Question about Cobra 29 LTD CB Radio
My cb motorola can't receive from other cb radio
  • 41 Answers
Motorloa has made thirteen models for CB use: CB555,CC975AX,CF925AX,CM540,CR520/21,CT950AX,Motcat40,T4000A,T4005A,T4009A(CB-1135),T4010A,T4020A,T4025A(CB-1136). If you have one of these models, then it is a cb. The model number might not be on the front of the radio, Look on the back of the radio, the model number should be on a plate or sticker. Check the mic. connections at the plug, make sure none of the wires are broken or shorted. Try a different mic. to see if the recieve works, some radios need the mic plugged in to recieve. Check the antenna wire, if it goes inside the vehicle through a door opening, then make sure it is not crushed or broken. Check the wire at the connector that goes onto the radio, make sure it is not broken or loose. Try connecting an external speaker to see if the recieve works. If none of these suggestions help, then you may have to take the radio to a tech and have it diagnosed. Good Luck.
Posted on Apr 24, 2014
  • 32 Answers
Make sure that it is a cb radio and not a business band radio
Posted on Apr 23, 2014
How is it repaired error E-29?
Search Results
    Motorola Spectra FAIL and ERROR Codes
    www.repeater-builder.com/motorola/spectra/spectra-error-codes.html
    Dec 27, 2007 - Motorola Spectra FAIL and ERROR Codes. ... For example, a radioFAIL code may look like this: "FAIL 01/90", where the first two digits ("xx" in the ....FAIL 10/84, Trunking EEPROM blank, Troubleshoot Trunking Option, CB.
    [PDF]How to Use Your Cobra 29 LTD Classic - Cobra Electronics
    https://www.cobra.com/sites/.../manuals/29LTDCLA.pd...
    Cobra ElectronicsBefore installing the CB radio, .... Even though the Cobra 29 LTD Classic has an automatic noise ...... referring to the manual, you still need help, call Cobra ...
Jan 13, 2016 | Radio Communications
Problem no squelch noise or speaker like its muted, but can hear weather ok shows receiving and ant ok
Since the radio cannot transmit on Weather bands, there is no need for the radio to detect if it is transmitting when receiving weather.
In CB mode (on CB channels) the radio will mute when transmitting. So... a guess is that it is muting, or transmitting all the time in CB mode. Check for a mic problem by removing the Mic from the radio ... if it receives CB with no mic connected, then there is an issue with the mic. Otherwise, unless the unit is in PA mode (public address mode) it is likely something internal and beyond the scope of this service.
Sep 08, 2015 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
How do you reset the Talkabout FV700 Two-Way radios?
It is best to contact Motorola Solutions.
http://www.Motorola solutions.com/support
Mark
Motorola Mobility Support
Aug 16, 2014 | Motorola Fv750Rcamo 18-Mile 22-Channel...
My cobra 29ltd will transmit but want receive
three things you need to check the mic must be plug into radio, make sure that the radio is set to cb not pa,check your rf gain is turned all the way up and last of all check the antenna.Now that being said if the radio does not receive you might have to take it to a radio shop.
Jun 11, 2014 | Cobra 29 LTD CB Radio
I have a 148 gtl.. when you tx, there is a loud high pitched tone at the receiving end(receiving radio)...and it is garbled...tried switching radios and when I tx the 148, the other radio had the same high...
how far away are they? It sounds to me like they are in the same room???
If so, you are getting feed back. CB's are not meant to be that close. As well, the also would raise another issue. Are their antenna's hooked up?
CB radio's need a CB antenna or you can damage the radios. The radio energy will not leave the radio and burn up the transmit section of the radio.
the both need an antenna, and the antenna needs to be tuned.
Also, if you are operating them close like that, you can also damage the receive on the radios.
also, when 2 radios are too close, it over loads the receive circuits on the radio ant thats why its garbled.
Nov 12, 2010 | Cobra Radio Communications
Will it work with a cb radio
No. CB's operate at the 27 MHz on 22 predetermined frequencies allowed for Citizen Band radios; and your Motorola XV1100 radio is a VHF 150-170 MHz radio with a set amount of built in frequencies to choose from, designed for business use.
Aug 20, 2009 | Motorola XV1100 (1 Channel) 2-Way Radio
New pair of new motorola talkabout distance dps radios.
can you check the PL or DPL setting on the radio that is all stadic when you receive a call?
The radio is going into monitor mode after a call is received. This is most often a PL or DPL issue.
Dec 08, 2008 | Motorola Talkabout Distance DPS (10...
Great TX no receive
broken wire on mic plug, black wire pin 4 0n mic...doc's cb shop ny
Jul 18, 2008 | Cobra 29 LTD CB Radio
CB RADIO RECEIVING PROBLEMS
You need to supply more information regarding make model type
am / uhf etc.........Cheers
Jun 27, 2008 | Connex 3300 240-Channels Base CB Radio
Cobra 29 LTD CB Radio Logo
113 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
