Question about Canon Office Equipment & Supplies
Cannot print Legal size on Canon IR2420L
I can't print Legal size paper on Canon IR2420L. It just show please load correct paper message. How can I solve that?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 39 Answers
LEGAL SIZE IS LGL THAT MEANING 8.5/14 INCH. IF YOU WANT TO PRINT CHECK THE SIZE OF THE PAPER, FLSC IS EQUAL TO 8.5/13
Posted on Nov 09, 2014
    Problem Solver:
  • 8 Answers
Is it in just that traY OR ALL TRAYS ,FIRST TRY CHANGING PAPER/TRAYS....
Posted on Apr 22, 2014
SOURCE: CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had the same cr@p of the problem yesterday. The problem was not inthe paper. You have to do 2 simple things, from which one will solvethe problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrectpaper format. Solution is very simple. Open MS word or somethingsimilar, file->print.. and before you print open Properties menu.There for the Output Size will be selected "Match Page Size". you don'twant that (i don't know why it doesn't work), but the solution ismanually select A4, or whatever your page size is.
And there it is... printer starts throwing pages out like crazy :)))
Posted on Dec 27, 2008
I had same thing happen after a fresh Windows install. It was hard to figure out since it had been working fine until then, but luckily it is simple to fix. Open the Start Menu > Settings > Printers and Faxes folder. Then right-click on the Canon MF4100 Series printer and choose Printing Preferences. In there, change the Paper Size to Letter (instead of A4). You may also have to do this in the Print setup for whatever program you're using to print.
Posted on Nov 14, 2008
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
sidathinfo
SOURCE: No legal paper size
no legal paper size
Posted on Dec 30, 2008
SOURCE: won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Posted on Jan 07, 2009
Canon IR1022if copier can't print in Legal size(8.5inx13in) using bypass or even paper cassettee
Did you trying hitting an Ok button, green button, etc to confirm legal size paper, maybe it wants you to confirm paper size. Also legal is 8.5x14, did you select legal or enter the size as a custom page?
May 22, 2014 | Canon IR1022IF 220-240 VOLT, 50/60HZ
How to Print Legal size paper in Canon IR2420L
I purchase the cannon IR2420L machine, But I cannot the legal size paper print. please load correct paper message display.Please help me. Thanking you.
Nov 30, 2012 | Canon Office Equipment & Supplies
When i press to copy it makes print but not all the page..then says load correct paper. down says A4R PLAIN COPY
A4 paper is used in Europe but some documents may be in that size. Try feeding legal size paper into your printer. Your document should be fully printed. Good luck !
Aug 22, 2012 | Canon Office Equipment & Supplies
Have a canon b95 faxphone machine. When receiving legal size documents, it receives and prints on 2 separate sheets. How do I correct so incoming only prints on 1 legal size paper
Use the settings to select LGL as the paper size. (But note that you have to have legal size paper in the machine)
1. Press the Function key (left side, lower right button)
2. Press the Start/Copy key (right side, lower center button). The display will show USER SETTINGS.
3. Press the Left or Right arrows (right side, upper row) until you see PRINTER SETTINGS in the LCD.
4. Press the Start/Copy key
5. Press the Left or Right arrows until you see PAPER SIZE in the LCD.
6. Press the Start/Copy key
7. Press the Left or Right arrows until you see LGL
8. Press the Start/Copy key
9. Press the Stop key (right side, lower right button).
May 18, 2010 | Canon FaxPhone B95 Plain Paper Inkjet
Canon LASER SHOT LBP-1210 Printer how to set legal page
For printing the Legal Size (8.5′x14′) in cannon LBP-1210, follow the instruction:
Step 1- Go to start
Step 2-printer and faxs
Step 3-select printer(Canon LASER SHOT LBP-1210)
Step 4-go to file
Step 5-select Server properties
Step 6-select creat new form (for legal page)
Step 7-give form name legal 1
Step 8-give paper size width 8.50in, hight 14.00
Step 9-give paper margin top 0.30in, left 0.30in, right 0.30in, bottom 0.30in
Step 10-select save form Step 11-then select advanced
Step 12-select informational notifications for local printers
Step 13-select apply
Step 14-then close
Step 15-select Canon Laser Shot LBP-1210
Step 16-select printer
Step 17-select properties
Step 18-select-select forms
Step 19-select change forms
Step 20-select legal 1
Step 21-select OK
Step 22-select apply
Step 23-select OK
Remember: 1 U need to set paper size (8.5′ x 14′) manually in the word documents and befor printing you need to set in printer properties "Legal 1′ for printing. Print preview may not show the whole page but the printer will print the whole page.
All the best.
Apr 24, 2010 | Canon LASER SHOT LBP-3000 Printer
Print legal size paper problem
when you give print command that time chage the paper size from a4 to legal in print proeprties and choose paper size legal.
Sep 08, 2009 | Canon LASER SHOT LBP-3000 Printer
We had problems to print legal and after 30 minutes of trying it finally printed legal. Now we cant go back to letter size so every document prints on legal paper. Can I get clear instruction on how we can...
When you say printing? Do you mean from the computer or are you making copies. If you are printing from the computer you need to change the paper size that you are printing to under the printers properties or the out put tray. If you are making copies just hit the reset button or just manually select another paper tray on the display pannel. Or if you have change a paper tray to leagal size change it back to LTR and make sure the paper is installed the correct direction.
Nov 26, 2008 | Canon imageRUNNER 2200
Legal size paper on LBP-1210
Step 1- Go to start
Step 4-go to file
Step 14-then close
Step 21-select OK
Step 23-select OK
Remember: 1 U need to set paper size (8.5′ x 14′) manually in the word documents and befor printing you need to set in printer properties “Legal 1′ for printing. Print preview may not show the whole page but the printer will print the whole page.
All the best.
PARVEZ [ info(at)parvezbd(dot)com ]
Jun 22, 2008 | Video Cameras
Legal paper
Legal size paper must be loaded into the automatic sheet feeder (ASF) in the rear, and the Feed Switch used to set Auto Sheet Feeder.
For printing, in the Printer Properties (or Printing Preferences) dialog box, select the Page Setup tab, and set the Paper Size to Legal.
May 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
148 people viewed this question
old marine
old marine
