Question about Yamaha Audio Players & Recorders
Reduce smoke in 2 stroke engine yamaha rx100 - Yamaha Audio Players & Recorders
  • 97 Answers
SOURCE: what is the maximum rpm for 50 yamaha 2 stroke
max operating rpm 4500-5500 see www.broadwaterboating.com.au/outboards/335_Yamaha_50hp_Mid_Range_2-Stroke.php for complete specifications. Hope this helps
Posted on Aug 06, 2009
ollie reece
  • 1167 Answers
SOURCE: the muffler is all leak ing and gap 2 stroke oil leaking out
hi buddy they do leak oil from the exhaust but if there is no power its normally the piston rings gone i will tell you how to check this when i get home from work
Posted on Sep 17, 2009
  • 18 Answers
SOURCE: yamaha outboard starting
New plugs and service
Posted on Sep 21, 2009
  • 26 Answers
SOURCE: WHERE DO WEGET THE YAMAHA RX100
hi anbudharin; welcome to the forum!
yamaha RX100 bike is excellent
1) no maintenace 2) engine power and pickup awesome 3)best suited daily ride 4)especialy its sounds rocking in the city
If anyone planning to buy used Yamaha Rx100, Just go for it by closing your eyes. If you could spend few hundreds initialy you can renew ur bike as like new one which you cant get it from any other bike
Keep track of the 2T oil regularly, if you ride a bike without oil, performance of the engine may go down. I drove this bike form bangalore to hubli once in a three month and I love to ride this bike on such a long drive
if u want seconds pls gothrough this classifides http://www.clickindia.com/search.php?q=yamaha+rx100+bike+for+sale
Posted on May 22, 2010
vishnuyzf
  • 57 Answers
SOURCE: How to modify yamaha RX100 in yamaha YZ 125
it is possible in a city like bangalore
Posted on Jan 29, 2011
White smoke from exhaust on yz 250
Hi, Anonymous and the usual suspects are:
1. Oil tank/pan overfilled.
2. Restricted oil return line to oil tank/pan.
3. Restricted breather operation.
4. Restricted oil filter.
5. Piston rings badly worn or broken.
6. Valve guides worn and or seals worn, crushed, missing, or have come of guide and are literally pumping oil through the valve guide.
7. O-ring damaged or missing from oil pump at crankcase junction (also results in poor engine performance). For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
YZ250 White Smoke Yamaha 2 Stroke
Dirt Rider Magazine
YAMAHA YZ250 LC Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Jan 18, 2014 | Yamaha YZ 250 Motorcycles
My Yamaha rt 180 is smoking
Being a 2 stroke engine it is normal to smoke!
Oct 04, 2013 | Yamaha Motorcycles
Yamaha yz80 2 stroke or a4 stroke
2001 Yamaha YZ80 Specifications Engine Engine Type
2-stroke Displacement
83 cc Bore x Stroke
47 mm x 47 mm Compression Ratio
8.2:1 Engine Cooling
Liquid Carburetion Carburetor
26mm Mikuni Transmission Transmission
6 - speed Chassis Wheelbase
49.5 in Ground Clearance
13.7 in Seat Height
33.6 in Fuel Tank Capacity
1.3 gallons Forks Forks
33mm Kayaba Fork Travel
10.8 in Shock Shock(s)
Kayaba Shock Travel
11.1 in Wheels and Tires Front Wheel
17 in Rear Wheel
14 in Brakes
disk/disk Other Information Intended Use
Motocross Color Scheme
Blue Cost when new
$3199
Jul 19, 2010 | 2003 Yamaha YZ 250 F
May 22, 2010 | Yamaha RD 250 Motorcycles
Can I place an in line bulb primer on a yamaha 2 stroke watercraft, it will not start when cold withoutv starter fluid. Also it seems to smoke alot when idling.
First - Never use starting fluid on a 2 stroke engine. It could wash the oil off the bearings and cause the engine to seize. Try using WD-40 to start it when it is cold. Another thing to try is getting a spray bottle and put your mix gas in it - then spray that into the carb to get it started.
Most of the primar bulbs are 'universal'. You could pick them up any boat supply house, you can also try NAPA.
Two stroke motors smoke. Here is some things to check -if it is oil injected see if you can adjust the amount of oil, if you have to premix the gas, double check your mixture ratio. I like to run most two stroke engines at 40:1 but use good quality 2 stroke oil.
Aug 07, 2009 | Boating
My 81 yamaha enduro is smoking badly
Same happended to me with exactly the same motorcycle... I solved the provblem by replacing the crankshaft oil seal on the rightside of the crankcase. It solved the problem immediatly!
Jun 04, 2009 | 1974 Yamaha DT 360
I need the spark plug gap for a 2001 Yamaha 115hp 4 stroke outboard.
For a 2001 Yamaha F115 4 stroke use NGK Plugs LFR6A-11 gapped between 0.039 and 0.043
May 09, 2009 | Yamaha 12V Air Pump
Hi there i have a yamaha dtr 125 thats smokes
Assuming you are using two stroke engine oil, the pump is pumping too much into the gas. DO NOT use motor oil in the gas. If 2 stroke oil is being used, then get a new pump, fix the one you have or disconnect the pump and mix the oil with gas when you fill up. Four ounces of 2 stroke oil per gallon of gas equals the standard 32/1 fuel mix.
Apr 28, 2009 | 2003 Yamaha DT 125 R
Yamaha india
hello Sir,
It was the phase between 1990-1995, when Yahama lost to Hero Honda, as v know, Yahama was an expert in 2-stroke engine bikes, as v know 2-stroke engine will yield higher power but NO good mileage, n emit more smoke.
so...GOV OF INDIA phased out all production of 2 stoke engines in the country, so yamaha had to stop the production of Yamaha RX n RD series in INDIA.
N constantly rising fuel prize, utilizing this need form d public Hero Honda's CD 100 hit the market, with 4 stroke engine n heavily improved mileage.
hence Hero honda won the race...
Although Yamaha came up with some 4 stroke models, but those didnt click it for them, but now its again yamaha's time !!
with introuduction of Yamaha R15, FZR , really yamaha is back with a bang !!
thank u so much..!!
plz vote me/ rate me ..thank u!!
May 22, 2008 | Yamaha RX-V520
118 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
