Question about Canon imageRUNNER 3030 Black and White Copier
Ir 3030 is not working
Error code E602-0001
3 Suggested Answers
  • 170 Answers
SOURCE: I have a Canon IR
check the fixing thermistor & thermoswitch or thermal heater
Posted on Nov 25, 2010
spinal
  • 287 Answers
SOURCE: IR 3030 error code E000020-0000.
Hello Cg
Well, the code means that the path between the toner bottle and the toner hopper is clogged. In 5 years of dealing with this device I have never seen that to be the case and our company has a pretty big poulation.I also have been working on copiers for 23 years. I can only guess, but have you recently had a new drum put in due to poor copy quality? If so, the installer may have disconnected the connector to the developer unit. We need to turn the main power off (located on the right side.....rear like a light switch) and TRULY power off the copier. Then verify the connector to the developer unit in seated properly. Then power the copier back up. If this does not help then you have have a unique and ugly problem that may require a tech. I hope not, thats why I'm trying to help. Good luck. SPINAL
Posted on May 05, 2011
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
Having error e0024-01. All paper jamed at drum area and before delivery trey . My machine canon ir 3030. Can you help me please
Sounds like there may be a tiny piece of paper stuck in there that is causing havoc with your paper...usually at the sides. Use a flashlight, and check carefully to see if you can find it.
Dec 11, 2016 | Canon Office Equipment & Supplies
IR 3030 error code E000020-0000. I am looking to find out the what this error code means. Thanks in Advance
Hello Cg
May 04, 2011 | Canon imageRUNNER 3030 Black and White...
I have a canon IR 2870 Photocopier it detected error E000000-001
there is something wrong with your copier's fixing unit.FIxing unit is located on upper side of drum unit.you can see when you open copier left door.a caution about heat is displayed there.the main reason of this error is your fixing unit heater not working or its heat is not detected by thermisters.
check all connection , check heater status,check thermister contact or wiring .replace heater or replace fixing unit.
Jan 19, 2011 | Canon imageRUNNER 3030 Black and White...
My hp laserjet 3030 error codes 79
It's an internal firmware error. Power it off wait 30 seconds and power it on. If error code is still there, you will have to upgrade the firmware. If problem persists..replace the formatter.
Jun 03, 2010 | HP LaserJet 3030 All-In-One Printer
I have an HP Lazerjet Model 3030. Recently I have
Here is a link to Hp for your Laserjet 3030. Look under Troubleshooting Fax Codes and Trace Reports. Click on 'Fax send and receive codes'. Scroll down the page to locate each code that you mentioned. I suggest calling your fax number from a cell phone to see if the fax line is clean (doesn't have any noise or static other than the "handshake digital tones") If it does have other NOISE....have the phone company check your fax's phone line for troubles. Let me know.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=378056&prodTypeId=18972&prodSeriesId=378056&objectID=c00062808#A5
Nov 18, 2009 | HP LaserJet 3030 All-In-One Printer
Canon IR 3030 error code 000 002-0000
This code is for the fixing area. I have found that most times it is the lower pressure roller bearings that have seized up and need to be replaced. it could also be the main thermistor has a problem, it would have to be replaced or cleaned ( try cleaning first). on the rare occasion a retaining clip has broken and had jammed the upper roller. The best thing would be to check everything in the fixing area. it is under the yellow cover that gets very hot.
Feb 23, 2009 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER 3030 Black and White Copier Logo
old marine
old marine
