Question about Canon PIXMA MP610 InkJet Printer
Printer error 5400
After cutting power during 30 sec printer remains in the "printer error 5400" status
Have lost router use in win 7 router works but will not connect to net
Best way is do a factory reset.Press and hold reset button during this procedure ,do not release the button until you are finished and you will be back to factory default.
1)Hold button 30 sec.
2)remove power cord hold 30 sec.
3)plug in power cord 30 sec.
You should now be in default factory mode,good to go.
Go to Windows,control panel,view network and status and see if it is there.If that fails go to control panel,system and security,fix problem.If that fails go to control panel,system security,system,device manager and find your device.Left click on it ,remove device ,go to top of page right click on very top icon and scan for devices or you may need to click on legacy device.This should resolve your issue.Good luck
Sep 09, 2013 | NetGear WGR614 Wireless Router
Hi.
if you mean not online. try to disable the snmp status in the driver
May 31, 2013 | Office Equipment & Supplies
Netgear wnr834b v2 not working cannot connect wirelessly error message reads 192.168.2 is managing this device
reset to factory default
press and hold reset button during the whole process and only release when completed.
1)press reset button 30 seconds
2)remove power cable 30 sec
3)plug in power cable 30 sec and then release.
You should no be set for 192.168.1.1
username admin
password is password
Apr 28, 2012 | NetGear Computers & Internet
Display reports: Problems in inksystem. Error no: 0xc18a0306 What do i do?
error detecting ink volume and will need to be cleared by resetting your printer. here are the two ways to reset it.
Reset to default setting
1. While your printer is on, unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ", press "#" key and then release both keys."Enter Special Key Combo" will be displayed.
3. Press "1", "2" and "3" to display Support.
4 Press ">" right arrow button and release when System Config Menu appear, then click OK
5. Press arrow key to display Hardware Failure Status, click OK.
6. When Hardware Failure Status:Clear appeared, press "OK" to clear.
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".
9. The last part is to turn off the printer and unplug at the back, wait for 30 sec, then plug and turn on the printer, if asked, press "OK" to continue and allow the "One Time Ink Initialization" to procede..After this try to print
Don't forget to rate this answer.
Thank you for using Fixya.
May 26, 2011 | HP Photosmart 3210 Printer
Printer error error code 3807
From the kodak website:
Error "System status failed" (3807)
How do I resolve the error message "System status failed" (error code 3807)?
To resolve the error message "System status failed" (error code 3807):
Disconnect the power adapter from the printer.
Wait 30 seconds to allow the printer to reset.
Connect the power adapter to the printer. Turn the printer on if necessary
If the error continues:
Open the printer access door.
Remove and install the printhead two times.
Close the printer access door.
Wait until the printer is ready to use.
If the error is resolved, upgrade your printer's firmware.
If the error is not resolved, contact kodak.
Hope this helps
Jan 09, 2011 | Kodak ESP 5 Printer
What does error oxc18a0106 mean?? I have replaced all the ink cartridges this afternoon and still won't print
Full reset
Sep 11, 2010 | HP Photosmart 3210 Printer
Laptop won't start-up
Can you tell me if the status lights on the power adapter and/or the battery turns on? Because you are telling me the status lights only stay on for 30 seconds, this should be a power connection problem.
One other possibility: can you tell me the climate environment of where you use your laptop?
Nov 16, 2008 | Dell Inspiron E1505 Notebook
Error code on 5300 printer
unplug the power chord at the back of the printer
wait for 5-10 sec.
replug power chord
turn on the printer
Jun 12, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Error 5400
the 5400 error is telling you there was excessive temperature in the printhead, and this error code will stop all printing attempts.
Unplug the power from the printer and leave it off for a hour and then check the pins inside the carriage and clean them and clean the contacts on the back of the head.
May 31, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP610 InkJet Printer Logo
old marine
old marine
