Question about Sony Playstation 3 (PS3) Console
Every time i turn on my ps3 it says "reconfiguring hard disk" and when i press ok, it just restarts the ps3.
  • 48 Answers
Right its ur hard-drive u cant really take it out like xboxers but u should be able to send it off to sony for a short bit of cash :P hope i helped
Posted on Jun 20, 2009
When I turn my PS3 on, it says hard disk file system is corrupted and will be restored, I press OK, it gets all the way to 100%, then it restarts and tells me the same thing. What do I do?
Your HARD DRIVE (aka: Hard Disk), located on the left side of the unit, has crashed. You will need to replace the HD.
When you replace your hard drive, you will need to have the latest firmware on a
usb stick. Download the firmware from the playstation official website onto a usb
stick. Once prompted by your system you will need to insert the usb stick into the
PS3. Good luck..
You will need 2.5" Sata Hard Drive.
Jan 24, 2011 | Sony Playstation 3 (PS3) Console
I was going to play modern warfare 2 when the system turned off and it said " The hard disks file system is corrupted and will be restored" so I pressed ok and it got to 100 percent and restarted...
I want to just make it clear to you, that you can repair the following problems at home with a good repair guide. There is no technical knowledge needed you simply do what you see on the step by step videos or the paper guide.
The best thing is you get to keep your ps3 guide for life so if something goes wrong in the future you can just review your guide and fix it.
click here to download ps3 repair guide
Dec 22, 2010 | Sony Playstation 3 (PS3) Console
What do i do when it says hard disc system is corrupted on my ps3
Ok try to follow these steps in order to restore your hard disks structure again.
Step 1. Turn the PS3 off into standby mode (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it, then beep again 5 seconds later and then beep once more and turn off. When the console turns off, release the power button.
Step 3. Press and hold the power button again. It will beep when you first press it, then beep 5 seconds later, then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4. The PS3 will start up asking you to connect a PS3 connector via USB and press the PS button. Do this and then go onto the next step.
Step 5. A menu will then load. Choose option 3 "Restore File System". The PS3 will restart and may report that your hard drive is corrupt, ignore this and click on "OK" to continue. Let the PS3 do its thing and hopefully when it restarts all will be well again.
If this procedure does not work, follow steps 1-4 again but on step 5 choose option 4. If this does not work try again but with option 5.
If none of these procedures work then I am afraid it looks like your hard drive may have become faulty. This will mean you will have to purchase a new one.
I hope this helps and thank you for using FixYa
Aug 20, 2010 | Sony Playstation 3 (PS3) Console
My ps3 has stopped working! It says: "Cannot start. Correct hard disk not found." Please, please, please can you help??? Many thanks, Mark & Michelle
Ouch, Bad news Mark and Michelle. This is a fatal error on the hard drive. Basically, the hard drive needs to be replaced :( Sorry
Aug 12, 2010 | Sony Playstation 3 (PS3) Console
My PS3 says on screen: The hard disks file system is corrupted and will restored. ok Press the PS button to use controller. But when I press x nothing happens
lsn if ur PS3 under warranty then send it to them and they will give u a brand new one, but if not just change the Hard Disk and u can choose any Hard Disk size u want
Jun 02, 2010 | Sony Playstation 3 (PS3) Console
Hi,my ps3 is saying, the hard disk's file system is corrupted and will be restored. the it says press ok. after i press ok, then it says restoring the system, after that it restarts it goes back to the...
here's some ideas:
________________________
I fixed my ps3!! All you need is a friend with a ps3!! Swap the hdd's and boot up your friends ps3, format the hdd, put it back in your ps3 and you may need to format it again.
_______________________________________________________
I tried to fix my friend's PS3 HDD that way in mine...it still gave an error every time he booted up his PS3. At that point I stuck the PS3 HDD in my laptop, booted from a Windows CD and fully formatted it that way...stuck it back in his machine...used it to format....finally got his stuff going. Took a little extra time but no problems since.
Apr 12, 2010 | Sony Playstation 3 (PS3) Console
I was downloading update for PS3 and now the playstation says "The hard disks file system is corrupted and will be restored." when I click ok it counts to 100% like it's restoring it and then it restarts...
Put your PS3 in Standby Mode. The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back
Time to enter Safe Mode. Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
You will then see this screen. "Connect the controller with the USB cable, then press the PS button".
Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
You will then see this screen. -REMINDER: -BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADDONS YOU BOUGHT FROM THE PSN.-
Select option number 5. (Restore PS3 System). Then select yes to perform step. You will then see this screen. "The hard disk's file system is corrupt and will be restored.
The PS3 will then restart. You will see many different languages, all that is is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed!
I wish you good luck.
Mar 18, 2010 | Sony Playstation 3 (PS3) Console
When I switch on my PS3 it says that the hard disk is corrupted and to proceed to press OK. So I pressed OK and it loaded, turned itself off and the system restarted itself. But nothing seems to have...
you already have a corrupted hard disk.the best possible solution for that is to replace it with a new hard disk.corrupted hard disk causes the ps3 to freeze bcoz it cannot the load the data that the ps3 needs to boot properly.hope this one solves the problem
Dec 21, 2008 | Video Game Consoles & Games
Hard disk corrupted
whell hold on to x and d together
Apr 09, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
