Question about Denon AVR-1508 Receiver
Denon avr 400 to samsung 4k tv - Denon AVR-1508 Receiver
  • 54 Answers
SOURCE: Best Way ti connect a Denon AVR-1602 Surround Sound system with a Bell Express View Satlite reciever and Plasma TV
lets see, 3100 has no digital out, so you need analog inputs for the audio. Best picture with the 3100, use S-video. Digital input for the DVD sound and S-video in for picture. OOPS....does your TV have a S-Video input ?. If not then you have to use the RCA standard video type connector, as this particular denon doesnt do up or down conversion to or from S-video to old style RCA.
Sorry for the late response.....Rob
PS.....the HD bell wont do you any good with this receiver nbecause it doesnt have component video inputs. Enjoy Bells' superior picture with regular TV . Its way better than cable. Rob
Posted on May 09, 2008
webdevil
  • 43 Answers
SOURCE: HDMI XBOX360 Elite -"No Signal"
The connection order can be a key issue as to whether or not the HDMI signals will pass through the system. For best results the receiver should be turned on first, then the source device(s) and then the display. The reason for this has to do with getting the equipment to handshake properly for the HDCP protocol.
If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
Posted on Jan 06, 2009
lscf150
  • 443 Answers
SOURCE: I just purchased a . Samsung 50
No, you would be better off sending the video signal from your sources(satellite,digital cable,DVD,BluRay player,any digital HD source,etc.)directly to your Samsung TV, and then use the fiber optic output from the TV to transfer the audio signal to your Denon receiver, or another way is to send all video signal to your TV and send all audio signal to your Denon receiver seperately, keep in mind that there really isn't a good reason to send video into a Denon receiver, that processes sound not picture! Good Luck !
Posted on Jan 05, 2010
Testimonial: "tHANK YOU, YOUR ADVICE IS SOLID, LOGICAL AND MAKES THE BEST SENSE!"
SOURCE: No audio running TV through Denon AVR 1910
I had the same problem. You're not doing anything wrong. the thing is you can't (I don't know why but the owner manual says it) have sound going to your tv AND your HT speakers when you're using HDMI. You should try going to input setup, choose hdmi audio out to your TV instead of the speakers, and then run an optical cable from your satellite to your receiver, assigning it to the TV/Cable input.
Posted on Jan 20, 2010
  • 5 Answers
SOURCE: Flickering video with Denon AVR 1910
I had the same issue with my Denon AVR-1908.....It turned out to be the cable box, not the receiver. I would suggest you unplug your cable box, remove and reseat the cable card,HDMI cables, and finally the cable line itself. Make sure the wires are not frayed or otherwise pinched.
Good luck....
Posted on Mar 09, 2010
Why is the Display Panel no longer displaying?
There is a fuse on the front panel that needs to be replaced. When doing so, there is also a capacitor that denon suggests replacing to avoid the fuse blowing again.
Oct 29, 2015 | Denon 7.2 Channel Full 4K Ultra HD A/V...
How to connect a denon avr-e400 receiver to a televion
If the DENON has an HDMI output, and your TV has an HDMI input, then use a HDMI cable. Then, use the TV's remote-control to select "source" (or "input") as 'HDMI 2' or 'HDMI 3' (assuming that you have been using 'HDMI 1' to watch TV).
Feb 08, 2015 | Denon AVR-E400 7.1 Channel 4K and 3D Pass...
Can a Denon 3600 be updated to except wyfi
I think you'll be fine, as this particular receiver's video connections allow for 4K. Connections:
  • 1080p-compatible HDMI digital audio/video switching; 6 in (including 1 front-panel input), 1 out
  • HDMI version 1.4a with support for 3D video, 4K video, Audio Return Channel, Deep Color, x.v.Color, auto lip-sync, and HDMI-CEC
  • analog-to-HDMI video conversion to 1080p
  • HDMI-to-HDMI video conversion to 4K Ultra HD
Oct 24, 2014 | Denon AVR-3600
How can i connect my denon 5805ci with my new tv 4k & 3D sony 65"
Are you sure that model is HDMI v1.4 compliant? I know my Denon 8508 is not so I use optical outs to get 5.1 surround sound.
Sep 08, 2014 | Denon AVR-5805CI A/V Receiver Dolby...
I have a denon avr-x2000 all hdmi ports except the cab/sat are fuzzy. it started with the PS3 on the game port
Plug your ps3 and/or blu-ray directly into the TV and see what it looks like. use different HDMI cables to test them. Once you know that all works then setup your avr-x2000. Does the Denon menus look fuzzy?
Mar 20, 2014 | Denon AVR-X2000 In-Command 7.1 Channel 4K...
RE: Denon AVR 3300 - I cannot get the system setup menu to display on Phillips P50PFP5332D tv screen? All connected components work and sound great, but I cannot see Denon's Setup menu on tv to a
I understand, it's something I've misunderstood on my denon avr-790 as well when connected to a samsung 8000 series led tv.
The answer isn't in the receiver's settings (you can be on whatever source you want on the receiver end when toggling the menu). You need to toggle through the tv's sources to find the menu (usually found on hdmi 1). I've spent towards an hour recently troubleshooting only to find that it was the tv's source that wasn't set properly and I was trying to change the receiver's settings instead of the tv's source.
Hope that helps!
Jan 16, 2012 | Denon AVR-485 Receiver
Jan 05, 2010 | Denon AVR-3805 Receiver
Denon Receiver AVR 1602 not playing Dolby Digital w/ Samsung BD
Dolby signals are passed via either an RF cable or optical link. Both the receiver and player need to have these switched on and that they are passing the correct signals. You clearly found the correct setting for the TV sound link. Now you just have to find the one for the DVD player.
Jun 02, 2017 | Denon AVR-3805 Receiver
Hi denon to cable box to samsung lcd
Unless you are having res. issues you can use component / optical / coaxial cables to connect all your devices to your denon and from your denon to your tv using component cables also
Feb 25, 2009 | Denon AVR-5803 Receiver
Denon AVR1602
I know the avr 1602 well....What exactly do you mean "I have my TV cable service wired to the Denon".....Do you mean the actual co-ax cable ?....
The denon is only able to switch raw video and audio signals.
What do I mean by that ?....IF you are running your co-ax cable from your cable company directly into the back of the denon, it won't work. The Denon has an AM-FM tuner, but not a video tuner ( channels 1-121)....If this is what you are doing, then you want to run it to your samsung first ( as long as the samsung has a tuner so you can change channels ).
If the samsung operates like an old VCR, whereby you can plug the cable company co-ax cable into the back of it, and change channels with the samsung, then that is what you must do. You would then hook up the OUTPUTS of the samsing to the VCR or DVD inputs on the Denon receiver. ( use DVD inputs on the denon if the samsung has optical audio out, and use an optical cable as well for better sound ).
You would then use the Denon for the sound, and hook up your TV to the Monitor out jack on the back of the Denon.
The Denon is like a big switchbox. You plug your DVD, VCR, Satellite, video game, or what-have-you into the Denon. Then you use the denon to route the signal to your TV for the picture, and the denon takes care of the sound.
Hope this helps, and remember to always follow your owners manual.......Rob
Mar 13, 2008 | Denon AVR-1602 Receiver
Denon AVR-1508 Receiver Logo
20 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
