Question about GE Profile JGB900 Gas Kitchen Range
How to replace ignitor on GE range JGB900 - GE Profile JGB900 Gas Kitchen Range
RescueTech
  • 145 Answers
SOURCE: short on range wont work
Check for power to the primary transformer on the control. You probably blew out the controller if you find 120 volts present to the board. You may also have blown the coil on your gas valve. Be careful here!
Posted on Dec 12, 2008
  • 101 Answers
SOURCE: I've arranged to purchase this range from Sears.
possible
Posted on Sep 10, 2010
SOURCE: Me GE Gas oven is not working, but broiler and range do ?
I am working with model JGBP26WEH1WW GE Gas range: You do not need to remove the back or even turn over, just remove the storage pan at the base of the unit and disconect the two plugs (unique plugs). You will need to splice your old conectors to your new igniter. Yes you have the correct igniter for that model.
Posted on Feb 04, 2011
  • 403 Answers
SOURCE: JGB900 oven won't work. Range
Your problem is with the oven ignitor. Remove the racks from the oven, remove bottom shelf. Remove the metal plate covering flame spreader. The igniter should now be visible. Turn oven on and watch the glow from the igniter. It will come on but it wouldnt get too bright, so it wouldnt open the gas valve. After changing the ignitor, oven should light.
Posted on Feb 17, 2011
KevinWhite
  • 1902 Answers
SOURCE: I HAVE AN OLDER GE
Hello & Welcome to FixYa
If the igniter wont power up and the gas valve is fine, then the problem is with the pressure regulator or the spark module. Please get back to me with its full model# if you have any other questions.
Kevin
Posted on Aug 06, 2011
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
JGB900 oven won't work. Range top works, broiler works. No glow in oven. Regulator is on.
Feb 17, 2011 | GE Profile JGB900 Gas Kitchen Range
My ge gas range wont work on BAKE but everything else works model JGS905SEK2SS
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Part numbers, the first one being the direct replacement: WB13T10045, 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Those ignitors are interchangeable, if you can splice the wires, if not comfortable splicing wires - order the first one.
Feb 09, 2010 | GE Profile JGB900 Gas Kitchen Range
GE gas range, model #jgbp33wen5ww, ignitors clicking and gas flow on all 4 burners, but none of the burners will light.
the burners on ge range are different in size / you may have the caps on the wrong burners . 2nd / ck for the hole in the burner are clean ( do not enlarge them when cleaning .. ) if this does not work . see if the ignitor's are in good cond . if chipped replace .. mm
Nov 22, 2009 | GE Profile JGB900 Gas Kitchen Range
Oven shows F7 and continues to beep
This almost always requires replacing the touch key panel. Once in a great while you can avoid replacement by disconnecting the ribbon connector from the key panel to the electronic range control and cleaning the end of the ribbon connector with a soft pencil eraser. Good luck.
Nov 20, 2009 | GE Profile JGB900 Gas Kitchen Range
MY OVEN WON'T WORK. I TURN ON THE TEMP AND IT JUST STAYS AT 100 AND NEVER RISES. MY BROILER AND BURNERS WORK. COULD IT BE MY IGNIGTER OR SENSOR?
it is without a doubt your ignitor
if you goto www.appliancepartspros.com
typer in your model number
your looking for the bake ignitor
usually runs around 50-60 dollars but i believe they are on sale this month
it is a very easy reapir and can save you a 75-100
Oct 21, 2009 | GE Profile JGB900 Gas Kitchen Range
Ge Profile model jgb900 has error codes & oven doesn't work
Hi, this is a lock switch malfunction and you may need to replace this.Check the wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
Mar 06, 2009 | GE Profile JGB900 Gas Kitchen Range
GE Profile JGB900 Gas Kitchen Range Logo
43 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
