Question about Torin Big Red Asymmetrical Two-Post Lift - 10,000-lb. Capacity, 73in
BOUGHT A TORIN BIG RED 2 POST LIFT 4 TON AND WANT TO CONNECT THE ELECTRIC BUT THERE IS NO DIAGRAM HOW TO CONNECT THE CABLES CAN YOU SEND ME A DIAGRAM HOW TO CONNECT THE CABLES.
NEED DIAGRAM TO CONNECT THE ELECTRIC CABLES
How do i connect the electric cables that lift works
Could you take a photo of the switch board for our reference?
Apr 25, 2014 | Torin Big Red Asymmetrical Two-Post Lift -...
Lift will not work
There is either air in the system, not enough fluid in it, the valve that lowers it is not closed or the orings are bad.
Dec 06, 2013 | Torin Jack Jacks Big Red Motorcycle Jack...
Won't build psi. When I purchased it, it worked fine. Tested to 5 ton. Let press sit 2 months and now it moves the ram but won't build psi
sounds like oil leaking back to reservoir under pressure when u pressure it up can u feel and hear like a hissing noise this is oil being passed back from ram u need to replace all seals,.....Easy to do
Sep 28, 2013 | Torin Big Red Hydraulic Shop Press with...
Air doesn't drive press
I suspect that you will need a pneumatic pump to replace the hand pump to get this to work as you need a multiplier to get the pressure high enough to make the press work at full pressure.
Jun 06, 2013 | Torin Big Red Hydraulic Shop Press with...
I don't get this product. How does it work?
You purchased jack stands, they aren't intended to lift the car, merely to support them after you've raised the car with a jack.
Apr 30, 2013 | Torin Big Red Torin Double-Locking Ratchet...
Big red 10 ton body jack would not extend ram
problems come to mind Firstly the release valve will not tighten to seat the ball to stop the oil from recirculating and so not pump up the ram. Second there is no oil in the jack reservoir to pump up with. I would check oil level first.
Mar 31, 2013 | Cars & Trucks
How do you lower the torin 2 ton jack?
It worked well, and slowly let the vehicle down if you didn't twist the handle too far. The lift height is really good (21in) and it has the quick release handle which I have on mine. Torin Heavy Duty 2.50Ton Quick Pump Service Jack features a safety overload system to prevent use beyond the rated capacity which makes it highly reliable and a two piece handle for easy transportation and storage. It also comes with steel casters for longevity, 2 inch HD wheels and an oversized saddle. Its patented Quick Lift design has dual return springs, with roller action and a flange body. The service jack has a lifting range from 5.5 inch to 21.1 inch.Read More
May 09, 2011 | Car Audio & Video
Torin Big Red Asymmetrical Two-Post Lift - 10,000-lb. Capacity, 73in Logo
Top Torin Big Red Heavy Machinery Experts
Tom Chichester
Bill Boyd
ray gallant
Are you a Torin Big Red Heavy Machinery Expert? Answer questions, earn points and help others
