Question about Samsung LNT4066F 40 in. LCD Television
When I turn on my tv it shuts off and on and when it finally comes on there are all these vertical lines of color with no picture but you can still here the sound
I have found through my research that the problem is most likely Back Light Inverter board or the P/S board. The P/S board Circuit Card Assembly or P/S CCA as I call them in my line of work, provides the correct voltages to the Back Light Inverter. The Back Light Inverter CCA then provides the correct brightness and contrast required on the screen. I am almost certain it is either one.
Posted on Oct 15, 2009
This is with the sam sung t4066f cannot see picture but can here the sound
Posted on Jun 24, 2009
4 Suggested Answers
lukster
  • 217 Answers
SOURCE: vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Posted on Aug 03, 2008
ProMonkey
  • 59 Answers
SOURCE: colored vertical lines with sound no picture
im afraid to say that your display has gone the best thing you can do is call the supplyer of the tv if its under warranty or call samsung. the cost of a new display will be 400 - 500 pounds so you may have to buy a new set.
Posted on Mar 10, 2009
SOURCE: Turn on Samsung LN-T4665F and vertical colored
when I turn the modelLN-T4661F TV on it just clicks and clicks any help how to fix it.
Posted on Nov 29, 2009
Sony bravia KDL-50W800B got only vertical lines when turn on.
You need to take it to a TV repair service, preferably one that specialises in Sony TV's. There is nothing you can do to fix this yourself.
Jun 16, 2016 | Sony Televison & Video
2004 rear projection daewoo tv problems
No value used, no one wants this old technology anymore.
May 18, 2017 | Daewoo DSJ-5510CRA 55" Rear Projection...
No picture, vertical colored lines
I have never heard of a warm-up problem on a digital television. Unlike the old CRT TVs and monitors, digital panels don't have to warm up. I would go with the TV repair persons assessment that you've got a bad panel.
Jan 04, 2018 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
When i turn it on it has an horizontal blue line in middle of screen then comes on, when shut down it has the colors in the middle in tight formation then suts off. is it the picture tube
the set having blue scteen when the nosignal condition so blue horizontal line due to failure in vertical deflection section and system control detect the vertical delection failure . so system control farce to set to shut down pls repair the vertical section and system should be ok
Aug 26, 2010 | Samsung SlimFit TX-S3082WH 30" TV
Visual transparent lines at top of picture
You have a vertical output circuit problem. This was common for Philips' sets. Have a repair shop check it out. Should not be too expensive to repair.
Oct 15, 2009 | Philips 27PT6441 27" TV
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
Insignia LCD 27" w/vertical lines for picture
Happens with mine also usually happens when you change channels alot all you need to do is shut tv off and turn it back on.
Mar 09, 2008 | Insignia LCDTV26 26 in. Television
Vertical colored lines no picture.
Dec 17, 2007 | Samsung LNT3242H Television
P42W46X Zenith Plasma - No Picture - Mostly Yellow on screen
Mine looks like too, but the line running across isn't on my set, picture looks like this, and the sound works fine. I took the tuner board all the way out and turned the set on and it did the same thing, then I unplugged the top wire on the board next to the tuner board and the screen went black. plugged it back in and the screen came back with the scrambled picture. Anyone know why? Bad mainboard maybe? the left of the tuner board?
Nov 25, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Samsung LNT4066F 40 in. LCD Television Logo
358 people viewed this question
Jerry Greenberg
Jerry Greenberg
