Our Siemens rev 11 screen has gone blank We have put in new batteries but still nothing does this mean the thermostat controller is dead or is there an electrical problem
confusedbrit
  • 38 Answers
SOURCE: The screen became blank
I would say the LCD is dead. They seem prone to that because we have had to replace two handsets with exactly the same problem. The one lost the top row of the screen, the second is completely screendead. Though all is not lost. Any GAP compatible cordless handset will work with that base, so you can replace them and not have to buy an entire system :) Ebay is a good source for handsets only.
Posted on Aug 20, 2008
Nobarai
  • 57 Answers
SOURCE: TI-83 Plus Went Dead
Has it been dropped recently? The screen may have cracked from impact. Press the Reset button on the back using a ball point pen.
Posted on Nov 16, 2008
nematics
  • 431 Answers
SOURCE: sony ericsson z310i, display screen has gone blank
try flashing the phones software
Posted on Jan 11, 2009
Fame_Guru
  • 483 Answers
SOURCE: I have Nokia 1100, battery is dead & won't charge
I am sure if you take this to the nokia care they have an easy replacement for the battery.
Thanks
Fame !
Posted on Apr 27, 2009
james3751
  • 614 Answers
SOURCE: blank thermostat
Check voltage at unit. Also check the 5 amp fuse in the unit. If this unit has a float switch in the drain line check that. Rus
Posted on Dec 03, 2009
Blank Screen
Remove and install new batteries, if displays reprogram. if no display replace thermostat
How To Install Programmable Thermostat The Home Depot
Jan 20, 2016 | Televison & Video
Acl lifestyle lp522
The display should not be blank, meaning nothing there to look at. Different digital thermostats can be powered in 3 ways. Just from their battery's, from the furnace control transformer, from the furnace control transformer with battery back up in case the control power fails to retain your programming. Usually, removing it from the base and pulling the battery's to kill ALL of its power, waiting a minute or so then re-powering it, will restore the factory program and return the display. Also, there may be a small fuse on the back of the stat. If it has one, it will be easy to see if you are looking for it. Easy to miss if just looking at it for no reason. Be sure there is power to it. The battery's and their connections first. If you have a meter, check for control voltage. Put one lead on "R" then touch the other to "C", "Y" or "H". Should have 24 volts (AC) from the furnace transformer. I have never seen a stat blow from a power outage. But?
Dec 18, 2013 | Heating & Cooling
I have a programmable thermostat Noma - the screen has gone blank ... does it require batteries ... I can't see any place to put batteries in it ... any ideas??? My heating is out of control and I...
Yes most today do take 2 AA batteries. Just look at the bottom of the stat and look for the area to separate the front from the rear plate.
Jun 26, 2011 | Heating & Cooling
My daughter's 3g phone was dropped...need help
Make sure connections are all good to motherboard. If they are you may need a new lcd screen.
Mar 14, 2010 | Apple iPhone Smartphone
Honeywell thermostat t8400c intermittent blank screen
It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
Sep 28, 2009 | Honeywell Electronic Programmable...
My screen went blank on my 880, I've fully charged it, took the battery out. it glows, but nothing is visable. any suggestions?
Ur main IC incoder is dead is peace junk now.
Tries to return it that all u can do.
Keep trying with new batteries see if digital display come back that all u could do.
Aug 25, 2009 | Logitech Harmony 880 LCD Remote Control
A/C not turning on - Digital screen is blank
Your honeywell should have battery back up but the primary power for this is a 24 volt transformer located in the air handler probably in your attic. All these controls run on 24 volts
Jul 11, 2009 | Honeywell Programmable Thermostat Heater
Screen gone blank. is there a battery to replace?
There is no battery, but I have one as well and it also goes blank. When that happens, you pull the front bezel off of the back mounted plate carefully and put it back on by attaching the 2 tabs at the top, then swing the bottom back towards the plate until the 8 pins go into the connector on the removable bezel. When you first pull it off, do it slowly and pull from the lower sides straight out.
I think what is happening is the pins get corroded and lose contact with the removable front.
Hope this helps you out.
Apr 28, 2009 | Honeywell CT3600 7 Day Electronic...
Chronotherm III Thermostat Completely Blank Screen, No Heat
One of two things either the disply has gone out which is likely as it is a common failure for that thermostat or your heating unit is not sending control power. the older chronotherms were system (24volt ac) powered the new hardware/box store units are battery powered. Either way display should not be blank with fresh batteries. to get heat on remove the thermostat jumper or twist together the wire from the R terminal with the wire from the W terminal. note the color of each wire for later reference, heat up house disconnect wires from each other and go purchase a new thermostat
Dec 17, 2008 | Honeywell Programmable Thermostat Heater
Aug 13, 2008 | Uniden Cordless Phone
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
