Question about Makita DCS6401 20 20",64cc Chainsaw 2 Cycle
Spark plug gap opel corsa 1.4 - Makita DCS6401 20 20",64cc Chainsaw 2 Cycle
Opel corsa baklie 1.6 sport 2007di engine light dont com on and dont haf sperk
the signal from the crank angle sensor thats mounted against the block pointing to the crank pulley is what tells the ecu that the engine is turning and to provide spark and injector pulse
so your possible problem area is the ecu
also check the ecu harness plug wires and pins
make sure the crank angle sensor is plugged in
Oct 02, 2016 | 2007 Opel Corsa Utility
O4 opel corsa sml miss when driving I ca say like a power loss than comes right when idling you can see a surge what can it be
probably defective spark wire or spark plug. it could be a bad fuel injector or connection (start with the spark plug wires) rudy perez good luck
Nov 26, 2014 | Opel Cars & Trucks
Why is my 2007 Opel Corsa Lite 1.4i jerking when I drive it? This is not happening every day
have the fuel checked for water or a blockage , injecters also mite need cleaning !
May 28, 2014 | 2007 Opel Corsa 1.2
Opel corsa c
What spark plug wire? A 2008 Corsa has a sealed coil pack connected to all four plugs and bolted to the cylinder head
Apr 03, 2014 | 2008 Opel Corsa 1.4
Makita DCS6401 20 20",64cc Chainsaw 2 Cycle Logo
Top Makita Garden Experts
Jim Parker
Jim Parker
JOHN LAPIER
Are you a Makita Garden Expert? Answer questions, earn points and help others
