Question about Aastra Telecom 9120 Corded Phone (aastraa1263)
Aastra 9120 call forwarding
How do i turn on call forwarding
3 Suggested Answers
ButtFuzz
  • 463 Answers
SOURCE: AAstra 9120 - i am currently using only one line. how do i get
Turn phone upside down and look for a little ***** switch that says 1 -- 2 -- 1+2 and slide it to the "1" position.
Posted on Mar 13, 2009
  • 183 Answers
SOURCE: I am only using line 1 on the aastra 9120, how do
i have the same issue. considering the following solution; install a splitter to connect both phone ports to a single line.
Posted on Jan 14, 2012
When someone in office calls my phone the intercom picks up instead of ringing. How do I turn that off? we use the NEC 80 version 2.25
The phone people in the office should be able to turn off call forwarding and auto answer
Call Forwarding
Call Forwarding - NECDSX.com
www.necdsx.com/dita/features/call_forwarding/call_forwarding_feature.html
  1. Cached
  2. Similar
Call Forwarding permits an extension user to redirect their call to another ... in the Call Forwarding programming mode - the same as pressing INTERCOM and ...
Jul 29, 2016 | NEC Lands Phones
How do shut off call devirter
Turn Call Forwarding Off from the Device ' Verizon Wireless
www.verizonwireless.com/.../knowledge-base-17268/
Verizon WirelessIf you're not receiving calls, callers are not getting through (e.g., fast busy signal, ...calls after turning off Call Forwarding, check additional settings (e.g., Do Not ...
Turn call forwarding on or off - Sprint Phone Connect 2
support.sprint.com/.../Turn-call...off.../WScenario_54...
Sprint CorporationTurn call forwarding on or off - Sprint Phone Connect 2. Last updated: Oct 12, 2013. article View all tutorials. Did this solve your problem? Explore Device. Calls.
Call Forwarding (*72) - Bright House Networks Support
Dec 12, 2015 | Cars & Trucks
How do I cancel I am here from the station I set it up (mitel phone) or from the station I had forwarded (analog)?
If you forwarded the analog to the digital you probably used a feature access code. So this code will either turn it off if entered into the forwarded phone. Or there is a call forward cancel fac that would turn it off. There may be a clear all features code that programmed that would cancel the forwarding as well. All of these options would need to be dialed from the forwarded (analog) phone.
Apr 08, 2015 | Mitel Superset 4025 Corded Phone...
Mobile phone Nokia 311 - Call forwarding is get activated want to deactivate but not able to do.
Hi Shailesh,
I have steps below on how to turn it on and since your concern is to turn it off please do the vice versa. Hope it helps.
Forward calls to your voicemail or another phone number Your phone is ringing, but you can't answer? Let the call go to your
voicemail, or forward it to another number. Call forwarding is a
network service.
1. Select settings > calls > call forwarding.
2. Select when to forward the incoming voice calls:
all voice calls - Forward all calls.
if busy - Forward when busy.
if not answered - Forward when not answered.
if out of reach - Forward when the phone is switched off or out of
network coverage for a certain length of time.
if not available - Forward when busy, when not answered, when the
phone is switched off, or when out of network coverage.
3. Select activate > to voice mailbox or to other number.
4. If if not answered or if not available is selected, set the length of
time after which a call is forwarded
Nokia 311 User Manual Page 30 Forward Calls To Your Voicemail Or...
May 02, 2014 | Nokia Asha 311 Mobile Phone - Unlocked Red
Gear alignment on outboard motor
When the gear box ix in forward, it should make a ratcheting noise when rotated forward and should not turn at all when turning in reverse (or be resistant as your back spinning the water pump -don't do that) Once in gear (forward ) you should be able to mate the shift to the motor. I have removed the prop and nut and used a remote start to spin every thing together, but requires a lot of safety precautions.
If you are working on an older mercury, that shift rod can work both ways with disastrous results if you over spin the shifter to the back side of the detent.
Sep 17, 2012 | Boating
Call forward will not turn off, have tried *74 & *73 , have rebooted and turned off then on, call divert symbol still on and phone calls still diverted.
To set Unconditional Call Forward ON Dial "*72" for a dial tone. Dial the forwarding number followed by "#". Wait for dial tone. LCD will display "Call FWD Activated"
To Cancel Unconditional Call Forward: dial "*73" and get the dial tone, then hang up. LCD will display "Call FWD Activated
but, since you have tried those two, it could be that there might still be a different type of call forward option that is still ON, on your phone like Busy Call Forward and Delayed Call Forward 1. To Cancel Busy Call Forward: dial "*91". Wait for dial tone. Hang up.
2.To Cancel Delayed Call Forward: Dial "*93" for a dial tone, then hang up.
Let me provide you a link to the website which I used as a reference for your future reference.
http://www.grandstream.com/user_manuals/GXP_User_Manual.pdf
Apr 27, 2011 | Grandstream GXP-2000 IP Phone
Flywheel won't turn forward
You must have a small piece of thread stuck in the raceway that is probably why you can turn the balance wheel backwards but when you turn it forwards it jams again.
Jun 08, 2010 | Bernina Bernette 75
How do I divert calls to a mobile number and then undivert calls
pickup the handset (phone... watever) and press the FWD/DND button then press #2 then type in the number of the mobile (or number you want to forward to...), and hang up the phone... then when your finished with the call forwarding function, press FWD/DND again and this time press #0
What 2 does it turn on the call forwarding feature
. and 0 turns off forwarding/do not disturb functions
theres 5 different functions after you press FWD/DND
0: turns FWD/DND off
1: put the phone into Do Not Disturb Mode
2: call forwarding
3: Busy-Forwarding.. which means if your on the phone and someone rings, it forwards them to the number you specify
4: No Answer- when you don't answer the phone if forwards the caller onto the number you type in
and lastly 5: Busy/No Answer- does both function 3 & 4
i hope i've helped
, Cameron
Jan 22, 2010 | Panasonic KX-T7630 Corded Phone
How do you turn off phone forwarding? Somebody inadvertently has their phone forwarding to another extension. Lucent Partner 18d.
It depends on the kind of telphonesystem and the kind of forwarding.
Generally the procedure is #code# where code is
21 for call forwarding unconditional
61 for call forwarding on no reply
67 for call forwarding when busy
On most mobile operators you can do #002# or ##002# to take the all in one go.
On some fixed (analog/PSTN/ISDN) lines you can use #001# to take them all inone go.
Some PABXes(officephones) also have call forwarding on precense (lunch, meeting. etc) and this is often turned off with #23#
Apr 01, 2008 | Lands Phones
Aastra Telecom 9120 Corded Phone (aastraa1263) Logo
51 people viewed this question
Top Aastra Telecom Lands Phones Experts
Illimar Saatvali
Illimar Saatvali
Jose Ma DM.
Jose Ma DM.
Michel Laprise Sr
Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
