Question about Nikon COOLPIX S5100 Digital Camera
Lense Error I need help with trying to fix a lense error on my Nikon Coolpix S5100. It wont turn on, besides the lense opening, then the screen displaying a "lense error" message. I have tried all the repair suggestions on this blog: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html and none of them worked. so please, any other suggestions, thank you.
dlundmark
  • 797 Answers
SOURCE: Nikon Coolpix L3 51 megapixels lense error
You may not be able to... but may be worth a try.
See my posts on this problem.
Posted on Jun 21, 2008
  • 4 Answers
SOURCE: lens will not open
Try pushing the lens gently inside then side to side. It should zoom right out when turned on. It happened to my S70 coz when my kids played with it dropped it.
Posted on May 23, 2009
iwctoys
  • 126 Answers
SOURCE: Lens Cover Error-Lens Cover will not open
You may have dust or some liquid blocking the cap from opening. Take a q t tip and clean cap. Use the q t tip to try to jar cap loose.
Posted on Jul 02, 2009
  • 8 Answers
SOURCE: Hi, my Nikon Coolpix s210 displays a Lense Error
you should take it do the shop because somthing might be stuck or it could have a malfunction well i dont no exactly i jus say go check it out
Posted on Oct 11, 2009
  • 11967 Answers
SOURCE: My Nikon Coolpix s200 digital camera has a lense error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 03, 2009
Nikon coolpix s230 shows lens error. will not take pic or shut off
please i need help! im only 12 years old and me and my friend were going to put a video on youtube of us singing and then i accidently dropped my nikon coolpix touch s230 on the floor and it wont let me take any photos or vids and is saying "lens error!" i pushed the lens in like a dummy and is really broken. how much money will it cost to get my lense fixed!
Dec 29, 2009 | Nikon COOLPIX S230 Digital Camera
Hi, my Nikon Coolpix s210 displays a Lense Error and the lense extends out, makes noises then retracts with the screen displaying Lense Error. Any help would be appreciated. Thanks
Oct 11, 2009 | Nikon Coolpix S210 Digital Camera
My Nikon 7900 has a lense error. WHEN TURNED ON IT SOUNDS LIKE SOMETHING IS SLIPPING AT THE LENSE, THE LENSE DOES NOT COME OUT, THEN IT SAYES (LENSE ERROR)
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Aug 17, 2009 | Nikon Coolpix 7900 Digital Camera
Lense Error
I have a solution for Nikon coolpix S5/S6. You can try my document "nikon s5 s6 lens cover error repair.doc"  uploaded on site
http://www.esnips.com/web/papputatiyasStuff
Regards Mukesh
Dec 30, 2008 | Nikon COOLPIX S6 Digital Camera
Nikon Coolpix P4 Lense Error
Yeah that's a pretty catastrophic error. Go to a local photographer, they might be able to help fix.
Aug 17, 2008 | Nikon COOLPIX P4 Digital Camera
Lense error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 21, 2008 | Nikon Coolpix S3 Digital Camera
Mar 27, 2008 | Nikon COOLPIX L3 Digital Camera
Zoom Error
this usually happens when you turn on the camera with the lense cover still on. just turn it off and remove the lense cover and turn it back on again. hope this helps.
Mar 16, 2008 | Fuji FinePix S5100 Digital Camera
Nikon COOLPIX S5100 Digital Camera Logo
99 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
