Question about Dell Computers & Internet
Application error 340?
Windows 7
  • 1,511 Answers
Boot error may need to reinstall operating system.
Posted on Aug 24, 2014
Error 0xc000007b
fix 0xc00007b error "the application was unable to start correctly"
there may be multiple reasons as to why you might receive 0xc00007b error when trying to run an application on a windows machine. 0xc000007b error usually comes from mixing up 32bit environment with 64bit one. For example 32bit application loads a 64bit dll causing 0xc000007b error.
Solution 1
In most cases it's .NET framework causing issues. This can easily fixed by re-installing latest .NET framework from [link]
Solution 2
Re-install the application that you are trying to run. It sounds simple but the application data files could be corrupt or missing. This could be caused by a installation that did not complete successfully or by a virus.
Solution 3
Running the application as an administrator could fix this error. Right click on the program shortcut or program .exe file, then click on Properties, and on the Compatibility tab. Check the Run this program as an administrator box, and click on OK
Solution 4
Restart your computer as some applications require restart after installation to function properly.
Solution 5
Run Windows update as it can provide application fixes and updates. Furthermore it installs missing drivers and updates the outdated ones like graphic card drivers. Windows 7 / 8 / 8.1 users need to search for "windows update". select all important and optional updates and click on the "install updates" button. If you use Windows XP navigate navigate to Windows Update by choosing Start > All Programs > Windows Update. When the scan is complete,Click the Review and Install Updates link. Finally press the "install now" button.
Windows 7 / 8 / 8.1
Windows XP
Solution 6
manually update the application if possible.
Solution 7
re-install Microsoft Visual C++ from [x32 link] or [x64 link]
Solution 8
re-install DirectX [link]
Solution 9
Many times hard disk problems can be repaired using the chkdsk command. If you are using windows 7 press the start button in bottom left corner of your screen. If you are using windows 8 / 8.1 press the windows key .Search for "cmd" and Right click it and select "Run as administrator". Windows XP users Click on start > run. In the Run box, type in "cmd" in the box.
Windows 7:
Windows 8 / 8.1
Windows XP
A CMD window should appear. In that window you can just type it as you see "chkdsk c: /f /r". If you have more then one drive or partition, you will need to tell it the disk (chkdsk d: /f /r).
If it is the primary windows disk c: it will ask you to schedule it for next boot. When you restart, it will do a chkdsk for you before even getting to the login screen.
Solution 10
This solution only works for a 64-bit system. It requires replacing files is system32 directory so be careful. Only attempt this solution if you are confident and if other solutions have failed. When Microsoft Visual C++ Redistributable Package is not properly configured it may cause 0xc00007b error. Firstly download the zip file [link] and decompress it. Reboot in safe mode and go to C:\Windows\System32. copy all files included in the zip package (mfc100.dll, mfc100u.dll, msvcr100.dll, msvcp100.dll and msvcr100_clr0400.dll) to C:\Windows\System32 replacing the current ones. After that reboot in normal mode.
If all the solutions above haven't worked i would consider backing up data and performing a clean install of windows.
Jan 11, 2016 | Dell Inspiron Computers & Internet
How to fix error message; Error in actiom 3: file of application c:\atscallingcard\install\atshotket.exe
Do you use the ATS calling card application?
As the error message is related to ATS calling card application, I would suggest you to uninstall and reinstall that application (if you still use it) and then check if it works.
Uninstall or change a program
http://windows.microsoft.com/en-us/windows/uninstall-change-program#uninstall-change-program=windows-7
Sep 27, 2014 | Dell Computers & Internet
Windows 7 problem
try to connect the usb HDD in windows with safe mode(by pressing F8 while booting ) and try to check the HDD system disk by windows tool, this might solve some errors. and restart ur device & can work normally then, if windows found errors on ur harddisk & fixed them. good luck
Dec 25, 2011 | Microsoft Windows 7 Ultimate 32 bit Full...
I have an error in an application (0xc0000a5) How can i fix it. Windows 7 home premium Product nr 00359-OEM-899 2687-00006 Sincerely Anita Laine
This problem is commonly misdiagnosed as licensing errors. If you are using Windows 7 and encounter this error, chances are the program has been preselected to run in compatibility mode for a previous OS or version.
1. Right click the application icon and hit properties. 2. Select compatibility tab. 3. Either uncheck the "Run this program in compatibility mode for:" box or select the OS/version the program was designed to be used on.
Hope this helps!
Mar 04, 2011 | E-Machines eMachines Desktop PC
Windows 7 64bit ultimate edition Lots of ''Application Error''
asus M2N68-AM PLUS motherboard is supports all operating system but intel is not support win 7 64bit
May 13, 2010 | ASUS P5QC Motherboard - Intel P45, Socket...
CrystalEye Webacam error
Go into control panel>uninstall a program and then select the application from the list. Look for a repair button towards the top of the screen. If that doesn't fix the problem you can try updating the program, and if that still doesn't fix your problem, you will have to re-install the program. If you upgraded from a previous version of Windows to Windows 7, it could be a compatibility issue.
Dec 26, 2009 | Acer Aspire 5610-4648 Notebook
Error tring to install camera software
  1. Click Start, click Run, type MSIEXEC /UNREGISTER, and then click OK. Even if you do this correctly, it may look like nothing occurs.
  2. Click Start, click Run, type MSIEXEC /REGSERVER, and then click OK. Even if you do this correctly, it may look like nothing occurs, or you may briefly see an hourglass. After you run this command, the operation is complete.
  3. Try your Windows Installer-based application again.
Jan 11, 2009 | Olympus FE-340 Digital Camera
Computers & Internet Logo
43 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
