Question about Karcher Garden
No power to my karcher power washer
Have changed the fuse but still dead
    Habit-Forming:
  • 78 Answers
DO YOU HAVE A GROUND FAULT PLUG ON THIS UNIT. CHECK THIS FIRST
Posted on Jun 14, 2014
3 Suggested Answers
  • 92 Answers
SOURCE: karcher washer went dead
Dear jimbocom,
The problem is that the spill valve got stuck. When the machine is working and the gun is closed, a valve( spill valve) moves with the accumilated pressure and switches the machine off. So what happened is that when the spill valve did its job, it found no water...and remained stuck. This leaving the machine in an off position. Service and lubrication to the spill valve must be done or completely replacing with a new spill valve. In my opinion you have no serious damage, but this job must be carried out by an expirienced technician.
Regards,
MG.
Posted on Nov 05, 2008
  • 57 Answers
SOURCE: I have a karcher pressure
you will have to take the cover off & look for melted wires or a fuse.
if there is no fuse the capacitor may have been cooked.
it should be a white cylinder.if it has been damaged it will have burn marks and may be swollen.
replace the capacitor and it should start.
Posted on Dec 20, 2010
Hi, My karcher 5.86 has suddenly stopped working. No power/ noise from washer when power is switched on. Fuse & source is obviously fine. Im going to obtain relevant torx screwdriver this week to open...
If its not the fuse in the plug it might be the on/off switch. I would check switch for continuity with a multimeter to rule it out first.
Feb 01, 2015 | Karcher Garden
Have a karcher k7.85 electric power washer .it won't turn on, or let water flow through gun nozzle. Checked fuse,and water pressure. Both fine.gave one attempt to start when I pressed trigger, then...
your going to have to email the company directly so that you might get it replaced if you have warranty on the product here is the email address and phone number enquiries@karcher.co.uk & 01295 752 000
Aug 14, 2014 | Garden
Karcher 4.91 checked fuse that is ok but no power
Check and see if you are getting power to the on/off swith. These switches have been known to go bad. Also, check the Ground fault breaker in the plug. Let me know how you make out.
Jul 26, 2011 | Karcher K2.26 Electric Power Washer
Will not switch on karcher 520M, have changed fuse
You have to see if you are getting power to the switch with a volt meter you should be getting 110 volts.
Mar 20, 2011 | Karcher Garden
I have a karcher pressure washer 1800 psi i bought from walmart it was running good until i had a power surge with the plug in. what can i do can i change the fuse in the plug or do i have to open the...
Dec 19, 2010 | Karcher PSI Electric Pressure Washer
Karcher K2.36 Pressure Washer I've just fired up my Karcher for the first time since last year and the motor started running fine, I then switched on the tap to allow the water through and the motor cut...
The water must be switched on, and seen to be running freely from the nozzle for a few seconds before switching on the power - suggest you check the fuse in the plug, and then try the above.
Apr 17, 2010 | Karcher K2.26 Electric Power Washer
Karcher washer went dead
Dear jimbocom,
Regards,
MG.
Oct 17, 2008 | Karcher K2.26 Electric Power Washer
Pressure washer karcher
Sounds as simple a fix as " The Fuse Has Blown "
Check the fuse in the plug, and it,s Rating.
I,d assume this should be rated at 13 AMPs.
If the fuse is 3-5 amps it,s under-rated.
You should get it tested out if your not electrical minded, you may have a short circuit. live/earth et.c.
hope this helps.
Mike @ Compurepair.
Mar 26, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
147 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
