Question about Canon EOS 400D Digital Camera
Wont recognise flash card, error message ,anyone any ideas
  • 3 Answers
If it is just one Flash card, then the card may have failed. If however you have tried other Flash cards and you get the same problem then one of the contacts (small gold coloured pins inside the camera that mate with the Flash Card) may have bent causing the error.
Posted on Apr 22, 2014
Canon mg5350s u043 error
Easiest solution is to buy an original cartridge, any colour and this will normally reset, otherwise your Google the problem and you should find a solution to disable this function, but chaeck reguarly as you wont get a warning that the cartridge is empty after you disable the function
Jul 15, 2014 | Canon PIXMA Office Equipment & Supplies
Tip
How to Format A Memory Card Using A Computer
If you are having problems where your camera or other device will not format or recognise your memory card, this is often because the card has become corrupted or the device is an older type and does not recognise the file system of the card.
You should always format your card with your camera or device (not your computer) every time you need to do this. This prevents the possibility of data errors and corruption.
However, if your device is refusing to format or will not recognise the card you can often resolve this by getting your computer to format it for you.
This often helps the camera or device recognise the card and make it functional again. If a format on your PC fails and the card is still not recognised then the card is either faulty or in the case of a camera exceeds your cameras max capability. In this case you will have to use a new card or one with a lower memory capacity.
If you have a card reader on your PC this is the easiest way to access the card with the computer. If not, a multi card reader is a cheap and useful device to have.
Be aware that formatting the card erases all information and or photos stored on it.
To format the card with your PC do the following:
1) Insert the card into the card reader.
2) Go to 'Start' - 'My Computer' and then find the card icon which will show as 'SD Card Drive' or 'Compact Flash Drive' or whatever card type you are using.
3) Right click on the relevant card icon. you will be presented with a list of options. Go down to Format and select this option.Now select a File system type.
PLEASE NOTE: Select FAT32 for 4GB or higher capacities. FAT for 2GB or lower capacities
4) Click start to begin the format process.
5) When the process is complete, take the memory card out and insert it into your device. If the procedure was successful the device should recognise it and it should work.
Note: Old cameras
Many previous old cameras and portable devices do not work if the card is formatted as FAT32 or NTFS file system. One of the following errors may occur if your device does not support FAT32 or NTFS:
- Error message asking to re-format the flash card.
- Error message that the flash card is not formatted.
To resolve the above error, backup your data and reformat your memory card in FAT file system
Hope this Tip has helped. If so please take a moment to indicate this using the Yes/No buttons below.
on Dec 31, 2009 | Cameras
MicroSD card has "fatal errors"
hi i have a 4GB microSD memory card in my blackbery and it started not reading properly not it says the memory card cannot be accessed due to fatal errors i now cant access nither pictures oe music on it can someone please help me
Jan 08, 2010 | SanDisk 8GB microSDHC Memory Card with...
My computer won't recognize my cruzer micro 8gb stick. I don't want to reformat, because I have at least 1000 pictures, plus Quickbooks, Legacy and other data on it. Anyone have any ideas?
some older pcs wont recognise sticks and sd cards larger than 4gb. it will probabaly be down to the version and service pack of windows you are using.
Aug 21, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My sony memory stick pro duo doesn't work
It sounds like the software on the card has suddenly dissappeared. Try downloading the software from sony back onto the card. Let me know if this helps.
Jun 19, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
Usb not recognised
Hello ak1979 ...
1. You're plugging in your Transend USB flash drive to your computer's USB port (as you've done many times successfully before with this SAME flash drive)?
2. It says "windows not recognise usb drive due to malfunction"?
a. Is that EXECTLY what the error says?
b. Is "it" an error dialog (window that pops up), or an error message from your Windows Event error logs? If a dialog, are there any pertinent error message entries in your Windows Event (System) log [Start > Run > type "eventvwr.msc" (without quotes), then "OK"]?
Try a bit of deductive troubleshooting:
  1. Restart (Reboot) your system [for a fresh start, if you will].
  2. Try plugging in your USB flash drive again, but in a DIFFERENT USB port.
  3. Try plugging in ANY OTHER "known good" USB device into the same USB port(s) used thus far that failed.
NOTE: If you EVER get any indication Windows recognizes the flash drive (like no error msg, or it shows in "My Computer"), IMMEDIATELY perform a "Check Disk" on it:
  1. Start > Run... > type "cmd" (without quotes), then "OK".
  2. Type "chkdsk DRIVE_LTR: /f" (without quotes), then hit "Enter" [where DRIVE_LTR is the drive letter of your USB drive]. EXAMPLE: chkdsk E: /f
Good luck, and please post back:
  • to provide any corrections/updates/clarifications.
  • if you have any further questions.
  • to let me know how things work out.
"Today's the best day of my life...and NOW you're part of it!"
Dec 24, 2008 | Transcend (589307) Media
Memory card error
hey man I have the exact problem my one is exactly the same i need help for it
May 14, 2008 | Pentax Optio S4i Digital Camera
Card errors
I suspect that the format of the camera is different than that of the computer. When I have run into similar problems, I have had success reformating the disk in the camera. If yours will not work, try another!...Dave
Jan 19, 2008 | SanDisk ULTRA II 4GB Compact Flash Card...
Error Message on start up
go to this page, http://rcaaudiovideo.com/en-US/RD2780_Upgrade and follow the instructions, i had this same problem, and i fixed mine
Apr 12, 2007 | Thomson Lyra PDP2860 Digital Media Player
Canon EOS 400D Digital Camera Logo
35 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
