Question about Breville Fast-Slow Cooker - 6 Quart
How to take off gasket for cleaning
Cleaning
How can I clean an oven door gasket that need to be cleaned?
I think you can replace the gasket but most manuals says to NEVER clean the gasket EVER
Feb 12, 2015 | GE 27" Built-In Double Electric Convection...
How to replace gasket on oil filter mounting bracket
Remove old gasket on the block and pump make sure its clean and reinstall with rtv silicone
Sep 28, 2014 | Cars & Trucks
How to replace a oil pan gasket 2003 mercury sable
1st. Can you remove the oil pan without partially removing the engine? If - YOU CAN'T - take it to a local ASE Professional. Concerns: 1 - rear main seal, will it be damaged when you remove the oil pan. 2. Front oil seal, pan seal, same concern? Lets assume you can remove the oil pan, ok, ... you MUST get the TWO gasket surfaces clean, smooth, I mean REAL CLEAN. SIT THE oil pan with the gasket surface up and flat, ..CLEAN THE GASKET SURFACES AND EVERY BOLT with QUICK EVAPORATING brake cleaner or acetone. Let then dry. Get some Permatex spray "red" gasket glue/sealer. Spray the pan side of the gasket with the red glue, carefully lay the gasket on the pan, use the bolts to locate the gasket, make sure the gasket is seated against the pan 100% around the edges!!!! Let the gasket dry overnight!! Then spray the face of the gasket with the red sealant before installing, do it while its still tacky. tighten all bolts finger tight, then start a criss cross pattern, start slowly tightening them (WITH A QUALITY TORQUE WRENCH) TO 50% OF RECOMMENDED.VALUE, keeping the criss cross pattern to 75%, then to 100 - 110% of FACTORY SPECIFICATION. This should stop all gasket caused leaks!!
Aug 16, 2014 | 2003 Mercury Sable
Replace valve cover gaskets
Remove bolts for valve covers. Remove cand clean covers. Remove and clean old gasket from heads. Use gasket shelack to place new gaskets into place(easier to place on the covers) Reinstall valve covers with gaskets in place. Reinstall bolts. Done.
Jun 12, 2014 | Vehicle Parts & Accessories
I cannot get the top w/ gasket back on a sanibest after servicing the macerator
Make sure the gasket and it's grooved channel are clean also the inside lid lip where the gasket sits on should also be cleaned. Once all parts are cleaned properly install gasket to inside lid lip make sure it seats to the very bottom of the gasket. If it tends to fall off when installing apply a tick coat of petroleum jelly( Vaseline) to help hold it in place while installing. Hope this helps it did it for me
Jun 06, 2011 | Saniflo 013/003/005 Sanibest Toilet with...
Im replacing the lower oil pan on a 2002 hyundai santa fe 2.7L because it got smashed. I've been told to only use sealant but there is a gasket available through auto zone. which way do i go or do i...
This is a great question. You can either use the gasket or not. The really difficult part is to GUARANTEE that the surfaces are clean, dry and ALL oil is cleaned off.
With respect to the gasket, I really prefer gaskets, UNLESS some clearance gets altered, like a valve body... I say use the gaskets and sealer, (on completely cleaned surfaces, clean with brake cleaner).
Jun 04, 2011 | Hyundai Santa Fe Cars & Trucks
Valve Cover Gasket
the oil was the cause of the misfire, the oil swells the rubber on the plug boots and interferes with the electrical connection from the wire to the plug. when you replace the gasket, remover the plug wires, marking which one went where, and use a spray electrical cleaner to remove the oil. make sure the rubber on the new wires isn't already swelled. before removing the plugs or valve cover, spray brake cleaner down in the holes and use compressed air or shop rags to get the hole shiny clean before removing plugs. remove plugs and clean them too. then reinstall plugs and remove valve cover. when replacing any gasket, use a razor blade on to clean the surfaces well. you can even spray a shop rag with brake clean and wipe it to make sure its clean. clean is important. reinstall cover with new gasket in place and torque bolts... be careful not to overdo it, they are small bolts and overtightening can flatten out gasket and cause more leaks. then just reinstall plug wires and off you go
Feb 20, 2010 | 2001 Dodge Caravan
Transmission gasket for 2007 HHR
Is the old gasket a resuable one meaning is it made of a hard plastic ? It should be and if it is there is no need for rtv on it it should not leak if it is make sure that everything is realy clean and make sure its the pan gasket if it is i would replace it. Most new cars are using reusable gaskets and for the most part i dont see any problems with them leaking.
Jan 07, 2009 | 1999 Ford Escort
Breville Fast-Slow Cooker - 6 Quart Logo
27 people viewed this question
Top Breville Home Experts
Donni Steen
Tom Chichester
Are you a Breville Home Expert? Answer questions, earn points and help others
