Question about Garden
Briggs & stratton rover lawnmower 14500 212009900207
While replacing pull cord spring jumped out
  • 376 Answers
SOURCE: Briggs and Stratton Governor Linkage problem
The easiest thing for you to do is look at any 12.5-19hp Briggs single cylinder engine that's on just about any riding mower.. They all have the same set-up.
Posted on Jun 10, 2009
  • 1111 Answers
SOURCE: I have a briggs and stratton lawn mower ad the pull-cord is stuck
make sure nothing is jammed around the blades...if thats ok, remove the pull cord housing and try and spin the engine. if it doesnt turn, the motor is locked up and needs repaired
Posted on Jul 10, 2009
  • 61 Answers
SOURCE: 5hp briggs & Stratton lawnmower
ck fuel pump its on the side of the carb
3or4 screws hold cover on .
Posted on Sep 06, 2009
  • 468 Answers
SOURCE: Pull cord broken. After removing red hood and
You don't need to remove the rivets. There should be two metal tabs that bend over the nylon retractor, or it'll have a screw in the middle of the retractor pulley inside the cover. you bend those up a little, or remove the screw, remove the retractor, be careful, because that spring can be fun if it gets away from you, take the old rope out, put the retractor back in place, wind it back as far as you can, feed the rope in, tie the knot, and let it draw the rope in. Put everything back like you found it, and your pull rope if fixed.
Posted on Mar 12, 2010
  • 24 Answers
SOURCE: Lawn mower won't start
to check for firing remove the spark plug insert it in the plug boot and pull the rope while watching to see if the plug sparks be carefull not to touch the plug electrode while pulling the rope or it will shock you. If you don't have a spark, try a different plug. If still no spark the coil could be bad.
Posted on Jun 30, 2010
Rover QuantumXTL 50 mower wont idle
clean the carby or could have bent governor arm where spring goes
Feb 03, 2013 | Briggs & Stratton Briggs Stratton...
Start cord will not wind back
make sure your blade brake in dengaged or the spring is broken or dirty inside starter coil houseing
Jun 17, 2012 | Briggs & Stratton Briggs Stratton...
Lawnmower blade hit a stump now can't pull starter cord
sheared timing flywheel key replace it check to see if crankshft bent if throw it away or replace motor
Apr 01, 2012 | Briggs & Stratton Briggs Stratton...
The pull start on my Champion Chain Saw does not re-wind. How may the problem be rectified? Many thanks.
This is a messy frustrating job, and if you had to put a price on the hassle that it is, it is probably better to pay somebody else to do it. That said, remove the starter cover with the cord and pulley inside. If there is a plate holding down the cord pulley, remove it and carefully lift out the pulley, try not to dislodge the recoil spring as this is where the frustration part comes in. Remove the old cord and insert the new cord end into the hole and copy the old knot - pass the other end of the cord through the eyelet in the cover. N.B. At this time take note of the direction that the recoil spring coil is orientated. Wind about 3/4 of the cord around the pulley and attach the start handle to the outside end of the cord. Carefully fit the pulley over the spring and place the cord into the cutout in the pulley. Wind up the pulley so that it engages in the curl in the inside of the recoil spring and further wind up the pulley in the opposite direction of the normal pulley start pull, holding the cord in the little cut-out so that the cord does not wind up as you wind the spring. It probably takes about 5 extra turns on the pulley to get the recoil tension right. Always hold the pulley in place to prevent the spring from jumping out. Release the cord so it can retract and replace the retaining plate. This is all if the spring does not jump out - which it so often does.
If the spring jumps out, hold it by the inside portion and start winding it up, pulling it tight to keep the coil small enough to fit back into its receptacle, . Once the spring is wound up and will fit into its position the problem starts. I found that gripping the spring with an alligator jaw vice grip will allow you to replace the spring and carefully release it without it going wild again, engaging the outer hook in its retaining slot or around its peg. Trying to feed the spring into position coil by coil seldom works, it has to be wound up outside and then inserted, especially on a small motor.
This procedure is as difficult to explain as it is to carry out. I have done many cord replacements and always dread the next one. If you have any problems, feel free to come back to me.
Jul 21, 2011 | Garden
My pull cord will not fully retract - and mower will not start - I would like to repair the pull cord but cannot figure out how to remove the assembly
Jul 16, 2011 | Garden
NEED TO CHANGE PULL CARD ON RH2660DA HEDGE TRIMMER
Jul 11, 2011 | Ryobi Garden
How do I repalace the starter cord
Jul 04, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
