How to tune Telefunken pal color MP514 - Televison & Video
How do i check if telefunken mp514 remote is faulty
Many things can go wrong with a remote control but one easy check is to look at the control LEDs using your digital camera or phone camera. Press any of the control buttons and you should see the control LED flash on the camera screen. Try this on a good working control so you know what to look for. If you dont see the LED flash clean the battery connectors first and then try new batteries. If you have got functioning LEDs but no remote operation check that there is nothing in the way of the TV sensor.
Feb 20, 2015 | Televison & Video
When convert PAL-NTSC w/ SV-5000W to Samsung Plasma only B & W pic
Switch through the TV input selector until you find the proper input channel , probably you are using the wrong input.
Oct 28, 2008 | Samsung SV5000W VHS VCR
Telefunken analogue color TV model MP-A2055VT-H to connect up digital decoder set-top box. The TV only has an RF input. no other plugs. Searched all 80 channels and I cannot find an AV channel on the...
The simplest solution would probably be the use of an RF Modulator. Feed the RF Mod with the A/V signals from the Conia CSTB12, set it to transmit on Ch 3 or 4, tune the Telefunken to either channel.
In most Telefunken TVs we have worked on, the A/V INput/OUTput would be on the SCART connectors as shown below.
To my understanding, a Conia CSTB12 as sold in Australia has a composite RCA (yellow) Video OUTput and L/R White/Red audio OUTputs. What would be needed would be a A/V signal to SCART adapter/converter.
If your Conia CSTB12 has an S-Video, then this may be used.
If your Conia CSTB12 has an HDMI, then something like this may be used.
Incidentally, should you be interested, there are comparable receivers to a Conia CSTB12 that has SCART OUTputs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 14, 2008 | Televison & Video
What is the code for telefunken mp514 on the rm-v301 remote?
028,022,026,021.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 04, 2014 | Televison & Video
How do i change the system of bush btv180tsil tv/vhs pal I to pal BG
Just go to its menu option first. There you can change the sound system to PAL B/G, NTSC, andso on. Select the system to PAL B/G first. Then make an auto tune function, All the channels sorted by the TV will automatically tuned and stored in memory with PAL B/G only.
google.com/+GopakumarGopalan
Nov 26, 2013 | Televison & Video
What is the Chunghop RM-88E code for Telefunken mp514 ty?
Try chunghop codes Shrtcut Method: 000 (TOSHIBA), 001(PANASONIC), 002 (PANASONIC), 004 (JVC), 005 (SONY), 009 (AIWA), 012 (DAEWOO), 013 (PHILIPS), 050 (SAMSUNG), 054, 073, 101. Hope one of which is the code. Thanks for using Fixya.
Aug 05, 2013 | Televison & Video
What is the code for a universal remote in order to tune telefunken mp514 tv
These are the universal remote codes for Telefunken Brand TVs: 0031 0000 0001
Try this method, if none of above codes work.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
If you wish to get more details check this.
Dec 31, 2012 | Televison & Video
TELEFUNKEN TDR-100A DVD RECORDER REGION UNLOCK CODE
You do not need a region unlock code for this recorder as it supports both NTSC & PAL
Dec 09, 2007 | Televison & Video
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
