Question about On Stage Stands JBL On Stage IIIP Portable Loudspeaker Dock Remote Control
Opening fo repair
Like to open JBL STAGE III for repair how do I??
Hi. I just bought a new JBL On stage micro III. The problem is that when I put my Ipod on the dock the sound only comes from the iPod and the speaker doesn't produce any sound at all but when I push...
Have you made sure the dock is compatible with the iPod version you have? If you are having to move the iPod around, this may be because the dock isn't built for the iPod you own.
It could also be a technical fault that the dock is loose. Take it/send it back to the shop and explain your problem.
May 06, 2011 | JBL 6-1/2\ Round Coaxial Speaker By...
How can i open the "jbl on stage 400p" for
We just discovered how to break openthis mother. Use a flathead to gently lift the wraparound speaker cover from the lip, and gently work your way around the speaker. Underneath it you'll find a crapload of screws. Then go to town.
Jan 12, 2011 | Harman Kardon JBL On Stage 400P Speaker...
Jbl 1100w amp no sound
a couple of things , there are sometimes fuses at the uput stage internaly or it sounds like you have bown the output stage or output i dont ko if it would be orth repairing as this is the ost xpensive part inside
Jul 20, 2009 | Pyle BZDBP212 Car Subwoofer
Will the jbl on stage micro charge the new ipod touch
I can tell you that I have the on stage micro, bought this past winter. And it does charge my iPhone 3G. Works great, I love it.
Feb 27, 2009 | JBL On Stage Micro Portable Speaker Dock...
JBL on stage II speaker doesn't work
If your 120v unit is not marked for use with 220-240v and you plugged it into such a socket (even once), you probably fried the AC adapter and will need to get a replacement.
Jan 21, 2009 | JBL On Stage Micro Portable Speaker Dock...
Compatability with 4th gen nano
I have had exactly the same problem having bought a JBL Radial Micro for my partner for Xmas for use with the Ipod Nano, i contacted JBL via their website and was advised to contact Harmen on 01707278100. I was advised that the new ipod nano (chromatic) would not charge on the JBL radial micro. They stated that this was due to Apple changing the charging pin in the new nano. I have since bought a JBL Stage III. I contacted Harmen before buying this and was advised that the Stage II would not work. Hope that this is of use.
Sep 26, 2008 | JBL (JBLRADIALWHT) Speaker System, Docking...
On Stage Stands JBL On Stage IIIP Portable Loudspeaker Dock  Remote Control Logo
41 people viewed this question
Top On Stage Stands Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an On Stage Stands Audio Player and Recorder Expert? Answer questions, earn points and help others
