Question about Daewoo Washing Machines
How to change the water sensor of daewoo dwd-1031
I want to change the water sensor of my washing machine. i need the location of the sensor
Master_Tech
  • 770 Answers
SOURCE: Daewoo Washing machine Problem
If it is new then it is under warrty plz call the dealer you bought iy from for service
Posted on Aug 02, 2008
ginko
  • 19396 Answers
SOURCE: Daewoo Washer Error E8
Hi.
E8 is fault connection from CCU (Control board) to balancing sensor.
When you get E8, this is often because of a faulty control board.
Try first disconnecting power for a couple of minutes, to reset the appliance.
If you still get E8, then you need to call a technician. Testing is done jumping the two wires to the sensor to bypass the sensor, then replacing either sensor or control board.
If you want to arrange a repair, then you can call the phone number listed on the machine owners manual.
Regards.
Posted on Nov 08, 2009
SOURCE: Daewoo wash machine air power 7kg Model DWD-F1013.
i bought used but good working daewoo f1013 washing machine in dubai,
i can not spin. no drying. i dont have user instruction manual.
please help
Posted on Feb 11, 2011
  • 6277 Answers
SOURCE: i have a daewoo 7kg
'LE' stands for Lock Error. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Jul 09, 2011
SOURCE: daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Posted on Dec 19, 2011
Daewoo washer DWD-F1011, WATER OVERFLOWING, HOW TO SOLVE THIS PROBLEM???
replace the water shutoff solenoid valve assembly
in the mean time when the machine is full turn the tap off
change the hot water hose over to the cold water tap and use the hot water solenoid button
Sep 05, 2016 | Daewoo Washing Machines
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
I have a daewoo machine model no dwd f 1031 but in my machine detergent remain in detergent case after a cycle why my machine is not taking detergent from detergent case?
the valve to control the water too the tray or despensor isnt right or jammed check the intel filter too the cold / hot water intakes
they both have a little inline at the valve filter catch
take the two filters out
then reconnect the hozes and run a wash thru
this clears any crap
then refit the small filter cones and carry on with clean valves free from crud...!! a tooth brush is handy here
Mar 05, 2015 | Daewoo Washing Machines
E9 message and machine stops
Jayshree, E9 error, pressure sensor error/water sensor error.
Replace water level sensor. The error display disappears if power button is turned off and on.This is what the service manual states.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Daewoo DWD M103 Service Manual Page 15 of 16
Daewoo CV701PC Service Manual Page 26 of 52
Daewoo Washing Machine Error Fault Codes
Washing Machine pressure switch
Apr 20, 2014 | Daewoo DWD M1031
E9 E2 ERROR
Message = E2
Error = OVERFLOW ERROR
Cause & Solution =
The water is supplied continuously due to an defective inlet valve. Change the valve inlet.
The valve inlet is normal, but the water level sensor Change the water level sensor
(sensor pressure) is low. (sensor pressure).
The drain motor does not work - Test and if faulty change the drain pump
Message = E9
Error = SENSOR PRESSURE ERROR
Cause & Solution = The water level sensor is faulty. Change the water level sensor. (remove pressure tube and blow through it to make sure it is clear first)
Mar 10, 2012 | Daewoo Washing Machines
Where is daewoo's company in cairo, egypt? I have any problem with my washing machine.
I have DAEWOO Washing machine DWD F1011. Whithin few years water started leaking through the drive shaft and ball bearing damaged. I need service manual for how to change the ball bearing or is there any repairer in Heliopolis, Cairo area?
How many year the machine is guaranteed??
Thanks lot.
Panchal
Aug 19, 2010 | Washing Machines
My washing machine (dwd-wd32ws) only uses hot water to wash!
hi,
try and switch your hot and cold water hoses around the other way. it should start the cycle with hot and rinse cold.. If it still does it you may have to have it serviced..
jm
Nov 27, 2009 | Daewoo Washing Machines
Daewoo DWD-F1011 PFE error code
Nov 16, 2009 | Daewoo Washing Machines
Washing Machines Logo
27 people viewed this question
Top Daewoo Washing Machines Experts
Paul Bade
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
