Question about Siemens Microwave Ovens
Siemens micro wave door won't open - Siemens Microwave Ovens
MicrowaveSvc
  • 9098 Answers
SOURCE: advantium micro wave
This is usually caused by either a bad door switch, a loose door switch mount, or a loose or misaligned door hinge.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 20, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Bottom part of door to
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
You should be able to replace just the affected door panel and save money as well as the hassle of complicated door alignment and leakage tests.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Posted on Nov 28, 2008
heatman101
  • 43501 Answers
SOURCE: Micro wave door closes but micro wave doesn't work
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Aug 30, 2010
  • 4088 Answers
SOURCE: when micro wave oven is
Not likely if the door seals are intact, clean, and the door is latched. The pin-holed screen that you can see through stops the microwave energy. Hope this helps!
Posted on Jan 25, 2011
  • 6771 Answers
SOURCE: after closing door micro wave turn table continues
The problem is most likely caused by a defective door switch, and should be rectified for safety reasons.
Posted on Apr 05, 2011
I have a emmerson 1000 watt microwave its about 3 or so years old. it stays on even when the doors open. so when its done and u take it out, it keeps on going around?
micro-switch if faulty or in stuck position thinking that it is okay to start/run microwave . these machines are mostly made in china and are sensitive of slamming the door too hard the plunger that insets into wave there is a micro-switch, you will have to take apart the wave..sorry ..
Oct 14, 2017 | Microwave Ovens
Micro wave comes on at times when the timer is not set and door shut, no problem if doo is left open
I think you will find it is either faulty door switches or a misaligned door catch.
Hope that helps.
Feb 27, 2011 | Magic Chef CMV1100 Microwave Oven
When micro wave oven is in use, I can feel air coming from the door. is it leaking micro waves?
Jan 25, 2011 | LG LMH1017 Convection Microwave Oven
My Emerson microwave is about 2 years old. I washed it just like I do every week and the power went out on it.
you mean it want power up or want work when you press the star buttom?
1. check the fuse if no power.
2. If it doesn't work when closing the door after setting timer it is the micro switch that the metal lach hits when the door close.
3. unpluge the micro wave unscew the scews to the cover of the microwave remove the cover. up front by the door you will see the micro switch maybe (brown,black,white,red/white ) what ever color it is disconet it take it to the hardware store buy a new one and replace it,themreasemble your micro wave.
Oct 30, 2010 | Emerson Microwave Ovens
heatman101
Aug 30, 2010 | Sanyo EM-A5200SW Microwave Oven
Micro wave stopped heating. All other features
Check the door safety interlock switches. Magnatrons are pretty tough but the little switches are not.
Mar 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Hotpoint micro wave makes funny noise and doesn't heat up food
Check door switches ... particularly if you are guilty of opening the door while the oven is in operation (door safety switches are probably cooked ... no pun intended)
Let me know if you need more help
a
Oct 07, 2009 | Microwave Ovens
Micro wave broke
open the door and look on the middle top right inside the microwave is it burned or blackend?You have a faulty magnatron.if it is.
May 19, 2009 | Magic Chef MCD1311ST Microwave Oven
Stuck door latch
no call a tech micro-waves can be dangerous to work on
Dec 22, 2007 | Whirlpool GH8155XJ Microwave Oven
Microwave Ovens Logo
83 people viewed this question
Top Siemens Microwave Ovens Experts
William Miller
William Miller
Steve
Gerry Harvey
Gerry Harvey
Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
