Question about IWC Pilot Chronograph Edition Automatic IW378901 Watch for Men
Iwc pilot metal bracelet - IWC Pilot Chronograph Edition Automatic IW378901 Watch for Men
Is it possible to convert the resin band strap of casio GS1001 to metal bracelet? If yes, where can I get the metal bracelet?
I have just found this site, it has all sorts of watch straps for all casio watches.
I am sure that you will find it useful
www.casiosalesandservice.com/starasp/a=3&dept=cwband&class=gshock.
Feb 20, 2012 | Casio GShock Giez watch #GS10011A Watch...
Watch running fast about 5 seconds per minute. it had stopped because didn't wear it for a few days. didn't wind it at all. just set time and it started but now running way too fast. any...
mcdevito75 here, Depending on how new your IWC watch is, without running at all can be bad in the way that the oil in the movement can settle and more or less drain off the moveing parts, and without the oil distributed thru out the movement, your watch could run a bit fast. Re--starting your watch as you"ve done will help, re-distribute the oil, in the mean time switch your watches position on your wrist every couple of hours, crystal on top of wrist, then 2--3 hours later crystal turnned under the wrist, it may take a day or two for the condition to correct itself, if I'm right. Hopefully you have a warrantee with IWC on your watch. Hope this helps.
Aug 03, 2010 | IWC Spitfire Pilot Mark XVI Steel IW325505...
I want fast running youtube
Video Download Studio is a tool which gives you the ability to download videos from streaming video sites. You can download videos from Youtube, Google Videos, ...
Nov 23, 2009 | IWC Pilot Chronograph Edition Automatic...
How to adjust expandable bracelet pleaseI would like to remove links to make it smaller.
If you are ready to take that risk, here is how you can do that.
First- get watch on your wrist and by squeezing the bracelet count how many links you have to take out to make it tight enough (say 4 for example).
Check the sides of a bracelet. You will notice that the upper band metal is flipped over the bracelet side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When it's done, you will see two metal staples inserted into the bracelet. You have to pull them out. While pulling out, remember how they where positioned, as you will need to drive them back in the same manner.
So, when the staples are out, do the same on the other side of bracelet. Now you have bracelet in two halves.
Count off 4 links and undo the staples in joint of 4th and 5th link in the same manner as previously.
When links are out, take the staples and drive them back into the bracelet joining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over the bracelet sides.
BE WARNED: as you gonna do it first time, be ready that you can damage the bracelet or can not put it back together.
Good luck.
Jul 29, 2009 | Casio Watches
Setting time on a iwc mark xv auotmatic
Follow this link:
https://www.iwc.com/index-en.asp
Rate me, please.
Mar 27, 2009 | Watches
Self-adjustable bracelet watch
Check the sides of a bracelet. You will notice that the upper bands metal is flipped over the bracelets side. Take tweezers or small pliers and unbend one of these. Try to do as little damage as possible.
When links are out, take the staples and drive them back into the bracelet koining two ends together. You have to do that exactly the same way and position as you took them out.
When all staples are in place, bend the metal back over to the bracelet sides.
Good luck.
Rate me, please.
Mar 19, 2009 | Timex 2J611 Watch
I have a bracelet link bracelet expansion bracelet watch I need to remove some links
Good luck
Dec 21, 2008 | Timex 2J611 Watch
Watch strap to loose
Good luck.
Dec 18, 2008 | Watches
IWC Pilot Chronograph Edition Automatic IW378901 Watch for Men Logo
13 people viewed this question
Top IWC Watches Experts
Ansel Alberto
Ansel Alberto
Are you an IWC Watch Expert? Answer questions, earn points and help others
