Question about Konica Minolta bizhub Office Equipment & Supplies
Laser error k
How to clear error C4554
  • Konica Minolta Master
  • 6,359 Answers
What model ######## K is black
Posted on Dec 30, 2015
How do i clear error code c4154 on bizhub c250
Polygon Motor for the Black Print head LASER is bad, the motor is internal to the print head get a new print head for the black, requires tech to install, clear code bye open closing front door.
Oct 17, 2015 | Konica Minolta bizhub C250 All-In-One...
A Malfunction was detected. Please call your technical representative and provide code. C4553
CAUSE: Failed laser unit (C4551 - Cyan; C4552 - Magenta; C4553 - Yellow; C4554 - Black).
SOLUTION: To confirm the failure of one of the laser units, perform the following:
1. Power the copier OFF and remove the power cord from the wall.
2. Switch the position of the laser unit with one of the other laser units.
3. Plug in the power cord and power the copier ON.
4. The failure code should change dependent upon the new location. Replace the laser unit as necessary.
Jul 24, 2012 | Minolta Di251 All-In-One Printer
Error problem no E000061-0002
The laser shutter is faulty. The laser unit is faulty. The potential measurement
PCB is faulty. The DC controller PCB is faulty.
Mode of
Detection
0001 As the result of potential control, the drum surface potential (VL2)
of the white background is about 200 V (generating solid black images).
0002 The primary charging output used for print output and the drum
surface potential after laser output has been made are about 200 V
Feb 13, 2011 | Canon imageRUNNER 5000 Copier
I have problerm with konica minolta c353 .. the error code c4554 showing on display. i cant printing....
this is an easy fix, have you had your fuser replaced recently?? if so then it needs reseated or just do a trouble reset. ask me if you need help with that
Dec 19, 2010 | Konica Minolta Konica Bizhub C353 Drum...
Lanier 5635 error code displaying a SC320
sc320 on the Lanier 5635 is a laser unit error code. Often if you power cycle the machine (turn it off with the orange power switch on the left side of the copier, wait a few seconds, then turn it back on) the code will clear and the copier will resume normal operation. If the error code comes back or doesn't clear, you'll probably need to replace either the entire laser assembly or the polygon mirror motor inside the laser unit. These are best done by a professional -- contact your local Lanier service company if the problem persists.
Oct 15, 2010 | Lanier 5222/27 Laser Printer
XEROX PHASER 7700 ERROR 11
Error 11, laser unit polygon motor failure. If this fault reoccurs 3 times successively the 7700 . enter diagnostics and clear tech rep fault and clear this 09-380, 09-383.
Oct 26, 2009 | Xerox Phaser 7700 Laser Printer
Hı sc 322 laser unut problem ld unut end laser connector poor cable error
Hello sir; Sometime this problem can be reset, just let's try, ; Press " clear mode ", "107", "stop/clear" key until screen show out sp mode then turn power off and back on again.
Oct 11, 2009 | Ricoh Aficio 1035 Copier
Drum and error light are on - got new cartridge - installed as directed - blue light will not stay on - printer will not print - red and orange lights will not go out
I can't recall the buttons on Brother laser printers but leaving the cartridge door open and pressing and holding down one of the buttons for about 5 seconds will clear the drum light error.
I've done this to clear the same error on aBrother HL5250DN laser printer.
If this doesn't work please post your printer's model number.
Sep 21, 2009 | Brother HL 5250DN Laser Printer
Canon laser fax 710 error message 100
e100 is a laser failure.... replace the laser assy
Oct 30, 2008 | Canon LaserCLASS Fax 710 Printer
14 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
