Question about Cyberhome CH-DVR1500 DVD Recorder
The dvd rom does not open. takes a long time to actually turn on and after is on the dvd rom doesn't open. is there a solution?
  • 2 more comments
  • andre 123 Jan 02, 2008
    Yes I cannot get the dvd door to open at all any help would be greatly appreciated.
  • entertainme Sep 15, 2008
    dvd player won't open even after I unpluged it and tried the solution above. shows "open" then " no disc" but won''t open after several attempts
  • Anonymous Oct 15, 2008
    ii cant open th tray no matter how many time ii press th button.
    and th light just keep on flashing.
  • dasme2004 Jan 19, 2009
    When I press the eject button the dvr reads "no disc" but does not open to load the dvd. I turned off the switch in the back and tried again, but the same thing happened. Please help.
  • 1,285 Answers
It doesn't reconized the dvd-rom, but to open it, unplug it for 30-45 seconds. plug it back into the power strip/wall. At that same moment tap (2/3 times) the stop/eject button . do not press play (it will try to load automatically) . try it once more (if it do not open, this time a full minute) presto it should open.
Posted on Nov 25, 2007
I have not used my LiteOn DVD Recorder in a couple years and I am trying to record a DVD but every time I push the power button it comes on normally then I try to open it to insert a DVD and it will not...
okay you need to take your DVD to a repair tech.what happen since you have not used over some years the solder on the circuit board might have gotten corroded causing minimal current to pass through the other words your DVD siezed up.or probably you might have to in vest in a new DVD recorder.. if you dont use your electronics product for a period of time that will happen.electronic items needs to be used offten. good luck.
Sep 25, 2011 | Lite On LVW-5101 DVD Recorder
How can I fix a CD Writer or a DVD rom when It's
Make sure that the CD/DVD has the power light on. Try and use the ermergency hole a few times to open and close the unit. This will sometimes get the unit back in sync with the gear mechanism. If that does not work, take the unit out of the tower and remove the case. Usually the ribbon and power cables are long enough to hook up the unit on the desk next to the tower. Inspect the mechanisn to see that the parts appear to be synced and then use emergency hole a couple of times. This has worked for me several times. I just did it last month on a friends computer. If this doesn't fix the problem, it's possible that the button you push is bad. Hope this will help you. UAW 974
Jun 24, 2011 | MSI CR52-M CD-RW Burner
My dvdw/r is not working properly,led is blinking continously
Actually u have to buy for a new and better cd rom, but if ur in tight situation the only solution is FiX it urself! I always do this, going at the junkyard and pick some cd rom.!
Open ur cd rom, u will see the lens, in the side of the LENS assembly there are 2 fine tuning resistor adjuster, use a precision screw driver(wutever that can fit on it), mark the adjusters before turning it back and forth. Just like ur cleaning up the contact point.After that return the adjusters to the original position!
Thats it! It will work fine now!
Hope that helps u out!
Nov 20, 2010 | LG DVD-ROM Drives, DVD Readers:...
I have a HP dvd/cd rom rw 1040d disc drive. The disc tray doesn't open when empty. It tries to open but doesn't manage to open. If I manage to get it open, (Usually manually when shut off, it will open...
Premature failure of this drive appears to be a widespread issue. I have joined in a support thread at HP and encourage you to do the same:
Sep 29, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
A dvd rom is looking the dvd player!
First of all you need to try unpluging cable and plugin it back in after 30 seconds. If this doesn't help then you should try manually taking the dvd out of the player while unplugged...
Jan 06, 2010 | Pioneer DV-350 DVD Player
Panasonic dmres30v unable to open dvd drawer led displaying u99 and cant remove
Press the power button on the main unit to switch the unit to standby. When the unit is in standby , press the power button again on the main unit to turn it on. If the unit doesn’t switch to standby, press and hold the power button on the main unit for about 10 seconds to forcibly switch it to standby.
To open the drawer, press and hold STOP and CH UP buttons on the main unit at the same time for about 5 seconds.
Nov 27, 2009 | Panasonic DVD-S35 DVD Player
My computer doesn`t recognise disk in dvd drive
1. Make sure you use DVD's in good condition.
2. Reinstall the driver..( right click My Computer->properties->Hardware tab -> Device manager-> DVD rom-> right click Uninstall and again install using Dvd rom driver cd)
3. Clean The Drive lens using Dvd lens cleaner disc kit available in maket.
4. Removing DVD rom. opening it up manually and cleaning the lens with cotton( this tedious for novice users.. instead give it to servicing shop)
May 20, 2008 | Toshiba Computers & Internet
DVD stuck
Replace the drivebay of the Bose AV3-2-1 If the drive sticks, or does not open, or If you receive an error of NO DISK, or any indicator that the disk is not properly recognized clean the lens and if still doesn?t work then the DVD drive is bad. You can actually use one for a desktop PC with a few part swappings. Check that the drive is a Toshiba SD-M1612 it is printed at the bottom of the drive bay. To use this SD-M1612 as a replacement you will simply have to swap three external parts. Remove the 3 parts from the bad Bose drive bay: Remove the 4 bottom bolts, lift cover, if the DVD bay door is locked then insert a paperclip into small hole in the front. Slide DVD tray out and remove the PC style DVD ROM tray facing. 2 clips hold it on pry them out and slide the facing up and off. Now remove the face of the drive bay. It has several clips. Save these three components (top cover, face, and tray facing) to add to the new Toshiba SD-M1612 DVD bay. Remove the old and installation is the reversed procedure above. also remove the small clear LED bezel from the new drive before adding the face. It works fantastic.
Mar 26, 2007 | Bose 3·2·1 II System
Open Questions:
See all Cyberhome CH-DVR1500 DVD Recorder Questions
Cyberhome CH-DVR1500 DVD Recorder Logo
824 people viewed this question
Top Cyberhome Televison & Video Experts
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
