any other questions let us know. Good Luck.
Dec 31, 2010 | Office Equipment & Supplies
Does not feed paper
Please follow the steps to fix your problem
Solution one: Reset the product
  1. Press the Power button (c01602202.gif ) to turn on the product.
  2. With the product turned on , unplug the power cord from the back of the product.
  3. Disconnect the power cord from the wall outlet.
  4. Wait at least 15 seconds.
  5. Connect the power cord to the wall outlet.
  6. Connect the power cord to the back of the product.
  7. If the product does not turn on by itself, press the Power button (c01602202.gif ) to turn it on.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Check the condition of the paper, and then reload it
  1. Replace any ripped, dusty, wrinkled, or bent paper.
    NOTE: Use only plain, white, unused paper in the product until you resolve the issue.
  2. Make sure that all of the paper in the tray is the same size and type. Never load mixed types of paper at the same time.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper has at least 10 sheets and no more than 25 sheets of paper.
    NOTE: Do not load too much paper into the product.
  5. Insert the stack of paper into the product, and then gently push the paper guides snugly against the paper. Make sure that the paper is fully inserted into the product.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time. Then try printing again.
Solution three: Adjust the paper settings in the print driver The paper settings in the print driver must match what is loaded in the tray.
NOTE: These changes do not change the default print settings. The print settings return to default the next time the program opens.
  1. Open the document that you were trying to print when the issue occurred.
  2. Click File , and then click Print . The Print dialog box opens.
  3. Click the button that opens the Properties dialog box. Depending on the software program, the button might be Properties , Options , Printer Setup , Printer , or Preferences .
  4. Click the tab that provides paper type and size settings. The tab might be Features or Paper/Quality .
  5. From the Size is drop-down menu, select the paper size that matches the paper in the tray.
  6. From the Type is drop-down menu, select the paper type that matches the paper in the tray.
  7. Click OK , and then click OK again to print the document.
NOTE: If the issue is resolved, and you want to print on another type of paper, load the new paper type, and then repeat the previous steps for the new paper.
May 18, 2010 | HP DeskJet 648c InkJet Printer
Ibm 6400
This is a easy problem... Have any question call 972-907-9771 x311
51e9bbd.jpg ATTENTION Hammer springs and hammer tips are fragile. Do not touch the hammer springs or tips. Handle hammer springs by the
thick mounting base only. Apply pressure only to the mounting base.
NOTE: Replace a hammer spring assembly only if there is visible damage or broken parts can be seen in the assembly.
5. Remove the mounting screws from the old hammer spring assembly. (See Figure 18, page 367.)
6. Handling the hammer spring assembly by the mounting base only, gently pry the old hammer spring assembly off its
mounting pins. (See Figure 18, page 367.)
7. Inspect the hammer bank and the old hammer spring assembly:
a. If there is ink on the hammer bank mounting surface, the hammer spring assembly mounting surface, or the hammer
spring neck or tines, reinstall the old hammer spring assembly and replace the shuttle frame assembly (page 405).
b. If the old hammer spring assembly and the hammer bank are free of ink, install the new hammer spring assembly
Installation
1. Using a clean dry cloth, wipe the hammer spring mounting surface on the hammer bank. Make sure the cloth does not
leave lint on the hammer bank.
NOTE: Replace a hammer spring assembly only if there is visible damage or you see broken parts in the assembly.
2. Handling it by the mounting base only, remove the new hammer spring assembly and mounting screws from the box.
3. Handling the hammer spring assembly by the mounting base only, carefully position it on the hammer bank mounting pins.
then gently press the mounting base down against the alignment pins. (See Figure 19, page 369.)
4. Continue pressing down on the mounting base of the the new hammer spring assembly as you install the mounting screws
from the replacement kit. Using a Torx T-10 bit adapter, torque each screw to 14 inch-pounds (1.58 N•m). Tighten the
center screw(s) first. (See Figure 19, page 369.)
NOTE: Use the 1-30 inch-pound Torque Screwdriver, IBM part number 16F1661.
5. Install the hammer bank cover assembly (page 354).
6. Install the shuttle frame assembly (page 405).
7. Install the ribbon and load paper.
ATTENTION Do not attempt to adjust or “tweak” hammer springs.
8. Run an operator print test and check print quality (page 223):
a. If print quality is acceptable, return the printer to normal operation (page 339).
b. If print quality is still degraded, replace the shuttle frame assembly (page 405).
Sep 10, 2009 | IBM 6400 Matrix Printer
Trouble printing a thicker form
I have come accross this problem on a number of sites. It may be the Paper Out sensor. It works by emitting light from one half of the sensor reflectiong it of the paer and picking it up with the other half of the sensor. When no paper is present, the light cannot reflect and hense a paper out error is reported. I have seen this error occur when paper with dark backing ( like that for bank and tax forms ) is used.
Aido
Jan 09, 2008 | IBM 6400 Matrix Printer
Cannon MP160 How to Print both sides of the Paper???
Set Duplex Printing (Windows) For details on how to set duplex printing, see below: 1. Select 'Properties' from the Print dialog. Note: Properties may be indicated as Advanced, depending on the application software. 2. Click the Page Setup tab. 3. In the Printing Type section, select 'Normal-size Printing', 'Fit-to-Page Printing', 'Scaled Printing', or 'Page Layout Printing'. 4. Select 'Duplex Printing'. Note: When a media type other than Plain Paper, Photo Paper Plus Double Sided, or Postcard is selected in the Media Type menu, duplex printing cannot be performed. 5. Specify Staple Side. 1. The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. 2. Click the Staple Side drop-down arrow and select the setting. If you want to change the setting, select another value from the list. 3. If necessary, click Specify Margin... and set the Margin width 6. When the setting is completed, click the OK button at the bottom of the window. Note: If a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab: The document will be printed on one side of a sheet of paper when printing starts. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side. If Photo Paper Plus Double Sided is selected for Media Type on the Main tab: The document will be printed front and back alternately for one sheet at a time, when printing starts. Load the paper according to the displayed messages. 7. You will be prompted, while printing, to remove the printed page and reload it in the ASF. 8. Dependent on the number of pages to print, you will need to repeat step 7 until all pages have printed. Back to Top
Sep 10, 2007 | Office Equipment & Supplies
Zebra P330i Thermal Card Printer Logo
19 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
