Question about Skil 4235 Jig Saws
Skil 4395 jig saw - Skil 4235 Jig Saws
2 Suggested Answers
kirkx
  • 2019 Answers
SOURCE: Can a jig saw rip fence (Skil rip fence model No.
Yes, but not very well.
That is because the fence ridge is intended to rest on the edge of the wood, and if you want a circular cut, you need to attach to the center of the arc.
In order to do that, you would have to turn the fence over so that the ridge pointed up and did not impact the surface of the wood.
Then you need to attach a point of radius.
The best way I can think of doing that would be to drill a hole through the sheet metal, near the ridge, and near the shaft.
Then use a small nail or pin through this hole you drilled, to stick into the wood surface far enough for a reasonably steady pivot point.
Best I can thing of.
But you could also just use a piece of wire to the rotation point pin.
Posted on Mar 11, 2011
Jig saw blades wont stay in.
loosen it more before you put the blade in.
Mar 16, 2014 | Skil Saws
How do you change a blade on a Skil 4280 jig saw?
It is REALLY easy, when you know how. There is a black piece, the larger one, near blade insert...lift it and VOILA, you can insert or remove blade easily. I lost manual and spent forever trying to put blade in. Hope this helps.
Sep 22, 2013 | Skil 4280-01 4280 Variable Speed Jigsaw...
Oil leak from my Skil Jigsaw and it keeps Jamming when I cut wood
get a nail file and sharpen the blade till you can see your face in it
May 07, 2013 | Skil Top Handle Jig Saws Variable Speed...
How do you change a blade in the Bosch Jig Saw Model 1587 AVS
Pull the black knob on the top front of the handle up and turn it clockwise to tighten and counterclockwise to loosen. I'd turn it counter clockwise at forst just to make sure it's loose enough to accept the blade when you start.
Sep 01, 2011 | Skil 1587AVSK - Bosch Jig Saws Power Tools
Need to know how to put blade in
Just pull up on that rectangle shaped black piece on the top of the blade. Then pull the blade out. You can use both type blades in this model. take care and good luck.
Mar 08, 2011 | Skil 468004 5 Amp Jig Saw Kit with Laser
Blade broken down in jig saw
This may sound to simple and not mean to be funny or insulting but why can,t you just take the screw out that holds the blade in you would have to do this when ever you needed to replace or change to a different blade Idon,t know mabey im missing something that your trying to say im not sure
Dec 04, 2010 | Skil 449501 6 Amp Jig Saw
It's actually a Skil model 4280 sabre saw. Problem is it doesn't grip blades properly, so they are constantly slipping out. Chuck seems to be engaged, have shot WD-40 in it - no change. Ideas?
There is nothing wrong with your Skil 4280. The universal U chuck blade is the problem. Look at Lenox blade 4318JC or Disston 5418 and you will see a slight ridge on the face of the blade on both sides where the teeth start and the blade tail engages the chuck. Without the ridge the blade will come out.
Oct 05, 2010 | Bosch Skil No.4280 - 01Variable Speed Jig...
Motor goes round in the dewalt but there is no drive.
check bearing and brushes, this was my problem on my SKIL 4280.
Mar 28, 2010 | Dewalt DC330K XRP 18v cordless Jig Saw Kit...
Skil 4235 Jig Saws Logo
Top Skil Saws Experts
JOHN LAPIER
Tim Venetis
Are you a Skil Saw Expert? Answer questions, earn points and help others
