Question about Carrier Heating & Cooling
Yellow light flashes six times - Carrier Heating & Cooling
2 Suggested Answers
  • 5166 Answers
SOURCE: the power red light keeps flashing six times
The blink code means that something on the board is over current/over voltage. It could be an overload of the +5 line (A/B boards) or the +5 line is shorted.
The TV needs to be opened up and the boards checked. You may be lucky and only need a thermal fuse. Also check your bulb.
I hope this helps.
Posted on Apr 26, 2010
Why does my toyota sienna flash the maintenance required light six times after an oil change?
Start when the battery load voltage change ... the lack of instantaneous voltage, all right, normal.
Mar 15, 2013 | 2009 Toyota Sienna
MY wega 42inch wont turn on...the little green light flashes like five time as if it where to turn on but never does...and then it turns red and flash six times pauses and then again the red light flashes...
Six blinks indicates a faulty power supply. often caused by open thermistor located at under lamp assembly or beside it. Or a defective regulator on power supply section.. Check the thermistor and replace if found defective.. Or contact the nearest Sony service center at your area.
Oct 01, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv shuts off on start up and light flashes six times
more loose inside your tv that is a reason for your tv shut off you need to resolder the printed board
Jun 24, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Battery light flashes six times
Flat / faulty battery or charger. Have charger checked.
Apr 13, 2010 | Toshiba Satellite A205-S4617 Notebook
We have a 2007 Palamino Yearling Model 4101 Pop-Up Camper and recently it was vandalized and the wires from the camper to my vehicle were cut and destroyed so we have to replace the vehicle end plug to the...
Is this a six way plug (six round holes)? If there are six wires coming from the trailer, then the color code should be as follows:
White - Ground
Brown - Tail Lights
Yellow - Left Turn
Red - Stop
Green - Right Turn
Blue - Auxiliary Circuit (Battery Charge, Electric Brakes, etc...)
If you open the plug up that was cut, it is labeled as to which goes where.
TM = Tail Lights
RT = Right Turn
LT = Left Turn
S = Stop
G = Ground
Center = Auxiliary
Jun 27, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Tv won't turn on at all
Hi
the best thing you do is to go back the unit where it you buy because this is under warranty
Thanks!
Jun 09, 2009 | Toshiba REGZA 47HL167 TV
Air bag light flashes 1 then 6
Common fault on FORD
Usually due to a poor connection in the YELLOW PLASTIC CONNECTOR underneath the passenger seat.
Just push it together properly and it should clear the AirBag fault
Mar 29, 2009 | 2002 Ford Windstar Cargo
Printhead light is flashing
the light indicator on the machine blinks one (1) green and then (six) yellow, over and over again. what does this indicate? a few weeks ago it blinked 7 times and i had to change the ink cartridge holder.
if(zs>0){w(''+x2+'#b">Get the answer below
');zSB(1,3);w('
Mar 23, 2008 | Zebra 105Se Thermal Printer
Heating & Cooling Logo
14 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
