Question about Garden
Ryobi grass trimmer RPT-321 MA shaft - Garden
  • 4 Answers
SOURCE: My new Ryobi boggs down/ stalls as soon as I pull on the trigger.
You should have 2 small adjuster screws next to each other on top of the carb.Try adjusting each of them a little with a thin screwdriver as the engine is running.Put strimmer on the ground first and adjust screws while you are revving engine until it runs correctly.Trial and error and very small adjustments can make quite a difference.Hope this helps.
Posted on Jun 12, 2009
  • 148 Answers
SOURCE: Installing new string line for Ryobi 4 cycle straight shaft s430
Go to www.managemyhome.com and download a free copy of the onwers manual.
Posted on Jul 14, 2009
SOURCE: can not remove trimmer spool
Squeeze the spool cover as you turn.
Posted on Aug 31, 2009
  • 110 Answers
SOURCE: there is no air filter on my Ryobi c430 grass
I had a number of customers tell me that they bought this model at LOwes and had the same answer from them. I think its a planned failure on Ryobi's part. Their reply to me was that they dont need one because they work in a clean environment. I find this to be a stupid answer, I would recommend that you buy an airfilter for an older model that used the donut foam filter and slice it in half to fit in the housing without crushing it and imbeding the air flow, this will help tremendously. Good luck. MY advice from 44 years as a small engine engineer is to buy a name brand product from a company that stands behind them, and never sells them in a box..
Posted on Nov 01, 2009
  • 56 Answers
SOURCE: my ryobi grass trimmer will only run on 1/2 choke
Check for fuel supply problems (clogged cap vent, dirty tank fuel filter, clogged or faulty fuel intake lines, leaky or cracked primer bulb, air leak in rear crankcase cover...check 4 screws above gas tank, air leak in carb gasket...check carb nuts, trashed up carburetor...needs cleaning or rebuild, mixture screws need adjusting)....a myriad of possibilities here but I would guess it's a dirty carb....hope it helps
Posted on Jul 04, 2010
I have a ryobi rpt 320e grass trimmer. my question is when pushing the prime bubble , should fuel come out of the small hole on the plate under the diaphram bowl.
the small hole should have a line attached to it so fuel goes to the carb --the bulb --has inlet from tank to bulb -outlet from bulb to carb
Nov 24, 2016 | Ryobi Garden
My ryobi RPT 321 MA trimmer just turns off whilst running so I don't know if it's failing to pump petrol. What might the problem be?
There are two screws you can adjust for rpm. H for high and L for low. Give that a... wait for it... WACK.
Dec 23, 2014 | Garden
Ryobi line strimmer hedge cutter attachment won't cut even though the blades are moving can you give any idea what he problem might be?
grass,string or vines can get wound around the motors shaft, you will need to take off the spinning head to remove debris from motors shaft
Jul 25, 2014 | Ryobi Garden
What is the fuel mixture for a ryobi rpt-320 grass trimmer?
I mix all Ryobi's @ 50/1 using a good quality oil.
Jul 11, 2014 | Garden
Ryobi rpt 3000 manual
over filled? http://manuals.club/document_order_init.php?search=RYOBI%20RPT-3000&doctype=1
Apr 22, 2014 | Garden
I've lost the user manual for my Ryobi 25cc RPT 2543c strimmer. Can you please advise where the dip stick is to check the oil. Can't seem to find it.
Ryobi RPT 2543c This is a 2 stroke engine, so no dipstick. You mix oil with the petrol (ratio 50:1) or 200ml of two stroke oil per litre of petrol, and that's how the engine is lubricated. Hope this helps, arvidis@btopenworld.com
Apr 19, 2011 | Ryobi Garden
Engine/shaft stopped working. Need to fix Ryobi trimmer.
Hi, I have a Ryobi brush cutter and the engine has a tendency to move up and down the shaft. It also rotates around the shaft
May 16, 2009 | Garden
Garden Logo
114 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
