Question about Indesit Dishwashers
Detergent dispenser doesn't open
I have an Indesit DFG261 dishwasher. The last couple of times I have run the machine the detergent dispenser has not opened even through the machine has run through it's who cycle. Any ideas on what is wrong and how to fix?
  • Indesit Master
  • 3,247 Answers
There is a solenoid in the detergent dispenser that opens at the appropriate time to let the door open and drop detergent. The solenoid might be faulty if the door spring appears alright. One option is to stop using the powder detergent and switch to tablets. One tablet like Finish diamond in the cutlery basket does wonders.
Not sure if you can buy the dispenser to replace.
Posted on Apr 23, 2014
  • 76 Answers
SOURCE: maytag mjd 2005dishwasher
Try what my wife does. She uses the individually contained detergent/rinse bubble packs (tab packs). No messy granular detergent and easy to simply place inside the silverware basket. Your dishes should wash spotless, like ours. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 19, 2007
SOURCE: Indesit D61D
I had the same problem and a repairer said to just throw the dishwash tablet in the bottom when loaded. This has worked fine for last two years and doesn't seem to have made much difference.
Posted on Aug 29, 2007
hotuna
  • 288 Answers
SOURCE: miele G660 premier dishwasher
There is a solenoid that opens the door to the dispenser. You can check it with a volt/ohm meter. Sometimes large dishes can block the door keeping it from opening. I personally know on some Whirlpool washers (because it was mine) that if the bottom drawer is put in backwards, it wont let the door open. When I opened the main door, then the dispenser would flop open. You need a meter to check this part if its not the other things. Without it, you are just guessing.
Posted on Mar 15, 2008
Todd_pdx
  • 22 Answers
SOURCE: detergent stays in the dispenser
Clean and dry your dispenser prior to filling with detergent.
Use only fresh detergent.
Do not place anything ie. cookie sheets, cutting boards in the path of the water obstructing the dispenser.
Do not allow anything to fall between the racks and stop the spray arms from turning.
Always turn the hot water on at the sink prior to starting you dishwasher they use less than 2 gallonsof water in the initial cycle and they require 120 deg f water. Unless you have hot water recirculation in your home.
If you have low water volume or low water pressure due to bad impellor or windings in circulation pump. The water volume or pressure will be insuficient to reach the dispenser.
Posted on Mar 31, 2009
VtToolMan
  • 704 Answers
SOURCE: Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Posted on Jul 31, 2009
Detergent lid opens, but undissolved detergent streaks down door and dishes aren't clean.
5 results (0.58 seconds) Search Results
    Support - Dishwashers DW80F600UTS/AA ' Samsung ...
    www.samsung.com > Home > Support > Dishwashers
    Samsung ElectronicsVisit Samsung today for DW80F600UTS Top Control Dishwasher with Stainless Steel Tub (Stainless Steel). You'll find product and support information for our ...Missing: black ‎undissolved ‎streaks
    Dishes still dirty - dishwasher ' Ask MetaFilter
    ask.metafilter.com/145865/Dishes-still-dirty
    Feb 13, 2010 - If they use dry dishwasher detergent, some of the undissolved dishwasher ... (part of the pump of the dishwasher) breaking down or some piece ofblack plastic (often a ... Every single dishwasher I've ever worked on had a built inwater heating element. ... That's all we use and never get spots on our dishes.Missing: samsung ‎dw80f600
Jan 19, 2016 | Samsung DW80F600 24" Black Built-In...
Dispenser door not opening, therefor tablet not being dispensed nor is rinse aid
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 04, 2011 | Indesit 23 in. DV62 IX Built-in Dishwasher
My office's GE QuietPower 3 dishwasher detergent
heatman101
Jul 29, 2011 | Maytag Dishwasher
The detergent compartment on our dishwasher will open during operation. We have run the dishwasher three times and the detergent capsule remains in the compartment and is only partially dissolved. It...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these.
Hope this helps...
Daniel
Apr 18, 2011 | KitchenAid Dishwashers
Hello What does the error code A13 represent. The soap dispenser seems Ok. Could it be related to something else. The machine starts up Ok, but about 6 seconds into a cycle A13 flashes up and the...
As you correctly pointed out A13 error is linked to the failure of the detergent dispenser lid operation.
If the lid is not opening at the correct time in the wash cycle, then the detergent will not be getting dispensed.
Either the controller circuit that operates the lid is faulty or the lid solenoid is faulty.
You can check the parts at this site.
Mar 20, 2011 | Indesit 24 in. DE73 Evolution...
Why does a lot of detergent remain in the soap dispenser after a washing cycle is complete
Was the dispenser cup wet when you added detergent?
Make sure the dispenser cup is dry before adding powdered detergent. If dispenser cup is wet, the detergent can clump.
Is the cycle incomplete?
If the previous cycle did not complete, the detergent can become caked in the dispenser cup if it is left sitting in the dishwasher.
Is the detergent old?
Older detergent exposed to air will clump and not dissolve well, which will cause the dispenser door to stick to the detergent. Replace detergent if necessary and store the detergent in a tightly closed container in a cool dry place.
Is the water temperature too low?
For best washing and drying results, water should be 120oF (49o C) as it enters the dishwasher.
Were items blocking the dispenser that kept it from opening?
Items blocking the detergent dispenser will keep it from opening. Make sure water action can reach the dispenser.
Detergent guidelines
  • Use automatic dishwashing detergent only.
  • Other detergents can produce excessive suds that can overflow out of the dishwasher and reduce washing performance.
  • Store tightly closed detergent in a cool, dry place.
  • Fresh automatic dishwasher detergent results in better cleaning.
  • Add detergents just before starting the cycle.
  • The amount of detergent to use depends on the hardness of your water and the type of detergent.
  • If you use too little, dishes won't be clean.
  • If you use too much in soft water, glassware will etch.
  • Suggested fill amounts are for standard powdered detergent. Amounts may vary if you use liquid or concentrated powdered detergent. Follow instructions on the package when using these detergents.
  • Water hardness can change over a period of time. Find out your water's hardness by asking your local water department, water softener company, or county extension agent.
Nov 25, 2010 | LG Washing Machines
GE Triton XL
Try placing a packet in the bottom of the DW and then start a wash cycle ( use the energy efficient cycle that does not use the heater to dry the dishes..).. if it is not disolved at the end of the cycle then your water temp may not be hot enough..Hope that helps..
Aug 28, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Detergent accidentally put into rinse dispenser
You need to use something to siphon the detergent out of the dispenser. I have plastic syringes for this type of purpose. You don't use the needle attachment.
If you cannot fit the syringe into the opening, then you may try to use clear plastic tubing to syphon out the detergent.
Once the flow of detergent stops, you should then use warm water to rinse the residue. If you have the syringe, you could use it to force water into the dispenser.
This may take a little time, but it is better than trying to disassemble stuff!
Good Luck
Brian
Jan 10, 2008 | Kenmore 24 in. 16463 Built-in Dishwasher
Dishwasher not cleaning well
The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. Good luck!
Aug 17, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit D61D
the solenoid has gone you will need to replace the soap unit. meaning panel off of door and removing unit.
Jan 13, 2007 | Indesit 24 in. D61 Free-standing...
Dishwashers Logo
233 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
noel
noel
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
