Question about Boating
5HP Mariner outboard no water coming out of water outlet, a water system diagram required
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 15 Answers
It would be nice to have a year.....but you dont need a diagram. in back of the prop on the lower unit there should be 3 or more holes/ slots on each side.....water gets sucked up from here. then where your lower unit bolts on to the tower there is a waterpump on the inside it pushes water through a 1/2 metal tube into the bottom of the motor then it squrits out . if its not sucking up water and or peeing then you have 1 of 2 problems
#1 blockage in the peeing tube. bugs and mud dobbers like it in there. gentle push a clothes hanger into the tube.
#2 bad water pump I change mine every year call me crazy if you like but if you run your motor without water you will be buying a new one
Posted on Jun 03, 2014
I have a late 70s 28hp Mariner Outboard, appears shift linkage has broken just below the motor where it connects to the rod that goes to the foot. How do I repair it with out moving the motor?
talk with a mariner service center
get a workshop manual for the outboard
with many outboards the selection rod comes apart with the bottom section as if you were replacing a water pump
see if you can undo the top section and let it fall out the bottom or lift the broken section out past the motor
talk wit a service center first and get some ideas
Nov 11, 2016 | Cars & Trucks
Engine diagram parts
Have you replaced the impeller in the lower unit recently? If so was it in pieces? I would start there.
Aug 21, 2014 | Clymer Mercury/Mariner 2.5-60 HP...
Mariner outboard 5hp overheating
clean the lower unit intake holes and
PUT IN A NEW WATER PUMP IMPELLER!!
Jun 20, 2013 | Mercury Boating
50 hp mercury outboard pull start diagram
http://forums.iboats.com/mercury-mariner-outboards/wiring-diagram-pull-electric-start-mariner-20hp-1985-a-468275.html
Feb 24, 2013 | Boating
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 | Boating
Outboard motor won't run under load
I have 1969 5hp Johnson. Starts and runs good, but will only push a 14ft row boat slow at low to medium rpm. When at higher rpm the the motor just revs up and the boat slows down to almost nothing just like it has seaweed around prop.Any help would be great.
Jan 19, 2009 | Boating
Mariner 40 hp outboard
If you know the year you should be able to go to http://www.crowleymarine.com/parts.cfm and pull up the wiring diagram out of the manual.
Oct 20, 2008 | 2004 Mercury Mariner
I have a Mariner outboard engine which requires the water pump to be removed for repair. The gear shift linkage once disconnected from the oprating lever will not pass through the casing in the engine...
In order to disconnect the gearshift linkage from the gearshift operating handle, a safety clip was rotated about 90 degrees clockwise. Once in this position, if you pull the safety clip towards you, it comes completely out, which then permits the gearshift rod to seperate from the operating lever.
Oct 11, 2008 | 2004 Mercury Mariner
Boating Logo
187 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
