Question about Dryers
Hotpoint ctd40 There is a burning smell when start button pressed . filer clean and water container empty
4 Suggested Answers
SOURCE: HOTPOINT AQUARIUS CONDENSER TUMBLE DRYER CTD40
There are three water reservoirs - one at the bottom behind the condenser, a second at the back bottom of the machine and then a third at the top which is the one you would normally pull out to empty.
There is a hole at the bottom of the filter in the first reservoir (at the back of the condenser) which leads to the second reservoir at the back. If the hole gets clogged up with lint/muck then the reservoir at the back does not fill up.
So to solve this, unplug the machine, take out the condenser (front left bottom of the machine) reach through to the back and mop up the spare water with a towel and check that the hole to the back reservoir - you can feel this it is towards the right side at the back of the machine is clear from muck.
Once you have cleared it, water will flow to the second reservoir and then (once you switch on the machine) up to the main removeable reservoir at the top.
Hopefully this helps. GB
Posted on Sep 10, 2009
todd0708
  • 247 Answers
SOURCE: hotpoint ctd40 t dryer. wont start just ticking.
do you hear anything running?,might have broken the belt or idler wheel,motor runs but no tumble,need to look inside,warning !! unplug ,high voltage.be carefull
Posted on Sep 22, 2009
miket756
  • 2702 Answers
SOURCE: empty water light flashing on hotpoint ctd40 dryer
this could be just a sticky switch staying stuck on, telling the dryer it has a full tank try soaking the switch in switch cleaner or wd40 may work
Posted on Jul 29, 2010
LIGHT FLASHING EMPTY WATER,CUTTING OFF WHEN WATER EMPTIED
Try cleaning the water sensor, it may need to be replaced though.
Dec 22, 2013 | Dryers
Hoptoint CDT40G condenser tumble dryer pump running no heat or movement
hi i have a ctd40 mine wouldent go a few years ago on the heater i had three stats on one of them there is a tiny hole i pushed a sewing needle in hole it reset the stat you can see if you look at bottom of stat it might be concave so pushing it out set it again dryer then worked pull plug first
Apr 29, 2013 | Hotpoint Dryers
How to discale the unit
Delonghi EAM, ESAM, ECAM, Nespresso
Over time, the continuous heating up of the water used to make the coffee leads to lime scale building up in
the inner circuits of the appliance.
When the appliance displays the message:
DESCALE
you should perform the descale cycle.
Proceed as follows:
• make sure the appliance is ready.
• press the button (the light over the button comes on) then press the button repeatedly until
the appliance displays:
DESCALE No
• Press and the appliance displays the message:
DESCALE Yes
• Press the button to start the descale programme.
• Empty the water tank and add the contents of one bottle (125 ml) of DURGOL descaler plus
one litre of water. For subsequent descaling, use descaler of the same type and brand as supplied
(available from technical service centres authorised by the manufacturer).
• attach the water spout to the nozzle;
• place a container with a minimum capacity of 1.5 litres under the hot water spout (Fig. 3);
• press the button. Descaler runs off from the hot water spout into the container below. The appliance
displays:
APPLIANCE IN DESCALE
• the descale programme automatically performs a series of run offs and pauses to remove lime scale
deposits from inside the coffee maker.
• After about 30 minutes, the appliance displays:
RINSING FILL TANK
The appliance must now be rinsed through to eliminate residues of descaling solution from inside the appliance.
Proceed as follows:
• empty the water tank, rinse and fill with clean water.
• Reposition the tank.
• Empty the full container and then put it back under the hot water spout.
• Press the OK button. Hot water is run off from the spout into the container below and the appliance displays:
RINSING
• When the water tank is empty, the appliance displays the message:
RISRINSING COMPLETE PRESS OK
• Press the OK button and refill the water tank with clean water.
• The descale programme is now terminated and the appliance is ready to make coffee again.
NOTE: if the descaling cycle is interrupted before completion, the appliance continues to display the descale
message and the programme must be started again from the beginning. Empty the water tank, rinse, fill with
clean water and run off a cup of hot water.
IMPORTANT: FAILURE TO DESCALE THE APPLIANCE REGULARLY INVALIDATES THE GUARANTEE.
Jan 01, 2012 | DeLonghi Esclusivo Magnifica ESAM3300...
Descale
DESCALE
Proceed as follows:
DESCALE No
DESCALE Yes
displays:
RINSING FILL TANK
Proceed as follows:
RINSING
Nov 25, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Empty water light flashing on hotpoint ctd40 dryer even with no water in it can you help
Jul 23, 2010 | Hotpoint Dryers
Hotpoint ctd40 t dryer. wont start just ticking.
Sep 22, 2009 | Dryers
Dryer not heating up
I hate to tell you but get ready for more problems with this drier, it has a bad track record. In some cases cleaning the condensor out and drying the unit well will allow the unit to function again. Once a month you need to empty the condenser unit, this is under the bottom panel at the front of the tumble dryer, you simply pull the panel down, undo the condenser and pull it out (it is normal for there to be some water in the tubes when you do this), you then have to flush the condenser by pouring water through it in either your sink or tub. Make sure that there is plenty of room around the drier and empty the water container often. This curcuitry of this unit it sensitive to high humidity and can cause the unit to not function properly. So with condensing dryers you have to work on keeping them clean. Let me know how it goes. Later DRRXR
Feb 02, 2009 | Hotpoint Dryers
Dryers Logo
15 people viewed this question
Top Dryers Experts
