Question about Home
Pcb of white magic 1-2-3 not working - Home
  • US Parts Center
    US Parts Center May 01, 2014
    Hi Narendra Chaudhari, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Need to know what the model number of the control box. What brand of control box? What name on it? Who made it?
Ir 3300 copier error code e000732-0001
Canon iR3300 Error Codes Code: E732-0001
Code
E732-0001
Description
A fault is detected by the main controller PCB in the communication between reader controller PCB and the main controller PCB
Causes
The connector has poor connection. The reader controller PCB is faulty.
Remedy
1. Connector, Reader controller PCB Is the connection between the connector J1014 on the main controller PCB and the connector J409 on the reader controller PCB normal? NO: Correct the connection. YES: Replace the reader controller PCB.
Below is the site this came from which lists all the error codes in case another occurs after you resolve this one
Canon iR3300 Error Codes List page 1 from 12
Aug 27, 2016 | Canon Ir 3300 Black & White Copier
Magic Chef Dual Zone Beverage Cooler...top zone works, bottom zone stopped working
What is the model number I can only guess to an answer not having the model number. Check the voltage that was feeding the bottom fan and top fan
Contact Me Here
Appliance 911 Sea Breeze
Nov 18, 2015 | Refrigerators
Error code E000064-0000
E064-0000 Description The presence of a high-voltage error is communicated by the composite power supply PCB (The output for primary charging, developing, or transfer has deviated from a specific level of voltage) Causes The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty. proce Remedy 1. Contact Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact? YES: Clean the contact, and set it once again. 2. Wiring Is the wiring between the contacts for the following normal: DC controller PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller? a. DC controller PCB (J301) <-> composite power supply PCB (J136) b. composite power supply PCB (J130-7) <-> primary charging roller contact c. composite power supply PCB (J130-1) <-> developing assembly contact d. composite power supply PCB (FT133) <-> transfer roller contact NO: Correct the connection. 3. Composite power supply PCB, DC controller PCB Try replacing the composite power supply PCB. Is the problem corrected? YES: Yes. NO: Replace the DC controller PCB
Nov 19, 2014 | Canon Ir 3300 Black & White Copier
The solution for an error code E000733-000
E733
0001 A fault is detected by the main controller PCB in the communication between
the DC controller PCB and the main controller PCB.
Main cause The connector has poor connection. The DC controller PCB is faulty.
Action
1. Connector, DC controller PCB
Is the connection between the connector J1015 on the main controller PCB
and the conductor J316 on the DC controlled PCB normal?
YES: Replace the DC controller PCB.
Jun 29, 2014 | Canon imageRUNNER 3225 Black and White...
Magic Chef Microwave has stopped working. None of the buttons work. It's showing random numbers when you plug it in. I tried a different outlet and it gave me different numbers.
Try unplugging it for 24 hours. Plug it back in and see if this helped. If it's still the same, it needs a new control PCB (printed circuit board).
Oct 16, 2013 | Magic Chef Mcd1811st 1.8 Cubic-ft,...
Canon ir 3300 error code e000803-0000
Similar to Description The 24V output from the composite main power supply PCB is absent for 1 sec or more Causes The wiring is faulty (short circuit, open circuit). The composite power supply PCB is faulty. The DC controller PCB is faulty. Remedy 1. Connectors Are the connectors J204 on the main power supply PCB and the connector J300 on the DC controller PCB connected securely? NO: Connect the connectors securely. 2. Main power supply PCB Is 24 V supplied by the main power supply PCB (J204) to the DC controller PCB (J300)? (J204-5 <-> J300-5: OVU3, J204-6 <-> J300-6: OVU3, J204-7 <-> J300-7: 24VU3, J204-8 <-> J300-8: 24VU3) NO: Replace the main power supply PCB. YES: Replace the DC controller PCB.
Aug 21, 2012 | Canon Ir 3300 Black & White Copier
Como soluciono un E302 en una IR3300
E302
0001 During shading, the shading processing does not end on the reader controller
PCB after 1 sec.
0002 During stream reading, the edge white addition processing does not end on
the rear controller PCB after 10 sec.
Main cause The CCD PCB is faulty. The wiring is faulty (short circuit, open circuit).
Action
1. Connector
Are the connectors (J6001/J6002) on the CCD PCB and the connectors
(J5002/J5003) on the reader controller PCB connected securely?
2. CCD unit
Try replacing the CCD unit. Is the problem corrected?
YES: End
3. Reader controller PCB, Main controller PCB
Try replacing the reader controller PCB. Is the problem corrected?
YES: End.
NO: Check the wiring; if normal, replace the main controller PCB.
i hope it will be help full to u.
Mar 06, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Error261 in canon copier
E261
0000 The intervals of zero-cross signals deviate from the tolerance range while
the fixing heater is supplied with power.
Main cause The wiring is faulty (short circuit, open circuit). The main power supply
Making Corrections
1. Connectors
Are the connector J205 on the main power supply PCB and the connector
J308B on the DC controller PCB securely connected? (zero-cross signal:
J205-7 <-> J308B-1)
2. Main power supply PCB, Main controller PCB
Try replacing the main power supply PCB. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Feb 22, 2009 | Canon NP 7130 Black and White Copier
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
