Question about Marantz PMD670 Desktop Digital Voice Recorder
What does a broken EDL means
EDL
2 Suggested Answers
tscmusa
  • 95 Answers
SOURCE: Broken EDL?
You must have deleted the EDL file,you cant fix it,re format the card and start again
Posted on Apr 01, 2010
Wat is ars
ASR system:
"The electronic stabilisation program (ESP) makes the vehicle easier to control in handling situations close to the limit It reduces the danger of swerving and thus improves directional stability. ESP identifies the car's intended direction and response. It applies the brakes on individual wheels, thereby generating one-sided forces that help to keep the car moving in the desired direction. The program uses the anti-lock braking system (ABS), electronic brake-force distribution (EBD), the electronic differential lock (EDL) and the traction control (ASR) system, and is permanently active."
"For today's typical high-torque engines, a form of wheelslip regulation or traction control (ASR) can increase both comfort and safety, particularly on surfaces with differing coefficients of friction or on slippery roads. It makes smooth starts and acceleration possible through all speed ranges without wheel-spin or fishtailing.
ASR only operates in conjunction with the electronic accelerator (E gas) and uses components of the anti-lock braking system (ABS). If one wheel suddenly begins to rotate faster than the others (slip), ASR intervenes in the engine management system and reduces power until the wheel stops spinning.
ASR improves traction and can help the driver maintain control even if the limit of adhesion is inadvertently reached while cornering. In addition, it reduces tire wear. ASR activation, is indicated by a flashing light in the instrument cluster; it works with the electronic differential lock (EDL) and it is also part of the electronic stabilization program (ESP). ASR can be deactivated with the ESP switch."
Dec 05, 2010 | 1998 Audi A6
Kodak 5100 easyshare software not functioning with Windows 7 O/S
You need to install the compatible version for win 7 and that's the Easy share version 8.1
you can dowload the software at www.kodak.com/go/edl
Dec 12, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Anti brake lights are on in my 2000 volkswagon bettle
Have it scanned in order to download the DTC (Display Trouble Code) for ABS.
The light will remain on if any of the following exist:
  • If supply voltage drops below 10.0V
  • If ABS system has a malfunction
  • If EDL is not functioning (if applicable)
Oct 19, 2009 | 2000 Volkswagen Beetle
Need easyshare software for windows 2003
There is no easy share version avail for your OS, the software is only avail. for winxp sp2 , vista or win 7.
You can get free download at www.kodak.com/go/edl
Jun 26, 2009 | Kodak Easyshare C813 Digital Camera
Broken EDL?
May 28, 2009 | Marantz PMD670 Desktop Digital Voice...
Cannot load kodak software for a kodak esp3
You must restart your computer then reinstall again. Pls. use website to get latest version www.kodak.com/go/edl
May 11, 2009 | Kodak EasyShare Z710 Digital Camera
Fuse
# 9 is ABS, EDL, TCS, and ESP power, it's a 5Amp fuse
#17 is a dead terminal nothing uses this spot.
Jan 30, 2009 | 2000 Volkswagen Beetle
Open Questions:
marantz PMD671 recorder - download problem How do I download a recording from the media card to my mac? Nothing registers on my computer when I connect to the recorder via usb... When I connect my Marantz recorder to my PC with the USB cable, it allows me to transfer files to the PC.  However, when I do the same thing with the Mac, nothing happens.  My Mac doesn't recognize it at all. Hi there, I've just bought a PMD671, and am have a lot of trouble with USB connectivity. I've tried 3 different computers (HP XU800, Lenovo S10 and IBM T43), and 4 different OS and BIOS combinations (Win98SE, Vista64, and two different USB-BIOS-enabled DOS boots. In all cases, I can read 5 different USB drives I have from Sandisk (3) and Kingston (2), as well as my Olympus E1 digital camera and my wife's Canon Ixus - but the Marantz PMD671 usually just causes my BIOS-equipped PCs to hang during boot up, unless and until I turn the recorder off or pull the plug. In Win98SE, where I use generic USB drivers (from Kingston), the "new device" recognition phase simply hangs - again, until I turn the PMD off or pull the plug. Once in a while - say one time in about 10-20 - when I turn on the USB, my Vista 64 machine sees it and pops up the "Autoplay" dialog; likewise, this same machine sometimes gets through a reboot with the BIOS recognising the PMD, which then gives me direct access from DOS. But it's so hit and miss - is there anything I can do to make it work every time, rather then once out of a dozen or more attempts?
Feb 28, 2017 | Marantz PMD670 Desktop Digital Voice...
See all Marantz PMD670 Desktop Digital Voice Recorder Questions
Marantz PMD670 Desktop Digital Voice Recorder Logo
43 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
