I used 220v electricity to ON the woofer but the woofer needed 110v. Now I cannot turn it on. Please let me know what parts will be damaged or need repairs?
  • 4 Answers
Try changing your main fuse - it should have blown.
Posted on Apr 24, 2014
4 Suggested Answers
SOURCE: speakers and OHM's
it will work temp. but it may put to much of a load on the receiver
Posted on Jul 27, 2008
SOURCE: Help repair EV SxA180 sob woofer
Q10&Q10B IRF6215 Q11 IRF3315
Posted on Jan 09, 2009
  • 3 Answers
SOURCE: Have a PSW-D112 sub woofer
Go to Parts Express and buy the Bash 300w digital subwoofer amp.It fits almost exact except it is one inch shorter.Just use mdf to fill the space and this amp will outperform the original.I have done this and it's not really difficult,pretty straight forward.
They usually sell for around $149,but they have sales often around $99.Good luck.
Posted on Dec 05, 2010
Testimonial: "THANKS, BUNCHES. I LOOKED UP PLATE AMP SOURCES, BUT WASN'T SURE WHAT BRAND OR SIZE WAS APPROPRIATE. YOUR ADVICE IS WELL RECEIVED AND APPRECIATED."
Hello! My BOSE (max 300w) have in 110V, and I need for 220V BILLION 261278-102 REV.07 E2-86RTF-NS1-0289 A92TS-196B-1 R152D 07'23 Where can I order a suitable transformer for 220V? How to chenge...
Hi
there are suitable converters in the market from 220v to 110v.
google in your area to find an electronic store that provides this type of converters.
second choice .
if you know someone that winds electrical transformers or motors .you can ask him to modify your transformer its easy done .
number of wire turns and diameter.... turns *2 and diameter 1/2.
for an example: 410 turns for 110v it will be 820 turns and 1/2 diameter of the wire, that will fit exactly the transformer size.
Good luck
Apr 11, 2015 | Bose Audio Players & Recorders
Can I plug GE dryer GTDP250EMWW directly to 220v? the manual says that the power rating of this model is 110/220v.
If the dryer is electric and bought in the United States then you can plug it in. The 110/220 power rating basically means that some parts if the dryer use 110v. All 220v is is 2 110v independent circuits sharing the same common ground.
Sep 06, 2012 | GE Dryers
Logitech z515 power US is 110V - israel is 220V - is US to EU plug adapter sufficient to use in Israel ?
No you cannot as 220v will damage the 110v the Logitech. You need a stepdown transformer to reduce the voltage from 220v to 110v. and then you can safely plug the Logitech into this stepdown transformer.
Jan 30, 2012 | Logitech Z515
My son accidentally plug a 110v bose 3-2-1 to a 220v outlet. What do you think is the damage? Do we still need to send it to a service center?
If you are lucky you would have lost the fuse on the sub woofer module which powers the whole unit. If not, yes you will need a qualified technician to look into the matter because its not a small offense to plug a 110 device into 220v.
Jul 06, 2011 | Bose 3 2 1 GSX System
I wanted to purchase a Bose companion 3 set from the US through ebay. i wanted to know whether they work on 220V and if not how can I make them work at 220V.
Since this unit dose not come with power adaptor. It has direct plug in in to the port behind the sub-woofer unit and other end to the wall outlet. Is there any way to convert the power supply from UK to US (220v to 110v). For example Desktop PCs have a switch behind every desktop unit to change power from 110v to 220v or vise versa.
Anyone has any idea how to make this happen in Bose Companion 3 system.
I bought it from UK and now moved to US and I want it to work in US.
othervise use waltage adapter to use it
Aug 08, 2010 | Bose Companion 3 Computer Speakers
What will happen if I plug my 110V tv into a 220V receptacle?
If you want to fry your electronics or appliances that's it's a sure way to accomplish that.
While appliance working ONLY at 220v will just not work or under perform (like a hair drier) when plugging electronic equipment that runds ONLY at 110v then that item will be "fried" as all its electric components will be burnt as it will receive twice the power that it was build to receive. Should that happen the safety switch on the 220v circuit where the item was MISTAKENLY plugged will be triggered (hopefully or there will be risk of fire and serious injuries, even death) and the power will be shut off. That's a major but possible mistake.
If traveling abroad those who come to US will unlikely damage their appliances (like electric razors) as they will receive less power (110v vs 220v) and usually these items are protected against these mistakes by the specifications of their own design. The opposite is not true of course as just mentioned above.
So do not play around with dangerous items please! ;) On a positive note though: Nowadays most appliances have dual power and should work whether plugged in a 110v, 60Hz (most common in US) or 220v 50Hz (most common in Europe). So nothing really happens... it just works as long as you have the proper adapters to plug the appliance to the different receptacles.
Note: One of the differences is that (without going into the math of it all), an appliance working at 110v will draw x2 times the power than it draws when working on 220v so if an appliance was drawing 3A at 110v it will only draw 1.5A when working at 220v.
Best.
Jul 05, 2010 | Televison & Video
110v or 220v ?
That would be a 220v dryer...virtually all electric dryers are 220v.
heatman101
Apr 19, 2010 | Maytag MDE2400A Electric Dryer
I have a kenmore 99701 series combo w/d. they tell me they are all 110. told them 220. neeed to know for sure as cord was taken off and screws missing and loose. don't know for sure and if grounding is...
Well for sure the washer is going to be 110v. Only electric dryers are 220v!. If your dryer doesnt have a gas connection on it then it is a electric 220v dryer. If it has gas connection then it is 110v gas dryer. there is no such thing as a 220v gas dryer!!!.
Mar 25, 2010 | Kenmore Washing Machines
I need a manual for the optical spectrum analyzer Anritsu MS9001B
Hi Jean, i have the same unit but at 110V, i need swich positions for 220V, if you can, please conntact with me at this email : nikig@langame.net, ill give you picture for 110V switches possition.
best regards.
NikiG
Feb 08, 2010 | Kenmore Elite HE4 Electric Dryer
139 people viewed this question
 Grubhead
Grubhead
