Question about Candy Washing Machines
Candy 1400 spin 6kg AAA
I live in Cyprus. My machine stopped working. the local repair man came and said the curcuit board had broken. I got one sent from the UK as NONE available here .Fitted the board but the machine is ''dead'' no lighting up ,,,nothing. what next please?
mumma_1
  • 903 Answers
SOURCE: Candy Model CE10 won't spin
It sound like the carbon brushes in the motor may need changing. It sohuld still be okay to get repaired, as most machines have generic brushes for all of thier models. It's worth calling an engineer and suggesting that the brushes have gone in the motor to get a quote on the repair job. Some engineers will come out and give you a free quote anyway.
Posted on Oct 30, 2008
  • 52 Answers
SOURCE: Water wont drain from Machine or go onto spin cycle
either the level control switch has become blocked or faulty or the drain pump has become stuck.
disconnect from the mains and gain access to the rear look for a circular unit with two or three electrical connections and a plastic tube. this is the level control.follow the tube to its start and you will find a plastic connection that goes into the wash drum, remove the plastic tube from the switch end and blow into it. if there is no restistance then the system is OK at the drum end. next reconnect the tube to the switch and remove the opposite end, very gently blow down the tube and you should hear the switch operate. Test wether the switch is working by putting a meter across the switch and blow into the tube. if all of this is OK then the drain pump is at fault. locate the drain pump. it is connected to the outlet tube, try turning by hand. if it does not rotate smoothly remove the clips holding the pump body together and clear the obstruction.
Posted on Dec 27, 2008
  • 31 Answers
SOURCE: Washing machine has broken down
try to put your washer on a drain and see you can hear the pump workng. you should hear a buzzing.if you dont it mite be your pump that as gone. to get the water out pull whasher out near your back door if poss and lie the drain pipe flat the waser will then empty. if there is a buz then you could have a blockage. but if not a pump is no more then 25 pound and are not that had to do
Posted on Jun 24, 2009
SOURCE: Washing machine candy grand'o 1400 has stuck, vanish stain light
Ok, turn the washing machine off and unplud. Open the flap at the bottom left of the machine. Put a bucket underneath it. Unscrew the cap. Water will pour out - lots of it and very quickly - so make sure you have a bucket underneath it and lots of towels round that.
Once the water has drained out, check there are no blockages in there. You may find that some coins or buttons flush out with the water. That will be your problem.
Once clear, screw the plug back in and turn on machine.
Posted on Jan 04, 2010
SOURCE: hoover vision HD 1400 AAA 8kg washing machine -
can I have the instruction how to use for HOOVER vision HD 1400 AA+A. I lost the manual
Posted on Jul 18, 2010
Candy 1400 aaa fills water but that is all it does
Simply try the old off at the plug, wait 10 mins then on again. Then try looking where your machine has access to the 'flap'. Basically, ours did that, I opened flap bottom right, where the muck/hairs/hair clips/pencils etc etc have all accumulated in the years of use. Clean it all out. Our machine apparently refused to spin / turn whilst bunged up with rubbish. Cleaned it out, turned back on and selected a "spin dry" only cycle and left it. Also, there's a pipe that outlets the water - usually directed into your sink drainage pipes. Check this isn't going up-hill. What I mean is, the draining water will pump mildly upwards sloping but I found ours was too steep thus not draining thus it wont spin. Not an engineer just had many issues similar with our cheapo Beko machine.
Oct 12, 2014 | Washing Machines
Candy Grande o, stain vanish and 90 min light flashing
Try to find error codes on the Candy website.
Dec 20, 2013 | Washing Machines
Candy A*AAA 1400 spin 7kg Machine turns on, water doesn't come into machine start of cycle except sounds as though it is going to. Emptied the filter at the bottom of machine lots of water nothing...
The valve through which water comes in2 the washer is opened electrically and it is the what-type-of-water-u want-2-use selector switch that controls the opening & closing. E.g if u select cold water it opens valve for cold water and closes valve for hot water. There is a place (most likely at the valves where pipes meet washer) where electrical connection e.g due 2rust, has been lost. Thus the valves r not being opened by the selector.
Mar 01, 2013 | Washing Machines
Simpson encore 605
Sounds like a motor transmission problem.190.00 parts and labor is not a bad price.
Check if there is a warranty with the new parts the service person is installing.
Oct 27, 2011 | Washing Machines
My Candy sprint 1300 washing machine wont spin to drain water from my clothes
these washers have a printed circuit board that is know to burn out some components.If you can locate it and remove it, it can be resoldered at a local electronics shop, if your not confortable, most appliance repair shops can change this board at a reasonable cost. Hope this is helpful
Dec 27, 2010 | Washing Machines
Simpson encore 605 wash machine 6kg. Washer pump
Hi mark just read your posting.Now what country do you live in.If you live in Australia then I can give you some phone numbers.Regarding your machine it does sound like the control board.Probably the power supply section of the board is faulting.Please reply with additional information and I can help you further.
Jun 19, 2010 | Washing Machines
Hoover vision HD 1400 AAA 8kg washing machine - wont start & four flashing lights on timer delay ?????? any advice pls
Feb 01, 2010 | Washing Machines
Dec 23, 2009 | Candy Washing Machines
My washing machine doesn't fill with water even if i fill it manualy it wont wash but it still does the spin cycle
Timer, the dial under the knob, or the curcuit board if it has a computer panel. That is the only thing I can think or, it's an easy fix, just order the part from a local repair shop, or order it on line.
Jul 31, 2009 | Washing Machines
Washing Machines Logo
14 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Kolbrun...
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
