Question about Kitchen Ranges
Whirlpool sf325peg oven not working
Oven does not work at all/no fault codes/top burners work fine/no gas smell/
  • 473 Answers
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. Let me know what you find and let's solve it before you rate the solution.
Posted on Nov 03, 2007
Whirlpool oven wont light
The igniter has to heat the thermocouple to turn on the gas valve so if the igniter is glowing brightly either (or both) of those components could be at fault.
Mar 11, 2014 | Whirlpool Kitchen Ranges
My ge xl44 oven will not turn on. There is no gas smell or sounds coming from oven. Burners are working fine. Any suggestions?
I have the same problem. Worked fine last night - now nothing from the stove but the top works fine.
Nov 15, 2010 | GE Kitchen Appliances - Others
Gas oven won't light. Stovetop works fine.
I have the same problem with my whirlpool gas oven. The top burners work fine, but when we turn the oven on, the ON sign on the display stays on for about a few seconds and then goes away. The oven doesn't light up. Please help
Aug 23, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool 465. The top range burners will not ignite. I can hear and smell the gas. The oven burner works fine. Do I need to replace an ignitor for the range?
The bake is seperate from the burner ignition system. You may need a new spark module for the top burners. All burners should spark at the same time even if you are only trying to lite one burner.
Aug 27, 2009 | Ovens
Oven works sporadically
IF YOU CAN SMELL GAS, TURN THE STOVE TAP OFF. Get it checked out immediatly.
Aug 03, 2009 | Whirlpool GS460 Gas Kitchen Range
Oven Not Working
Your igitor mat be glowing but it is not generating the proper amps to ignite the gas. The proper solution is to replace the oven igniter
May 27, 2009 | Whirlpool GS460 Gas Kitchen Range
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Maytag gas oven doesn't heat, but oven's pilot light is on.
Get the oven checked out by a professional, if you have a gas leak you can easily blow up the entire house and you with it. I think you have a faulty gas valve based on what you wrote
Mar 03, 2017 | Ovens
Tappan oven not gas flow or ignition
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Feb 13, 2009 | Tappan TGF303BW Gas Range
Frigidaire gas range oven won't come on
the oven ignitor needs replacing, this is the part that makes everything works, it's a glow coil in side the oven, nest to the burner, that is the electronic pilot, when it goes bad the safety valve, the one that sends gas to the oven will not open to light the oven burner.
Dec 07, 2008 | Kitchen Ranges
Kitchen Ranges Logo
342 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
