Question about SWANN Home Security
Need extensioncable dc and bnc - SWANN Home Security
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 133 Answers
That cable called RG59
Posted on Mar 05, 2015
Need antenna
This radio has a standard BNC antenna jack. Radio Shack does now offer an antenna with a BNC connector on the end that you can use with this radio.
Dec 03, 2012 | Uniden Bearcat 855 Xlt 50 Channel Scanning...
Hello\r\nI have a kc-2a camera and would like to know what the pinout is? hope you can help thank you K.V
Its RJ11E. If your system doesn't support RJ11E, you can find a adapter at B&H (that's where I got mien) to connect to a BNC DVR. Make sure the camera has the right Power supply. KC-2A use 15V dc... most camera's I have use 12V.
Aug 11, 2011 | Ultrak Kc552bcn Ccd Cctv Color Security...
Need an replacement antenna for my radio shack pro-508 scanner. Radio shack does not carry them anymore
Hi.
Check on eBay. You need a standard BNC connector antenna for this scanner. Radio Shack scanners are made by Uniden so a Uniden BNC antenna will fit your unit.
Here's a link for an antenna on eBay:
http://cgi.ebay.com/UNIDEN-DESKTOP-SCANNER-ANTENNA-BNC-SCAN-3-/220734104369?pt=LH_DefaultDomain_0&hash=item3364c72331
Feb 08, 2011 | Radio Shack Pro-2018 Scanner
Runco DTV-5800-component to BNC connection problem
component cables have standard RCA fitting on the end. you can however but adapters enc to RCA. these work well are are readily available through eBay
May 04, 2010 | Runco DTV-5800 58 in. Rear Projection...
I have a dvd/vcr that does not have a coaxial cable hookup on back of vcr. I need to have my satellite hooked up
If your VCR does not have the coax connection then you should either have RCA inputs and outputs or the BNC type of connections. If you have the RCA style then you can connect your sattelite receiver using them. If you have the BNC type then you may have to contact the manufacturer to see if there are converters available to switch your RCA ends to BNC. You will also have to find out if the BNC connections will even work with the outputs from the satellite receiver.
Feb 02, 2010 | Televison & Video
How many instrument and power cables in one cctv
Hi a simple CCTV one camera system is 1 pair of power wires (1 positive 1 negative) and 1 piece of coax cable with BNC connectors at both ends. (usually rg59 but RG6 is better)
Things to be aware of:
Cameras come in both 12v DC OR 24Vac configurations some are capable of both but most models available to consumers run on 12v most professionals choose 24v models.
simple adapters used to convert from regular coax screw type connectors to either an RCA connector or BNC connector are available at Radio shack. If you need more than 1 or 2 its cheaper to get them on ebay.
You can connect a BNC equipped camera to an input on your TV by using one of these adapters. *put an RCA connector on the end and plug it into one of the yellow video inputs on the TV.
Nov 09, 2009 | Samsung DLP HL-P5663W 56" TV
Can't find satellites
The internal antenna BNC connection (the little steel bayonet that the secures the antenna or extender cable) is a common failure on these units. The threaded retaining ring on the outside of the antenna BNC comes loose when installing/removing the antenna connection, and eventually the BNC rotates and the solder joint inside fails. This happened on mine recently, if you are handy fixing small mechanical parts and a good solderer it is pretty  easy to fix. Remove the batteries, remove all six outer case screws (but not the one with the oval metal plate) and gently pull the housing apart. Check the solder connection of the coax wire to the BNC pin & shield. If it's broken and the BNC is loose in the GPS case, tighten the outer BNC retaining ring VERY tight, add a drop of thin super glue (Hot Stuff or Permabond CyA, etc) to keep the ring/BNC/case mated, then repair the coax solder  connection. Replace all the screws and test it outside. If it's an aviation GPS you would of course have this done by an FAA licensed avionics specialist. Wink wink.
Jun 14, 2009 | Garmin GPS III
I have two samsung ssc-12c cameras.
green wire : 12v dc
clear wire : video ( + )
wire around clear wire : video and 12 vlt ground ( - )
you don't used the rest of wires . rest are audio .
Nov 20, 2007 | Samsung Weather Resistant Security Camera...
Home Security Logo
Top SWANN Home Security Experts
Electro Med Services...
Pierre Legault
Da Doc
Are you a SWANN Home Security Expert? Answer questions, earn points and help others
