Question about Skylink Group DM-100 - Swing Door Opener
Remote will not work
New out of box, remote does not work.
Roku remote will not work roku on screen but remote not responding. Green lite flashes on but voes right off but only sometimes.
I presume you have a box and not a stream stick.Try unplugging ROKU box.Many units have a button you have to push on remote after plugging in ROKU box,this connect Remote to ROKU box.If this doesn't work take out batteries in remote and put back in,this has to be done after you plug in ROKU box.Are batteries weak,try some new ones?
Feb 06, 2016 | Roku Televison & Video
I have a Cisco4742hdc set top box and I cannot get the controller to work with the box
If it is the original remote and you can't get it to work, you should take it to repair and if can't be repaired, buy a new one.. I don't believe any universal remote should work for a Cisco4742hdc set top box
May 09, 2015 | Televison & Video
Got a new tv with hd box. my mom did something and the remote dosent control the hd box anymore. it is an lg 47" LED. how do i get the hd box working again
Hello, this is fairly simple to fix. Just follow these simple steps, and that will be working for you real quick!!!!!!!!!!
http://www.dishnetwork.com/SupportSection/remote-setup
Hope this helps!!!
Becki Barned
DISH Network Customer Service
Nov 21, 2010 | Universal Remote Control Dish Network...
I have the new suddenlink little boxes put on my tv by your people. BUT they did not fix the remotes to work with the tv combos (tv and dvd) They will not turn on the tv therefore I must use one remote...
Hi - My name is Tina and I am with Suddenlink. I am very sorry for the issues you are having with the remotes for your new DigitaLink boxes. If you would email me at tina-AT-suddenlink-DOT-com, I would be happy to help resolve this issue. Thanks!
Oct 13, 2010 | Televison & Video
Remote start will not work after dealer programmed a new key.
Yes you need to reprogram your immobilizer bypasskit and depend the model you have it is the program mode, I sugest you go under the dash and try to find out the bypasskit box wich is a small black box like 2"x3"in. and see what model you have.
Jan 23, 2010 | Directed Dei Valet 561r Remote...
I have got a new sky+box and remote. can i use a previous sky remote with my new sky+box and if so, how do i sync it? thanks.
you can only use a previous remote if it is a sky+ remote, original sky remotes will not work with the sky+ box. vice versa
Nov 13, 2009 | Pace Type 30-0060 1121-0369 D1 .060 D2...
Have a new Phillips 42" lcd tv. my cable box remote has been working intermittently. However the white light near the remote sensor on the TV blinks whenever I use the cable remote. after changing bat
your TV and, your cable box both "see" a series of invisible (infared) flashes of light like morse code these flases tell them what to do.one answer is to: buy a universal remote so that you can program a button for each device then when you want to control the cable box just push the "cable" button and, then volume etc. to turn your tv off push "tv" then "off" the service man was right but he should have explained this to you
also your cable remote may be programable to work with your tv like a universal remote check with your cable co.
May 22, 2009 | Televison & Video
New sky hd remote will not operate sky+ box
Dont think so
Try resetting it by this method,it might work
To perform a RESET press [TV] and then hold [select] and [red button] together for around two seconds (until the red light blinks twice). Now press 999 (red light blinks once for a long time and then twice quickly).
Please let me know if this helps
JonnieC
Jan 18, 2009 | Directed 434MHZ Remote Control
Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Nov 21, 2008 | Zenith DBZN-311 Remote Control
Remote Codes for new Sony Bravia
I plugged this code in and it worked:
10000
Good Luck
May 12, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Skylink Group DM-100 - Swing Door Opener Logo
26 people viewed this question
Top Skylink Group Home Security Experts
Lawrence Oravetz
Are you a Skylink Group Home Security Expert? Answer questions, earn points and help others
