Question about Hilti TE 70 Hammer Drill Performance Package
Can you reset the service light on a hilti te60 atc
rowdy45176
  • 2176 Answers
SOURCE: service light
You can reset the light. What you need to do it remove the handle assembly from body of tool. The contacts will unplug. Then plug the cord in and pull the trigger and sometimes the light will blink, while holding the trigger in the on position unplug the cord. reinstall the handle and the light should go out. Sometimes you have to pull the trigger while plugging cord in but this should work. and then while holding unplug cord.
Posted on Sep 21, 2009
Testimonial: "excellent, tried it out and it worked... thanks very much :-))"
  • 61 Answers
SOURCE: hilti 76 p atc
Hi . The solution offered by rowdy (pull the trigger and hold it until light goes out) will only work on older machines, the newer machines have more complex electronics that need reseting using an optical reader which plugs into a PC , you will also need the Hilti ODA Software. this is not available to the general public. you may have to send it back to hilti for service and reset. this is free if the machine is less than 2 years old.
Posted on Oct 11, 2009
  • 61 Answers
SOURCE: parts for my hilti te 76
If you send me an email i will send you the parts diagram. parts are available from me but I am in Gibraltar. but I can give you a quote if you like.
paul@wysehire.gi
www.wysehire.gi
  • 47 Answers
SOURCE: How to reset Active Torque Control in the handle
Active Torque Control (only TE 76-ATC / TE 76P-ATC)
The TE76-ATC / TE 76P-ATC is equipped with the Active
Torque Control system in addition to the mechanical
torque limiting clutch. This system offers additional protection
while drilling by rapid shutdown upon uncontrolled
rotation in the axis of the drill bit, e. g. when the
drill bit jams due to hitting rebar or when the insert tool
is tilted unintentionally.
When the ATC system has become activated, the tool
can be restarted by releasing the control switch and reengaging
it after the the motor has stopped rotating
("click"-sound signals readiness for use).
Always choose a working position in which the electric
tool is free to rotate in a counter-clockwise direction
(as seen by the operator). If this is not possible, the ATC
system cannot react.
Posted on Mar 01, 2011
  • 123 Answers
SOURCE: how to change trigger switch on hilti te60
If this is an older [Metal Housing] Te60 then you would remove the two 5mm allen screws at the base of the handle at the moter. You then have one more 5mm screw that is recessed in the top of the handle. You will see a hole and in that hole you insert a 5mm allen and it will access the screw. After that you can pull the handle away from the drill about an inch. Take out the phillips head screws holding the handle together. Seperate the handle and you will have access to the switch. It is just a matter of taking out the four wires and replacing the switch.
Posted on Apr 16, 2011
How to reset service light on hilti te 76 atc??
Only factory service can reset certain faults.
Test kit is available to run drill without electronics.
Sep 17, 2012 | Drills
How to reset te76 atc module
Eto rabotaet. Spasibo!
Its working. Thanks!
Apr 07, 2012 | Hilti TE 70 Hammer Drill Performance...
My. Hilti 76 atc. Shows service light. Changed. Carbons still. Light on. And won't. Work
the light needs to be reset and usually you have to send to Hilti for them to do it. BUT if you are mechanically inclined I can try and help. Send me a reply before I go into detail about how to try this, it will require you removing the handle assembly. Let me know
Jun 12, 2011 | Hilti Drills
How to change trigger switch on hilti te60
Apr 13, 2011 | Hilti Drills
How to reset Active Torque Control in the handle of Hilti model TE76P-ATC Rotary Hammer Drill
Mar 01, 2011 | Hilti Drills
I have a TE 60 hammer drill. It does not run . I looked at the brushes and they are wore .One of the wires to the brush is broken. Can you inform me on how to get replacement brushes?
If this is an older metal housing TE60 parts are no longer available. If the brushes are worn out then the commutator on the rotor is also probably worn. If it is a new version of the TE60 (introduced in 2009). Then parts are available for it.
Contact Hilti @ 800-879-8000
Nov 16, 2010 | Hilti Drills
Hi, My hammer drill HILTI TE76-ATC has service red light on. How can I solve this problem? Thanks
Hi. It all depends on the age of it as there are 2 different types of electronics fitted to the TE76.
If you have an early model, the service light came on when the brushes were worn or it was in need of a service. Check your brushes 1st. then to reset the light, simply pull the trigger and hold it untill it resets.
If you have the newer type then you will need to reset the service light by attaching a data reader to the service light. this data reader plugs in to a PC, you will also need the HILTI ODA Software to go with it. Basicaly you need to send it back to hilti to have is serviced and reset. if your machine is less than 2 years old, this is FREE. just phone hilti and ask them to collect it. they will pick it up, service it and get it back to you in 3 working days. if you not sure how old your machine is simply phone Hilti and ask them, quoting the serial number. this is etched into the plastic on the left side of the machine underneath the white writing on the motor housing. Good Luck
Sep 25, 2009 | Drills
Service light
Sep 21, 2009 | Hilti Drills
Hilti 76 p atc
Jul 02, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti TE 70 Hammer Drill Performance Package Logo
388 people viewed this question
Top Hilti Drills Experts
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
