Question about Gatco & Channel& Satin Nickel Towel Bar
The towel bar just fell apart. The wall mounts remain in tact as well as the mounting hardware on 1 side (the piece that the bars (this towel rack has 2 bars) slide into. I can't figure out what holds the other mounting hardware onto the wall mount? There does not appear to be screws or any place to hold the hardware securely on the wall mount
  • 334 Answers
The part that holds the bar up should either have a screw in the bottom to tighten up against the wall bracket or a hole to access a scew and turn the screw out to tighten to the wall bracket
Posted on Jun 20, 2009
Towel rack fix came out from wall
Go to a hardware store and wall anchor screws to reinstall the brackets that hold to towel bar to the wall. There should be two brackets and two holes on each bracket. If the existing holes are to big, drill two new holes on each side. Screw the brackets to the wall. As you turn the screw, the will expand in the screw hole and hold the brackets that you attach the towel bar to.
Feb 02, 2018 | Towel Rack Home
How do you fix a Moen Towel Bar when the mounting system has come apart from the wall?
There are larger screw-type anchors available at a hardware store. If the hole is a half inch, you can possibly use an expanding wing type "molly" anchor. it's hard to assemble the screws through the bracket, then put on the butterfly, and shove the folded butterfly into the hole, but it's doable.
Jul 28, 2014 | Moen YB2218BN: Brantford 18 in. Towel Bar...
How do you remove the eva towel rack holder
The Moen YB2824 is attached to the mounting bracket with a set screw through the base. You would simply need to loosen this set screw to remove item from the wall.
May 07, 2011 | Moen YB2818 Eva Towel Bar Bathroom...
I have a franklin towel bar and the mounting bracket broke at the screw hole. is there replacement mounting brackets avaible?
Probably not, but if they sell a toilet paper holder of the same style the bracket might be identical to the towel holder, but would be cheaper than buying a new towel bar. Good luck, Al K
Mar 16, 2011 | Franklin BATH UNLIMITED NORTHPORT TOWEL...
The left bracket/brace is off the wall. There is one long screw in the back center. How is this put back together?
There should be a small screw in each of the arms that secure the towel bar to the wall mounts. You will need to loosen each of these to remove the towel bar from the wall and to release the mounting bracket which has pulled free. To repair you need to puchase a larger size moly plug, toggle mount or other suitable hardware to secure the mounting bracket to the sheetrock wall (should not have pulled free is screwed in to the stud). Once you secure the mounting bracket then you are able to re-install the towel bar by placing the arms over the mounting brackets and tightening the small screws on each arm of the towel bar.
Here are a couple of videos which should help you undesrtand how towel bars are installed. Hope this is helpful. (do not delete) utube.png Here is a couple of videos that should help understand how towel bars
Dec 19, 2010 | Moen 24 In. Towel Bar...
How to remove towel bars and hooks from wall. No set screw visible. We did not install them.
Newer towel bars don't have set screws... Solution-slide off! There is an opening in the bottom of the bracket. Slide your flat head screw driver inside the opening and place pressure on the bottom. Make sure you place enough pressure to allow the holder to slide off.. Now pull on the holder and it will snap off...
Sep 23, 2010 | Moen 24 In. Towel Bar...
Tighten up a loose Moen Eva towel bar wall mounted bracket
u have to really push hard up on the spring and at the same time pull towards u
Apr 18, 2010 | Moen YB2818 Eva Towel Bar Bathroom...
How to Install Towel Bar?
Since towel bars are usually installed onto separate hardware that's mounted on the walls, use the actual hardware as a template to mark exactly where to drill your mounting holes. Hold a piece of mounting hardware against the masking tape and use your pencil to mark the actual spots to drill your holes. Use different-sized drill bits to drill for the two ends. The Molly bolt or wall anchor will require a much larger diameter hole than the screws going directly into the stud. (The size of the hole required for the wall fastener will be marked on the packaging.) Install the wall fastener into the wall, then mount the hardware onto the wall and place the ends of the towel bar over the hardware. Attach the towel bar to the mounting hardware using the screws included with the towel bar. These are commonly small-slotted screws located on the bottom of the end pieces of the towel bar.
Aug 27, 2008 | Grohe 40.344.000 Essentials Bathroom...
Gatco & Channel& Satin Nickel Towel Bar Logo
791 people viewed this question
Top Gatco Home Experts
john h
Tom Chichester
Are you a Gatco Home Expert? Answer questions, earn points and help others
