Question about Navman Tracker 5505i Color Chart Plotter 5" C-Map Max by GPS Receiver
Connecting external antenna to 5505i - Navman Tracker 5505i Color Chart Plotter 5" C-Map Max by GPS Receiver
How would I attach an external antenna?
The manual may be generic, covering a number of models with and without external antenna connection provisions.
Aug 26, 2015 | Radio Communications
Gps fix
do you have anything interfering with that signal, like a solid mass of metal?
Jun 03, 2008 | Navman Tracker 5505i Color Chart Plotter...
Yes i order an antenna adapter for a 2005 dodge dakota.. The end that goes into the radio fits perfectly but the end that attaches to the antenna itself will not fit.. the antenna has a round black plastic...
The adapter is not exactly the same which is required.but yes you can get the external connection for adapter which will fit in adapter and also get connected to the antenna.You will have to get this external connection from
www.walmart.com or from
www.radioshack.com
check out.thanks.
Jun 05, 2010 | Car Audio & Video
Unit does not pick up satellites but recognizes when antenna is open
I have a unit like that. The antenna appears to be dead. It just searches forever and never finds anything. I use an external antenna that I got from eBay (brand is Gilsson) and it works fine. You just plug it in the external jack (after removing the little rubber plug) and it works even better than the built-in antenna.
Jul 01, 2009 | Garmin iQue 3600 GPS Receiver
Grundig PVR/ Digital TV Tuner with no external antenna?
i am living in a house where i cant place an external antina. is there any reveiver that donot require exteernal antina and we can receive channens
Jun 27, 2009 | Televison & Video
How do I connect an external radio shack AM enhancer
I presume that you wish to connect an external antenna/aerial to a portable radio with no antenna connection. Wind several turns of your antenna wire around the telescopic antenna - should work ok!
Mar 30, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
How do I see the rest of this solution? Garmin Nuvi 660 GPS Receiver Problem: Garmin Nuvi GPS won't acquire satellites Solution by: wingflinger (1 solutions) There is a known hardware bug in the...
you should see it now
There is a known hardware bug in the Garmin 600 series relating to the detection of the connection of an external antenna. The GPS is supposed to do this automatically and when it detects an external antenna plugged in it switches out the internal antenna. Unfortunately, this circuitry doesn't work correctly in some versions of the unit and sometimes it get's comfused and thinks there is an external antenna connected when there is not. This causes the behavior you describe because, for all practical purposes, there is no antenna connected.
Garmin can fix this and they've been known to fix it even on units that are out of warranty. There is a fix that can be done by someone with the right equipment and know-how which requires disassembling the unit and bypassing the antenna switch. Not to be attempted by anyone not experienced in micro surface mount PCB re-work.
Wingflinger
Dec 12, 2008 | Garmin GPS
GE Spacemaker TV/Radio combination Model #7-7650
Yes, you will need an external antenna to pull in the digital signals. It will not work with the built-in antenna on the GE. Alternately, you can use an external antenna (ie, rabbit ears), connect them to the converter box, then connect the converter box to the antenna jack on the back of the TV (I think it has one). Granted, not an elegant solution for a kitchen TV, but it beats not using it anymore.
Cheers
Nov 11, 2008 | GE Televison & Video
Toshiba
There are no connectinos for an external antenna on your laptop model sorry.here is a picture of what it looks like though: The connectors at the top for the antenna cables. If you know someone that is an electronics guru, then order another card ( just in case ) for about $15 + shipping, and have him/her connect
those wires to a TMC or SMA connector somehow. Otherwise,.. just buy a good quality USB Wi-Fi adapter with an external antenna. ( which wouldn't cost much more than the spare Toshiba card and less if you figure in what a good dB gain antenna costs)
Feb 24, 2008 | Toshiba Tecra M2-S730 Notebook
Navman Tracker 5505i Color Chart Plotter 5" C-Map Max by GPS Receiver Logo
12 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
